Old 14th January 2010, 00:42   #31
Stanher's Avatar
Thanked: 1,693 Times
Originally Posted by abhijosh View Post
Hi Stanher!
Great job Boss!!!
Can you please elaborate on the specs of the engine particularly? I believe I can lay hands on a similar Herald here. Same two door version. I have seen one rusting near my home. Just need to enquire about the car.
Thanks abhi!
Well, engine is 4 cyl. OHV 948cc.
Good luck on the Herald you're trying for. Any pics. you can post of it? So we could maybe guide on you on what to look out for in the car etc...
Anyways, here's further updates- left side scraped nearly completely, and part of the rear roof too. More rust spots and filler jobs seen! Also seen is the closed hole for the fuel tank filler, and some shoddy welding job on the rear wing. It started to rain just after I took these pics. today, and I left shortly later.
A few more pics. to be included, my net is going real slow right now!
Stanher is offline   Reply With Quote
Old 14th January 2010, 21:18   #32
kingofmyworld's Avatar
Thanked: 249 Times
At which place are you getting it restored?
kingofmyworld is offline   Reply With Quote
Old 16th January 2010, 00:37   #33
IndrojitSircar's Avatar
Thanked: 116 Times
The work seems to be progressing quite well.What about the mechanicals ?Have you started anything on them?What are the mechanicals you are planning to do ?
Old 16th January 2010, 01:13   #34
Stanher's Avatar
Veerabhrama auto works, Balam Rai checkpoint, on the way to Tarbund X-roads (opp. old airport boundary wall), Sec'bad
Not touched them yet, sir! Engine's quite well. Gearbox would need to be worked on, clutch plate is said to have gone. Once the body is off the chassis, planning to get suspension done too.
Old 16th January 2010, 01:17   #35
Thanked: 116 Times
Ok hope to see some more reguler updating with pictures .Thought of changing the tie-rod ends and changing the brake linings?How about getting new wheel cylinders and a master cylinder or servicing the old ones ?
Old 16th January 2010, 01:32   #36
Stanher's Avatar
'had been there today, workshop was closed and my camera batteries were down, so no pics. But the whole body as of today, has now been scraped fully of the paint. Except part of the front bumper and grille surround. 'will post pics. tomorrow. Also I've felt that it's better to post an update when there is major work done every time with atleast half a dozen pics. to post rather than just 1 or 2.
2 of the wheels have got new wheel cyl. kits. The remaining are to be done. Tie-rod ends I do have a few new ones. Brake liners may have to be imported if needing replacement.
Old 16th January 2010, 01:37   #37
Thanked: 116 Times
Ok i suggest you get all of them since you are stripping down the car.You don't need to import liners because they are available in rolls and you are ment to use the old shoes and take of the old linings and rivett on the new ones.Ask around where it is available.It was commonly done on fiats and ambys as well.Try and get is possible new shock absorbers.
Old 16th January 2010, 02:01   #38
Stanher's Avatar
OK, will do.
Speaking of new shocks, your father, when we'd last spoken, did tell me he had seen a pair of brand new herald shocks at a spares shop there! 'forgot to follow up with him since!
Could you ask him about them , if they are still available?
Old 16th January 2010, 02:08   #39
Thanked: 116 Times
OK, will do.
Yes i will do that for sure but after the tolly show is over on sunday.
Old 17th January 2010, 00:39   #40
Stanher's Avatar
OK all, as per Indrojit's request, here is a relatively regular update- with more pics.!!
As you can see, the body is nearly completely stripped off of the paint and trim, and also dismantling of smaller panels has commenced. The rear bumper valences and guards on either side are out, as are the petrol tank and the front grille and bumperguards. The rear chrome guard on the right was proving quite a task to get out today, the bolts being rusted solid!
More pics. later, feeling too tired now!
Old 19th January 2010, 00:36   #41
Stanher's Avatar
More updates!! The car has been further stripped, this time of all the glass except the front one, plus quarter-windows, and all the cosmetics from outside.
The right rear bumperguard had proven rather stubborn to take off, bolts being jammed with rust. But he finally managed to get it off (carefully enough) after a lot of effort. Some of the other fittings had to be got off the same way.
With the glass and other major external fittings off, one could see the formerly hidden rusty horrors that crept into the body crevices! The rear roof deck particularly, as you can see, has had it!
No, this is not the wreck of the Titanic, it's the rear side of the underbody. The chassis outriggers (rails that hold up the rear body tub, left and right) are both intact- just!
I'm now considering having the chassis sandblasted once stripped.
Stay tuned for more...!
Old 19th January 2010, 00:44   #42
Thanked: 116 Times
Wow
Work atlast seems to be in full swing.What do you think about removing the Dash board along with the meters so that it stays safe somewhere.Have reminded my father about your struts.By the way are you getting new glass rubbers for the quater glasses etc ?
Old 19th January 2010, 01:24   #43
Stanher's Avatar
Wow
Thanks!
Dashboard and other internals will be removed in the next step, rest assured!
I do have new rubbers (brought from th UK) for the front and rear windscreens, which can be used for this car. 'need to get a pair for the side-glasses as well.
Old 19th January 2010, 01:27   #44
Thanked: 116 Times
Thanks!
I do have new rubbers (brought from th UK) for the front and rear windscreens, need to get a pair for the side-glasses as well.
Thats good news.What side glasses are you planning to get ?
Old 19th January 2010, 01:34   #45
Stanher's Avatar
Um, I'm not changing any of the glasses at all! They will be the ones that came on the car only.
I meant the rubber-beadings for the side-glasses.
Blue Angel - Resurrection of my Yamaha RD350 MindSpeeDs Motorbikes 70 26th August 2017 13:22
Vatsa Vintage Resurrection - Rajdoot GTS 175 aka Bobby SA7VA5 Post-War 44 10th February 2017 08:07
Resurrection Z: The two stroker lives on (Yamaha RXZ) Roomy Motorbikes 12 23rd September 2016 19:34
Superb article on the resurrection of KTM Bookkeeper Motorbikes 2 16th February 2016 16:22
Resurrection: A CJ3B STORY diesel_maniac 4x4 Vehicles 147 9th September 2011 11:57
