Old 7th October 2016, 15:44   #106
Default Re: Another Fiat - The Restoration of a 1956 Millicento
Ilangop - the engine is aligned to the longitudinal axis, but I will recheck the same. There is enough space for the radiator - we had managed to mount it without issues. I did want to fit an AC, but given the delays so far, have de-prioritized it for now. Will take your suggestion to change the fan
The carb is Mikuni - is Hitachi better ? If yes, would it be available ? Hadnt checked on the tie-rod - will do that as well and post back
On your point with respect to stocking the parts - a very valuable learning. Though have not started thinking on my next project, it is something that I will definitely incorporate
vgopk is offline   Reply With Quote
Old 10th October 2016, 17:58   #107
autocrat's Avatar
Thanked: 538 Times
IIRC, Behram Sir had mentioned that its not a good idea to put an AC in these cars as the engine has only 3 main bearings and it will cause overloading and premature wear.
autocrat is offline   Reply With Quote
Old 11th October 2016, 21:47   #108
Autocrat - is that the case for an 118NE engine as well (I have replaced the original engine and gearbox with that of 118NE) ?
Old 12th October 2016, 09:01   #109
ilangop's Avatar
Thanked: 586 Times
Gautham, 118 (N)issan (E)ngine is a 5 bearing engine. So loading it with an AC compressor is not a problem. Vgopk has to just take care of the space available between fan and the front grill and optimally adapt a condenser and a slim radiator.
ilangop is offline   (1) Thanks Reply With Quote
My 1956 Fiat Millecento - A learning experience! Jai3033 Post-War 53 11th September 2016 18:06
My 1956 Fiat Millecento Restoration beetle_boy Post-War 78 1st October 2015 14:01
Restoration of MTP 8389 a 1956 Fiat 1100 the mole Post-War 323 14th March 2015 19:04
My 1956 Fiat Millecento Restoration Project spike Post-War 51 24th September 2013 14:28
1956 Fiat Millecento restoration and overhaul eternalck Post-War 11 17th January 2010 21:10
