| LinkBack | Thread Tools | Search this Thread |
| | #226 |
| Senior - BHPian Join Date: Apr 2009 Location: Bangalore
Thanked: 228 Times
| I think if we reduce the pressure of the compressed air the velocity of the media is reduced and then glass beads can be used to acheive the desired results without destroying the chassis. But then no ventor will be ready to do that. |
| | #227 |
| Senior - BHPian Join Date: Jan 2009 Location: Abu Dhabi (for now)
Thanked: 188 Times
| Simply put you need to get a new chassis then. TAIF You might not see the rust very clearly but trust me its there and Pavan know too. Its gonna be a nightmare to get that chassis rust free. The first places the rust will erupt in are the welds where new metal has been grafted on Been there and done that so I speak with experience Last edited by wasif : 4th January 2011 at 22:03. |
| | #228 | |
| Senior - BHPian | Quote:
| | #229 | |
Thanked: 188 Times
| Quote:
Not sure if it is availabel in India, you guys live in India so you might know better. It does work well though and will not take away any metal from the chassis. usually items are media blasted to ensure that all surface rust / paint etc is completely removed and then dipped to seal the said item from rust. This is one of the reasons the restored cars last much longer in the west as the basic issues of reust are addressed in fitting manner. Now in India when you patch a rusted area what happens is sooner or later the rust starts up again around the welds and even the edges of the patch. | |
| | #230 |
| Distinguished - BHPian ![]() Join Date: Nov 2008 Location: Mumbai
Thanked: 1,091 Times
| Hi! Are you serious? This is a wonderful sentence for forwards .Topolino chassis may be thin, but they are engineered to survive. But now you have to check if you have lost any metal, then the chassis becomes weak. Thin and weak are different situations. In the very first car which we restored and was partially hands-on, we scraped down the chassis and then used a hand drill with a steel brush to clean the chassis properly. But sandblasting and dipping in a tank like galvanising would work better. BTW, how is the engine? Cheers harit |
| | #231 | |
Thanked: 228 Times
| Quote:
Chemical dipping is prefered when we have delicate parts which might get damaged by the media (from blasting). How ever much also depends on the Guy doing chemical dipping, too much of dipping can also eat away the metal. Chemical dipping will go to every nook and crany of the component or part, which is a good thing. As far as I am aware that much big tank is not available in India to carry out dipping of the whole body. Chrome platers also do chemical dipping before chrome plating and many times to scrap old paint the same acid is applied by brush over the body by local painters. | |
| | #232 | |
| | #233 | |
Thanked: 228 Times
| Quote:
Also phosphoric acid is also said to be a good agent. HCL is faster of the two. Last edited by manishalive : 5th January 2011 at 11:41. | |
| | #234 | |
| Senior - BHPian Join Date: Jan 2007 Location: NAMMA BENGALURU
Thanked: 1,094 Times
| Quote:
![]() We have given it a nice 2 coats of 3M antirust coating , initially i needed the Wurth guys to do it, but they have been giving me nightmares with their timings since 3 days. 3M is a rubberised compound and coats the surface neatly .Some pics | |
| | #235 |
Thanked: 228 Times
| | #236 |
Thanked: 188 Times
| guys like you and Pavan with the knowledge you possess should take the plunge and get started in ofering these services in India |
| | #237 | |
| Quote:
![]() Some more pics on the chassis. As on today evening, the work on the Chassis is DONE.........! ![]() Lot of detailing has gone into the making of this chassis, Rust proof, Well detailed and as straight and square as possible. Tomorrow onwards work on the underbody of the shell will start. I hope the commitment levels of the team remains same. | |
| | #238 |
Thanked: 228 Times
| You have a good point, at one point of time I dreamt of a resotration shop (I even met Manvender Singh at an age of 16 to work with him). Now I work for a different Industry. |
| | #239 |
Thanked: 188 Times
| Chassis looking good Pavan. Seriously guys ....why not look inot offering such facilities and others like hi class paintwork and chroming under one roof....surely a recipe for success |
| | #240 | ||
| Quote:
ENGINE..................! all i can say is " Its running fine right now sir" ![]() I dont know, what ghosts come out once its mounted on the car. Quote:
Sirjee, in such case, i need to start charging fees for all my restorations. and make it a Business. In which case, i will loose my passion and become a pucca Business man.And i dont want to do that. | ||
Similar Threads | ||||
| 1950 Morris Minor-Convertible Restoration- Get set Go... | PAVAN KADAM | Post-War | 101 | 24th March 2013 11:46 |
| Restoration of a NOMAD's 1954 Fiat Millecento- DELIVERED | PAVAN KADAM | Post-War | 117 | 15th March 2013 13:58 |
| A 1934 Fiat & other Pre-1950 Fiats | GTO | Pre-War | 89 | 20th September 2011 22:10 |
| New SuperSmall FIAT TOPOLINO | Cyrus43 | The International Automotive Scene | 13 | 26th July 2008 01:23 |
| 1936 Fiat 500 A Topolino | nevertouchme | Pre-War | 9 | 9th July 2007 15:16 |
