Old 23rd December 2009, 10:13   #16
deutscheafrikar's Avatar
Thanked: 316 Times
Originally Posted by wartikars View Post
But where will I be able to find the specification about the brake oil of the W123 series Mercedes Benz 300D? Does it differ from one series to anothee i.e. W123 to W124 ........
On the brake fluid filler cap. Say how come I haven't seen a photo of your mercedes? While you're clicking the pics please get one of the brakefluid container. It should be dot 3 or dot4. Time some mercedes owner let us knwo the fludi type after checking his brake specs
deutscheafrikar is offline   Reply With Quote
Old 23rd December 2009, 20:30   #17
Dear wartikars
could we get to see few snaps of your 300D.
bsa1955 is offline   Reply With Quote
Old 25th December 2009, 08:48   #18
boeuff's Avatar
Thanked: 63 Times
I own a W123 series Mercedes Benz 300D. When I was driving it from Belgaum to Pune I had to brake suddenly as the truck in the side lane suddenly came into my lane to overtake tractor in its lane. After this the brake was not working for a long time. I had to park the vehicle for some time at the side of the road. Then I was ok again. When I reached Pune I took it to the mechanic who removed air from the brake pipes. All the 4 brakes are disk brakes. I had the same problem when I was driving in the Amboli ghats from Goa to Belgaum. And the mechanic in Belgaum had to do the same thing (remove air from the brake pipes). I am unable to ascertain the root cause of the proble also at the same time I don't want to be duped by a mechanic for lack of knowledge. Please help me.
We had the exact problem in our 123 Mercedes. Found that the wheel caliper piston was jammed causing overheating and heat transfer into the fluid.
Cleaned all 4 wheel calipers and replaced the seals, problem solved.
boeuff is offline   Reply With Quote
Old 25th December 2009, 11:56   #19
wartikars's Avatar
Thanked: 12 Times
Thanks Boeuff! But does this problem still persists? And what is the specification of the brake oil that you use? I am currently using the common one that is available at the HP outlets. If it is not the correct one then I will surely, flush out the current oil and put the specified oil. Also please let me know about the cost that you incurred in cleaning all the 4 calipers & replacing the seals.
I will surely ASAP post the snaps of my 300D and the brake fuild filler cap.
wartikars is offline   Reply With Quote
Old 25th December 2009, 16:37   #20
Thanked: 316 Times
wartikars
What is the type of fluid youve bought from HP? Dot 3 or Dot 4
Drive your merc and check if any of the disks are gettign more hot then the others? or jack up each wheel and turn to check. But if this were the case your mechanics would have found out by now. Cause you have got work done at belgaum and pune, right?
Old 25th December 2009, 19:13   #21
Dear wartikars
The rear 2 cylider kit costed about 1300 rs. yes after the change of kit the problem was solved. (Due to jammed cylinders the wheel used to jam and because of heat the brake fluid used to vapourise).
As per the instructions on the cap only DOT 4 brake fluid is suggested
Pradeep
Old 27th December 2009, 16:02   #22
wartikars's Avatar
Thanked: 12 Times
I was not aware of the specification fo brake oil in dots. I had asked for a brake oil at the HP petrol pump in Goa and the salesman gave me the brake oil. Does HP provide the 3 dot & 4 dot oil separately? OR is the brake oil a generic one? Is 3 dot a less dense brake oil than the 4 dot?
Old 28th December 2009, 22:06   #23
wartikars's Avatar
Thanked: 12 Times
I have checked the can of the brake oil. It says, "3 DOTS". I was a bit suspeciuous but was not confirmed about the desity available in the market. Where can I get a '4 DOTS' brake oil?
I have started to upgrade my knowledge about 300D W123. Thanks to you all.
Old 28th December 2009, 22:09   #24
Thanked: 316 Times
They may have both types at the pump. check the container. If you don't have it then go to a pump in pune and check details on a similar brake fluid container.
Old 31st December 2009, 16:24   #25
wartikars's Avatar
Thanked: 12 Times
I am still trying out to find the 4DOT brake oil. If I want to change the current brake oil with the correct brake oil myself, can it be done easily? If yes, then please let me know the procedure/process to do it myself?
Old 31st December 2009, 17:28   #26
SX4LOVER's Avatar
Thanked: 129 Times
I didnt know cars like Mercs for which you pay close to a quarter crores can develop such defects!!
SX4LOVER is offline   Reply With Quote
Old 1st January 2010, 14:09   #27
wartikars's Avatar
Thanked: 12 Times
Yes you are right SX4LOVER. You are absolutely right. These German beauties are seamless. But after 25 years there might have some health issues. I had bought this car almost 4 years ago at just Rs.3 L. And now it is almost 25 years old beauty. And again I take up the onus of creating the problem. I had not put in the correct brake oil.
Old 7th January 2010, 20:34   #28
wartikars's Avatar
Thanked: 12 Times
Old 7th January 2010, 21:56   #29
Jaggu's Avatar
Thanked: 7,475 Times
I wouldnt recommend a DIY with brakes, instead procure the right grade fluid and approach a garage. Its a straight forward job which garages can do in 30-40 minutes. If you dont do the bleeding and refill properly, loss of braking/jamming etc are real possibility and will compromise the safety.
Old 8th January 2010, 21:20   #30
imperial.s.a's Avatar
Thanked: 15 Times
as jaggu says go to the right mechanic because the123 is an no nonsence car get the fluid changed the brake subject is been discussed for a while i had suggested the idea to sort out your problem in the begining in case your are going to kolapur my good friend who runs an very old garage there called mandody his name is vivian can take his advice
imperial.s.a is offline   Reply With Quote
Mercedes Benz 300D (W123 series): Manual Transmission to Automatic Transmission. wartikars Post-War 5 3rd January 2014 12:39
Mercedes Benz 300d bsa1955 Post-War 90 4th February 2013 13:01
Looking for A Mercedes W123 300D Automatic canonball Super-Cars & Imports in India 28 29th November 2011 18:22
Advice On Restoring My 1985 Mercedes Benz 300d (w123) LOVE HER(ALD)! Post-War 3 7th October 2010 15:28
