Old 16th May 2010, 22:50   #106
funkykar's Avatar
Thanked: 1,726 Times
This is excellent progress. Do the folk over there work full time on your restoration or attend others too? Looks like they are dedicated to your car which feels good.
Yes, its good to finish troubleshooting fully before the head is removed.
funkykar is offline   Reply With Quote
Old 18th May 2010, 11:13   #107
Thanked: 39 Times
[quote=funkykar;1888778]This is excellent progress. Do the folk over there work full time on your restoration or attend others too? Looks like they are dedicated to your car which feels good.
There is only one mech who is working on my car that too as and when he gets time.These kind of restorations can take a lot of time as the parts are generally not available off the shelf that was the reason I didnt push the mech to work for me exclusively.
I managed to get a set of Engine packings including gaskit plus a set of size 10 piston rings. The shopkeeper says its better to put size 10 rings as the bore might already be bigger in the middle so the rings will fit well.Is it true? or should I go in for standard size rings?
damasthebiker is offline   Reply With Quote
Old 18th May 2010, 13:56   #108
IndrojitSircar's Avatar
Thanked: 113 Times
I think if the engine need to be done you either get oversize 0.10 pistons and rings or you keep to standard size.Now you need to open up the egnine and take the pistons and get them checked at the local machine shop wheather they can be reused or not. If they can be and you need to bore your engine then you go for new rings and just ask him to reseleave the block to standard size.But then you need to get a new set of rings for that.
Old 18th May 2010, 16:03   #109
Thanked: 39 Times
thanks for the advice Indrojit Ji. I have finally decided what you have suggested - I will go in for a change of rings - my mech checked and informed me that the pistons are in good shape and can be reused without any problem he said only new standard size rings will do the trick to get back the engine in shape and in the worst case we can resleeve the block.
Old 18th May 2010, 16:27   #110
Thanked: 113 Times
My advice to you would be get the pistons checked by a speialist and then if they can be used then i think you should go ahead with the resleeving of the block, this would last for a longer period then just changing the rings. What is the condition of the bearings and the valves ? You could consider changing the valves and the valve guides as well. At the end you would get a roaring engine .
Old 19th May 2010, 00:03   #111
manishalive's Avatar
Thanked: 699 Times
You can check for valve sealing on the seat, if the valves seem to be in good condition.
on bigger engine's (50Liters) with individual head, we supply compressed air from the inlet / exhaust manifold hole and then immerse the whole head in water to observe any leaks in valve seating.
If leaks are present there, we nead to lap the seat by the paste, bigger engines we have seat inserts to male our job easy .
manishalive is online now   Reply With Quote
Old 19th May 2010, 22:49   #112
funkykar's Avatar
Any progress on the engine work yet? Do post pictures of the pistons and rings.
Old 23rd May 2010, 01:44   #113
Thanked: 113 Times
So did you get the standard size rings ? What is the status of the work on the engine and the other mechanicals ?
Old 23rd May 2010, 18:03   #114
Thanked: 39 Times
In the last couple of days we could manage to fix the brake pipelines and get the head fixed(valve setting and grinding) its just today that we have completely opened the engine. The Head of the pistons were cleaned and thus we found that the piston read "030" so I assume that the pistons are 30 oversize. The matching 30 size rings are not available at places I know so I have ordered them with local ring maker in Agra(Agra is one of the biggest place in India where they produce Pistons and rings - for almost all the cars these guys even export them to various western countries). I am hopefull that by tomorrow I should get the rings.
I shall uploads pics early tomorrow morning.
Old 25th May 2010, 09:08   #115
Thanked: 39 Times
Here are the pics as promised. Head has been done up. Brake pipelines are fixed.
Still on a lookout for rings of size 030(though I have ordered them) If someone has size 030 rings to spare it would be really great.
damasthebiker is offline   (1) Thanks Reply With Quote
Old 26th May 2010, 00:03   #116
Thanked: 113 Times
Now that looks like some good work done. Just waiting to see the engine started up.
Old 26th May 2010, 00:37   #117
chanu's Avatar
Thanked: 140 Times
Default Lightning Fast
The best part of this car resto/thread is the way thing are done (clean and neat) and apart from that everytime you check there is something new and better happening on the car. I am glued to this thread and last but not the least my signature dialouge " all the very best of good luck".
chanu is offline   Reply With Quote
Old 26th May 2010, 09:56   #118
Stanher's Avatar
Thanked: 1,539 Times
Sorry for the silence on my side, been busy with my exams.
BTW, wouldnt it be good to get the engine block also painted, especially now that it's out? A red like you've used on the front srpings will look good, considering the car too is a red one.
Stanher is offline   Reply With Quote
Old 26th May 2010, 10:14   #119
Thanked: 39 Times
Definately, it will be done I was not considering red for the engine colour but since you have suggested it I find it quite a good idea - lets paint the engine red.
What about tappet cover and head - Black or Silver?
Last edited by Technocrat : 26th May 2010 at 19:55. Reason: Please avoid posting the entire text in bold, thanks
Old 26th May 2010, 11:21   #120
Stanher's Avatar
Definitely black is a better choice!
Stanher is offline   (1) Thanks Reply With Quote
1967 MK1 Standard Herald-Restored PAVAN KADAM Post-War 187 26th July 2011 19:22
Standard Herald wanted R32_GTR Shifting gears 31 14th October 2009 11:22
Looking for Standard Herald Pune_Bike Post-War 27 6th March 2008 02:42
MK 1 Standard herald engine / gearbox for sale R32_GTR Shifting gears 3 27th October 2007 11:22
