Old 15th December 2016, 19:35   #421
Stanher's Avatar
Thanked: 1,548 Times
Default Re: MPR 4142, 1959 Fiat 103D Select Restoration.
Now with the car in safe custody, the big task remaining is to get the car registered in my name at Hosur and I seek help from members in this regard. Do any one has contact to get this done.
We started to work on the car and quickly dismantled the remaining bits on the old car. Plan is to use which ever is good from the 2 cars, refurbish and fit back.
Just to clarify - you're not going to start restoring the 'new' fiat for now, are you? Looks ok to me at present!
Stanher is offline   Reply With Quote
Old 15th December 2016, 20:54   #422
manishalive's Avatar
Thanked: 704 Times
No not a full blown restoration. But mechanically correcting the things. And installing the new wiring.
manishalive is online now   (2) Thanks Reply With Quote
Old 16th December 2016, 13:34   #423
SHAHBAAZ's Avatar
Thanked: 95 Times
Continuing further -
The registration book still retains the old information (what a nice thing to have)
Attachment 1585327
Moving ahead found that the car has original seat cover on the rear seat -
Attachment 1585328
The front seat is non original tough.
Between my 2 cars there are now lots of good stuff and largely my new car will become original.There are few bits and stuff still remaining of which I have a list and am on it.
Meanwhile some more progress -
The horn button is refurbished
Attachment 1585330
The original water pump pulley
Attachment 1585332
The original rubber gasket for park lights (I have similar for tail lamps as well). These will be reproduced as well, waiting for raw materials.
Attachment 1585333
The original Sipea flasher units
Attachment 1585335
Now comes the task of mechanically sorting out the car. Recently my ex colleague has returned back from Canada and has build up his hobby work space at ground floor of his house. This is fully furnished with TIG welding, 2 post lift and a mini lathe to name a few. Having this facility available I dropped my old car at his place.
A look at his place -
Attachment 1585337
Attachment 1585338
Attachment 1585339
More updates as and when we work. Also on a side note I have 5 numbers of 5.20-14 tyres that I had purchased new some time back. I also have the white wall seat inserts to go on these.
Attachment 1585340
Good to know about the progress and purchase of a donner. It seems that your hands are full in the Hobby workspace. Best Luck.
SHAHBAAZ is offline   (1) Thanks Reply With Quote
Old 17th December 2016, 16:59   #424
Thanked: 704 Times
Thanks Bro, yes we are busy bringing her up to level. Lot of things to do. We dismantled the old car completely. We found many original bolts and stuff. We also found that on the Brake shoe holding plate we have a different color than black (on the rear ones). Could this be the original color -
Karlos has once told me it's not black. Need help guys.
I now have a new wiring harness (pin type) but with plastic sleeve. I would like to ask how to go about the cloth sleeve for the period correct look. I have seen tape rolls coming that do the job
But what color should be the cloth sleeve. So far I could not see any reference online. Jay Leno car does not have seems to have any sleeve
Also an a similar note the door seal was made of cloth. Which color was that and where do I get that.
The current number plate for my car is in this style, what should be the period correct one -
Name:  DPP_0006 1024x683.jpg
Lastly I have one question on the instrument panel. Do we had these in Indian Fiats as well
Name:  Instrument panel.png
manishalive is online now   (3) Thanks Reply With Quote
Old 1st August 2017, 19:42   #425
Thanked: 704 Times
Time for some updates guys. The body work is in good condition but mechanical's were needing urgent attention. So over to my friends shop for rework
At the workshop -
The chassis is being worked upon (note the single radiator mount as opposed to 2 mounts on original) -
Upon dismantling found these rather amusing rear dampers. As per Rony these would be rare vintage items but not sure of originality
The previous mechanic had cambered the springs to have 11 inches of height and thus providing wrong working angle for the shackles. These were re-cambered back to specification of 6 inches.
The wheels were sand blasted & straightened on the machine.
Painted and new tyres installed along with white wall inserts.
Search for original paint in places found to be of no use. So plan to have a shade of blue green as the new color.
Engine no found on the 58 Fiat has 103E designation and is a numbers matching. The 59 Fiat engine is good with all new parts and will be used. Old numbers will be punched tough.
The 59 Fiat engine is prepped for installation, the old mechanic did some wrong doing here too. All is being bought back to specification.
The engine block is prepped with high heat primer and silver. Further sealed with clear coat. This is what originally came on the cylinder blocks
manishalive is online now   (11) Thanks Reply With Quote
Old 2nd August 2017, 11:08   #426
KartikeyaL's Avatar
Thanked: 4,653 Times
Wow,apart from a great restoration, your friends work shop looks just amazing, neat and clean, unlike most in India.
KartikeyaL is offline   (2) Thanks Reply With Quote
Old 2nd August 2017, 12:30   #427
Thanked: 704 Times
Kartik,
Yes, that's the best part of all the process. Thanks for the complements. He is the best guy so far I have seen. He is taking care of the minutest of the minute details.
All components were sand blasted and painted
All of the hardware was galvanized, this was done in batches so as not to loose track and miss the rare fiat bolt.
A hydraulic press was fabricated for pressing the bushings correctly and also to straighten the bent hardware as well.
Rear end gets buttoned up.
Engine bay gets ready for all the mechanical stuff
The engine bay is painted from a spray can, Ford tractor blue. This will be the right match to the exterior color change.
The steering box was get's attention too, lot's of year of use had the oil caked up, also the hole to support the gear shaft is being mended as well. The earlier mechanic didn't bother to even look at this. This is what I like about my friend, almost every mm of the car is now being looked and perfected.
The steering shaft also got attention by way of re threading.
The original type wiring harness that I had. I also procured the same type bullet connectors from Aliexpress for any eventuality. Most of my electrical components are having bullet connectors.
To replicate the authentic vintage style harness, I purchased wiring sleeves from the market. I also procured the glue backed cotton tape from Aliexpress.
I also purchased varnish to be applied once we install the sleeves / tapes.
manishalive is online now   (9) Thanks Reply With Quote
Old 2nd August 2017, 17:59   #428
Thanked: 704 Times
The original made in Italy bearings are in good condition and are being re used. Except front wheel outer ones as they were damaged.
We wanted to change this front wheel inner bearing as well, but being of imperial dimension a replacement is hard to find so clean and reuse then. This problem comes only if you use the original hub.
MPR 4142, 1959 Fiat 103D Select Restoration.-2-front-wheel-inner-bearinh.jpeg
A single wheel cap and a single tail lamp glass was found with a seller in Italy (through FB). Both are original items
Thanks to Indrojit Sirkar, I got this original lamp glass. Carello stamped
The original fuse box with original fuses
The original cut out with the lamination plate. This will be installed with dummy wires running to make it look authentic. The original Dynamo will be placed in a box for show purpose.
The original Carello headlight connector is procured from a n Italian seller on eBay, they are on the way.
Name:  9headlight connector.jpg
The speedometer is all ready.
manishalive is online now   (8) Thanks Reply With Quote
Old 5th August 2017, 09:22   #429
Thanked: 147 Times
Attachment 1663051
Very neat! Is it an original idea? Is it a bottle jack?
Vaguely remember the dual damper set-up on some diesel transplant done old ambassadors. That was jugaad work by local mechanics, not sure about factory cars having dual dampers.
crdi is offline   Reply With Quote
Old 5th August 2017, 11:29   #430
Thanked: 704 Times
I am pretty sure this would have been done before. My friend encountered problems by the way people work here so this was fabricated.
And what do you mean by dual damper?? My setup is all stock and original to 58 model year.
manishalive is online now   Reply With Quote
Old 6th August 2017, 09:38   #431
Thanked: 147 Times
Sorry, my bad! The picture of the damper confused me. Thought that two dampers were fixed on one side itself, to one link. If that was the case, of course you would have recognized that to be a jugaad.
Such stuff were done by resource scarce mechs of yesteryears, supposedly to improve load bearing. Not at all judging the quality of work or the originality of the car
Old 31st October 2017, 16:14   #432
Thanked: 704 Times
Time for some update guys, All this work has paid off and the car was successfully fired a few days back. Some pictorial updates -
As suggested by Karlos, Gypsy filter element was modified to fit the original air filter body. My friend did a good job there.
The original made in Italy carburetor was refurbished with all new and original parts.
Engine bay getting there, some of the original parts are yet to be installed as they need to be better prepped and since they are bolt on can be done any time.
Original wheel caps coming from Germany.
Car is finally back on all 4 legs again, The rear suspension (leaf spring) height is not looking good, we will get this sorted tomorrow.
Restoration - 1963 Fiat 1100 Super Select karlosdeville Post-War 95 3rd June 2017 12:46
Restoration of "Vinty", a 1960 Fiat Select 1100! CAC444 Post-War 105 10th December 2016 01:13
Kolkata - 1959 Fiat Milicento / Select FIAT'57'Kolkata Post-War 48 4th September 2013 22:51
The MPR-999 is here! (Universal Learning Steering Remote Control ) frankmehta In-Car Entertainment 110 2nd April 2012 18:45
1959 Chevrolet Belair Restoration. junkmn Post-War 3 26th December 2010 12:47
