Old 11th June 2010, 11:47   #106
Thanked: 178 Times
Originally Posted by srisha View Post
Yes, the ignitiion assembly which is mounted on the steering column, not sure if it comes with a steering lock as well. Never the less, I shall take it if you want to give it away.
Does it have a key with VW logo and with complete wiring as well?
Srisha
Yes it does along with the ignition switch. Do send me your pics if any just to make sure we are on the same page.
67Bug is offline   Reply With Quote
Old 11th June 2010, 12:55   #107
srisha's Avatar
Here is a picture from wolfsburgwest website, let me know if it is similar and do you have a pix you can send? When you said original, is it also a common lock for the door? The 1966 one came with a common key for the ignition and the doors.
Thx
Srisha
srisha is offline   Reply With Quote
Old 11th June 2010, 14:23   #108
Thanked: 178 Times
Thx
Srisha
What I meant was this....I think I have what you have shown in the picture. No it has separte keys. Your current door keys will continue to hold good and the switch will operate from separte keys.
Old 11th June 2010, 15:19   #109
Thanked: 931 Times
pre67 models did not have steering lock facility and if my info is correct it did not have column mounted ignition switch also(not absolutely sure).
also as srisha said the doors and ignition had the same keys with profiles like K,SU etc.
The original Steering column assembly pictures are attached here
ajay99 is offline   Reply With Quote
Old 11th June 2010, 15:25   #110
Thanked: 931 Times
I think what srisha is looking for and is the correct for his model bug is this part no Volkswagen Part # 111 905 803 D. which Has both VW and Manufacturers Logos on Switch
Old 11th June 2010, 16:38   #111
srisha's Avatar
Yes, Ajay is right. The 66 ones came with dashboard mounted ignition. They were not mounted on the steering column, i just read online and saw some dashboard pictures of 66 model and they had them on the dashboard.
Old 25th June 2010, 16:06   #112
srisha's Avatar
Default Rear windshield sourced
Finally sourced the rear windshield for my beetle, this one came off from the one zozimo had posted some time back. Picked up a lot of spares from that beetel.
Here are the pictures of the windshield, and I must admit that the packing was done really well,
This will be fitted post all the other accessories i sourced from Singapore.
Old 25th June 2010, 16:55   #113
Thanked: 931 Times
is the windshield made by SEKURIT or SPLINTEX?
does it have VW logo?
Old 25th June 2010, 18:10   #114
srisha's Avatar
unfortunately, nothing is mentioned on the windshield. No logo nor manufacturer information.
Old 25th June 2010, 18:49   #115
Thanked: 931 Times
Then most likely it will be a Repro
hope you paid only the price of a repro windshield for it
Old 25th June 2010, 22:31   #116
Thanked: 178 Times
It most likely is a repro in that case. Else SEKURIT should be mentioned on it. Any reason why you wanted to buy one as I believe there is one on your car isn't it?
Old 25th June 2010, 23:09   #117
After all the touchups, the car would really look a beauty Classic Drive. Congrats for your great B'day gift. Hope you get it cleaned up sooner than later.
Subaro123 is offline   Reply With Quote
Old 25th June 2010, 23:42   #118
Stanher's Avatar
Thanked: 1,539 Times
The one on his car happened to be not a glass but a PLASTIC sheet cut out in the shape of the windscreen and fitted on. It was mentioned earlier in this thread too. Which is why he went for this glass.
Stanher is offline   Reply With Quote
Old 26th June 2010, 00:26   #119
Thanked: 2,459 Times
Correct shyam,
It had a fibre glass sheet. We paid almost 8K to get the glass from Goa.
Present updates.
1) Engine is down
2) Gearbox down
3) New gearbox mounts replaced
4) New engine mounts replaced
5) Carb split open for an ovehaul
6) Bowden cable installed
Pending work to be done soon.
1) Drawing some fuel lines which are only rubber pipes
2) New door handles with keys to lock the door getting installed
3) Rear right brake leaking, need to replace the cylinder kits
4) Gravel guards to be installed
5) Seat mountings to be checked
6) Rear tail lights mounting to be completed
7) Rear windshield glass to be fixed.
With lot of other restorations around, its becoming a tight rope walk for me right now.
Old 2nd July 2010, 11:40   #120
Default Overhauling the VW Carb, with Brosol Rebuild kit
Whenever it comes to Carbs, i make sure, i do it myself.
Since getting these kits are damn tough, you cant do anything if the Mechanic screws up
So i start rebuilding the 30 PICT-2 carb for Srisha's car.
Basically this car should have a 28 PICT carb, but that carb was in a bad shape, and i had transplanted the 30 PICT one way back during restoration.
The carb was fine, but was actually a bit sluggish, and few drops of fuel use to drip from the Venturi spindle, which by VW standards is Worst.
Would not talk much, let the pics do all the talking.
The perfect Father's day present - A couple of laps at the green hell jai-uno-t Travelogues 5 23rd June 2012 15:47
Websites of Indian Car and Bike Manufacturers (Past/Present/Future) devarshi84 The Indian Car Scene 28 7th August 2010 10:29
1967 Volkswagen Beetle-Build your own paper beetle Naren4140 Shifting gears 4 5th December 2009 05:16
Best Looking WRC Car (past and present) Tom Int'l Motorsport 45 3rd February 2009 01:28
Honda's VTEC Technology: Past, Present and Future nitroxx Technical Stuff 3 17th December 2005 19:39
