Old 3rd February 2011, 23:01   #61
Thanked: 26 Times
Default Re: My 1961 Volkswagen Beetle,restoration project
I got my 15" white wall tyres from Chennai,was some old stock, can check if they have tyres if you are interested.The MRF tyre Mangalore office was also expecting some stock of these tyres when i spoke to them late December.
brat001 is offline   Reply With Quote
Old 4th February 2011, 19:05   #62
mbz180's Avatar
Thanked: 543 Times
Please ask them if they have five 6.40 x 13 whitewalls for my Ponton.
Prithvi
mbz180 is offline   Reply With Quote
Old 5th February 2011, 11:38   #63
inderpalgill's Avatar
Thanked: 34 Times
Prithvi
hi, i got one set of 165 r 14 hankook tyres with one inch white line for my 71 benz,they look pretty and a good to drive too, and that fellow had the 13 inch set too, do let me know if you opt for radials with white band
inderpalgill is offline   Reply With Quote
Old 5th February 2011, 20:01   #64
mbz180's Avatar
Thanked: 543 Times
The correct radial size for my car is 185/80R13 but I need with wide whitewalls, atleast 2 inches.
Prithvi
Old 7th February 2011, 11:44   #65
Thanked: 34 Times
Prithvi
hi, i think you must go for Firestone ,they are available freely but are on the higher budget,look great
Old 7th February 2011, 11:48   #66
Thanked: 34 Times
yes please do me a favour and contact them if they have 2 inch wide 15" tyres,this will be a help
Old 7th February 2011, 20:14   #67
mbz180's Avatar
Thanked: 543 Times
Pls let me know which Firestone tyres you're talking about.
Old 8th February 2011, 12:31   #68
Thanked: 34 Times
white wall firestone tyres are available in delhi and bangalore (may be other towns but i know just 2) and are beautiful and full wall is white
Old 8th February 2011, 12:32   #69
Thanked: 34 Times
hi, i have a strange problem in my 61 beetle since i bought her,when i start the car in the morning or after a approx 24 hours the gears do not shift i mean do not engange and the lever remains stiff,but after 10-15 mts of idling it shifts but too hard, and after a running of around 10 mts the gears shift very normal and soft,what should be the cause and what remedy be adopted
Old 8th February 2011, 16:33   #70
mbz180's Avatar
Thanked: 543 Times
I'm thinking maybe you need to replace the Gear lever kit? Doesn't sound like a clutch plate or pressure plate problem to me. Alternatively, adjust the clutch settings. Should help.
Prithvi
Old 8th February 2011, 17:29   #71
Thanked: 34 Times
Prithvi
even i think the same but what may be the reason that the shifting becomes smooth as the car warms up?
Old 8th February 2011, 18:07   #72
Thanked: 69 Times
gear oil becoming less viscous with the heat?
kevinephraim is offline   Reply With Quote
Old 8th February 2011, 18:40   #73
Thanked: 178 Times
I have feeling there is a problem with the Gear Syncromesh. As the car starts and runs the transmission oil runs and lubricates the syncromesh and helps in connecting the gear teeth. I could be wrong but had a similar problem with my Bus and had to change the syncromesh and now the gear engage very smoothly.
67Bug is offline   Reply With Quote
Old 8th February 2011, 22:29   #74
Thanked: 2,460 Times
The problem is with your loading plate and releaser bearing.
Beetles starting from 1960 - 1964 came with a different kind of loading plate and releaser bearing. They were referred as "FIXED CARBON TYPE"
Change them to the correct type " Aalll izzz Wellll.........."
Old 9th February 2011, 11:42   #75
Thanked: 34 Times
yes the release bearing is carbon type, and is new,should i replace it with the late model one and pls elaborate the "loading plate" do you mean the plate below the shifter or what ,pls suggest.
1961 Italian Fiat 1100/D Special. A Restoration Project. V-16 Post-War 426 17th August 2016 19:08
My 1966 VW Beetle! A new restoration project SA7VA5 Post-War 61 19th January 2015 15:48
1961 VW Beetle Restoration PAVAN KADAM Post-War 59 3rd June 2012 00:19
1967 Volkswagen Beetle-Build your own paper beetle Naren4140 Shifting gears 4 5th December 2009 05:16
