Old 28th January 2010, 22:37   #91
Thanked: 22 Times
today after some basic painting, put together some bits to see how she looks. How does she look then?? Is the all green body ok or should i make the side rear window panels and tail gate top also lime stone?/ Then we did some chequered plate for the tub next will be the cab floor and wing tops.
Polly
Polly Singh is offline   (2) Thanks Reply With Quote
Old 28th January 2010, 23:42   #92
Jaggu's Avatar
Thanked: 8,686 Times
I think the color combo is just perfect, no need to deviate. Great going as usual!
Old 29th January 2010, 01:03   #93
chanu's Avatar
Thanked: 140 Times
I feel if the window panels can be coloured limestone it will look fine along with the same colour on wheels.
How about the front mesh what is the colour polly sir?
chanu is offline   Reply With Quote
Old 29th January 2010, 10:05   #94
ajitkommini's Avatar
Thanked: 109 Times
I agree, the window panels would look better if they matched the roof colour. The front grille should be silver I guess. What about the bumper?
ajitkommini is offline   Reply With Quote
Old 29th January 2010, 21:05   #95
Thanked: 22 Times
Oh No i was hoping you would like the present scheme, its uncommon for the series Landy but not wholly incorrect. The configuration and schemes the series Landys came in was mind boggling add to that upgrades, repairs and replacements and you have a veritable pot pouri of styles. My only grouch against your recommended scheme is that it would look too much like a Gypsy !!
iam making the headlamp surrounds matt black as opposed to the standard silver, the grill matt black, the wing chequer plate- matt black and the bumper stock silver (hammer-down silver with the pebbled effect) likewise the windshield, cappings on tub and door tops. Sounds any better??
Polly
Polly Singh is offline   Reply With Quote
Old 30th January 2010, 01:38   #96
chanu's Avatar
Thanked: 140 Times
Sounds absolutely fine to me. Yes the headlamp rims would look beautiful with new sealbeam and matt finished rims even my Willys has the same way.
Do put some badges like "AA" or some landrover badge with yellow colour it looks cool on the front mesh.
Have you thought about a mesh (a rectangled box) for indicators on the front with the limestone colour polly sir. If it is apt.
Once finished would this be a day to day commuting vehicle or only on special occassions polly ji?
Old 4th February 2010, 22:13   #97
Thanked: 22 Times
Well, hard work continues through the night, its all the small stuff now, tried out a silver on the barbecue grill and re did the steering wheel and the dash. Removed the glow plug heater indication which the PO had put into the dash leaving an ugly hole by riveting a sheet cutout and filling it with body filler.Entering the last lap now!!
Polly
Polly Singh is offline   (1) Thanks Reply With Quote
Old 4th February 2010, 22:43   #98
samsag12's Avatar
Thanked: 206 Times
Really a great and commendable work being carried out by you Mr Singh. It seems that working on a car having a full aluminum sheet body is very tough and time consuming as one wrong move will lead to more hard work. In metal one can repair the mistake, such as getting the wrong hole covered made in fender, by welding it but not in this case. You are doing true justice to this ancient beauty by supervising each and every rivet going on it. Hats off to you Mr Singh.
Old 5th February 2010, 11:27   #99
Thanked: 109 Times
Polly
Matt black headlamp surrounds would be nice. Wing-top chequer-plate also.
Not sure about the grille though, black would be a very "low-contrast" look. I guess it's hard to imagine without actually seeing it. But at the end of the day it's your car and there's no right or wrong. The only success criterion is that it should put a smile on your face every time you look at it, and going by the pics you've posted I think it's well on it's way to achieving that goal!!
Old 6th February 2010, 07:48   #100
Thanked: 22 Times
dear Samsag 12, thanx for your kind words, yes it is a built difficult to work with aluminium alloy Birmabright which the landy is made off, warps easily under heat, have to be careful when welding if at all, riveting is best!!
Polly
Old 6th February 2010, 07:50   #101
Thanked: 22 Times
Thanx Ajit, exactly my thoughts!!! and how its probably gonna turn out.......
Polly
Old 11th February 2010, 00:58   #102
chanu's Avatar
Thanked: 140 Times
Polly sir any new updates, hungry here.
Old 11th February 2010, 07:50   #103
Speed-Gladiator's Avatar
Thanked: 11 Times
Hi Poly, I have been watching this thread very closely, Interested to get the updates. Did anybody notice that this thread has got 5*.
Good going poly, waiting for the update
Speed-Gladiator is offline   Reply With Quote
Old 13th February 2010, 20:17   #104
Thanked: 22 Times
well guys everything is held up as wiring is on now, then we' ll do the last touch ups and cutting of the paint. Was trying to get the play out of the steering and found all the ball joints shot. could have temporarily fixed them, but that would have lasted only a few months especially in the off road scenario, so spent a few days hunting for alternatives and came up with the Ford tractors ball joints which fit well but have an extra thread on the reverse thread side of the rod ends. had to have an extra thread cut into the tie rods and we are good to go now. Took apart the indicator assembly and wondered at the simple mechanical wizadry. The lever simply puts a shaft which is under spring tension-off kilter and the rubber gromet sitting under the steering wheel hub, releases it when the driver turns the wheel the other way, the assembly even has a green flashing light in situ which flashes whenever its engaged !!! had it cleaned out, buffed and put back as new with a new rubber gromet.
Had some logo stickers made for the mud flaps as well.
Put a relay in the head light circuit to prevent the sealed gas head lamps from blowing in case of an over- voltage runaway from the original but unregulated Lucas alternator as well.
Deviated greatly from stock by putting the fuse box under the dash as against the engine bay as i dont see myself stepping out into the pouring rain of a sudden 4 :30 PM Bangalore shower to open the bonnet and fiddle with the fuse box. Still have the original fuse box and could revert to original quite easily!!
the seats also just came in !!
Heres a pic of an old man driving a "Moga" jeep on the high way near the garage , thought you photo hungry BHPians might stop panting long enough for me to make some progress on my car !!!! enzoy
Polly
Old 14th February 2010, 01:44   #105
chanu's Avatar
Thanked: 140 Times
Congratulations!!! our family is 6 years young today!!
This thread is rated 5* a well deserved credit. Looking forward to the British beauty revealing its New Avtar,
Polly Sir any plans of a nice PHOTO SHOOT once completed?
Pics: Silver Land Rover Range Rover SE Gordon Super-Cars & Imports in India 38 4th May 2011 17:06
Can a 1969 Series 11a SWB Landrover be considered a classic with diesel conversion? eyedoc Post-War 13 13th October 2009 09:06
Land Rover Unveil 2010 Range Rover Sport with all-new 510hp V8 Engine hanmust The International Automotive Scene 2 8th April 2009 20:53
Land Rover unveil the LRX - to be badged Range Rover Tstag The International Automotive Scene 26 14th March 2009 16:17
