Old 6th April 2011, 21:42   #46
jgsolo27's Avatar
Thanked: 11 Times
Default Re: My Pride - 1946 Chrysler Windsor
Jai!
Excellent work. Pl. post more pics. Would love to drop in just to have a look! Hope your beauty may participate in the next Vintage Car Rally between Chennai and Puducherry!
Solo
jgsolo27 is offline   Reply With Quote
Old 14th April 2011, 18:09   #47
absoluteyogi's Avatar
Jai,
Excellent job. I am absolutely in love with the paint job done on this car. Also, I would love to see it in motion, can you post some video of this baby moving on the road?
Cheers,
absoluteyogi is offline   Reply With Quote
Old 15th April 2011, 10:19   #48
ravi_xx's Avatar
Thanked: 27 Times
Fabulous job mate. Am sure the previous owner is waiting impatiently to do the temple drive. Good on you.
Ravi
ravi_xx is offline   Reply With Quote
Old 23rd December 2011, 20:03   #49
Thanked: 1,926 Times
Originally Posted by Jai3033
Here are the post restoration pics taken at a rally held in Chennai last month.
Nice shade may I know how you came across this. Wonderful result
Last edited by karlosdeville : 24th January 2012 at 16:20. Reason: Removing entire quote
kasli is offline   Reply With Quote
Old 24th January 2012, 13:43   #50
MercLover's Avatar
Excellent car and fine restoration. Just loved the shades pretty much. Would you mind please us with some more pictures of interiors.
MercLover is offline   Reply With Quote
Old 24th October 2013, 11:00   #51
KPS
KPS's Avatar
Thanked: 5,394 Times
An article had appear in The Hindu(1st July'13) on this car and the brothers Sri & Jai
http://www.thehindu.com/news/cities/...cle4862779.ece
Photo credit to the article published by The Hindu
KPS
KPS is online now   (8) Thanks Reply With Quote
Old 25th October 2013, 04:03   #52
Thanked: 100 Times
Originally Posted by KPS View Post
An article had appear in The Hindu(1st July'13) on this car and the brothers Sri & Jai http://www.thehindu.com/news/cities/...cle4862779.ece Photo credit to the article published by The Hindu Cheers KPS
Congratulations on completion of restoration of this nice car. I have followed the rebuild process earlier reported on these pages and even enquired about the
grill . It seems all problems have been solved and the car is on the road. I do recall that there was some problem rebuilding the transmission and the operation of
the fluid drive. Please enlighten us how that was solved and if the gears are shifting normally now without the engine revving too high and causing overheating.
This has indeed been a labor of love and you are to be praised for bringing this project to a successful completion.
priyo is offline   Reply With Quote
Old 30th October 2013, 21:35   #53
FINTAIL's Avatar
Thanked: 1,116 Times
Yes! Even I am quite interested so as to know how the Fluid Drive system set working.
I presume the Fluid Drive system was mechanical?
Lastly, how many Carburettors does the car run on? What make are they? Carter, I presume.
Cheers!
Fintail/Heckflosse!
FINTAIL is offline   Reply With Quote
Old 30th October 2013, 22:42   #54
Thanked: 100 Times
Chrysler Windsor came with a basic L-head 6 with a single Carburetor . Only the New Yorker came with a L-head 8 . Fluid drive was a semi-automatic in that you did not have to depress clutch each time you up-shifted or down-shifted. Only time you needed the clutch was from N to first . Remember these were three speed transmissions. The Fluid drive used a complex system of electrical and mechanical components and was not as easy to fix as a normal gear box. A photo of 1948 Chrysler New Yorker with the straight 8 two dr. coupe was found on Flipboard - isn't she a beauty ?
priyo is offline   (1) Thanks Reply With Quote
Old 31st October 2013, 07:47   #55
KPS
KPS's Avatar
Cheers!
Fintail/Heckflosse!
Here are the details of the fluid drive system
http://www.team-bhp.com/forum/vintag...ml#post2547798 (Automobile Technologies of the Past - A Revisit)
There is only one carb, Carter of course
KPS
KPS is online now   (1) Thanks Reply With Quote
Old 31st October 2013, 13:14   #56
karlosdeville's Avatar
Thanked: 8,922 Times
Originally Posted by priyo View Post
Chrysler Windsor came with a basic L-head 6 with a single Carburetor . Only the New Yorker came with a L-head 8.
The side valve 6 cyl was shared with many other Dodge, Plymouth and DeSoto cars I think, right up to 1957, though I think with varied power outputs.
I remember the head having bold SPITFIRE lettering on a friend's Windsor - though never saw it on later cars.
karlosdeville is offline   Reply With Quote
Old 31st October 2013, 13:43   #57
Thanked: 944 Times
Priyo,
I have owned/driven these cars, all had four forward, one reverse speed transmissions. You manually shift the lever upwards for selection of low( first gear), then depress the accelerator pedal when a seamless shift into second would happen, then manually shift the lever down for selection of high( third gear ) accelerate, then ease off, to again seamless shift to the fourth gear. If in either low or high you wanted to downshift say whilst overtaking, you floored the pedal which in turn manually activated an electical switch on the carb, which enabled the change. At times the switch on the carb malfunctioned, so I had a push button switch installed on the dash to enable the kickdown shift
The set of solenoids if in order , made this type of gear system easy to drive.
Fluid drive was in addition to this type of semi automatic transmissions. Some fluid drive models came with standard ( manual ) three forward, one reverse transmissions , but the semi automatics that I have over the years seen, have always had FOUR forward speeds.
Bulldogji is offline   (4) Thanks Reply With Quote
Old 9th November 2013, 15:33   #58
KPS
KPS's Avatar
Here is proof of SPITFIRE, as seen in our car
KPS
KPS is online now   (2) Thanks Reply With Quote
Old 9th November 2013, 17:46   #59
harit's Avatar
Thanked: 2,876 Times
I am a bit puzzled about the engines in 1947 Chrysler (Dodge, DeSoto and Chrysler) cars. There are 8 cylinder engines, no problem for those. But there may be two types of 6 cylinder engines, Spitfire and non-Spitfire? If I remember correctly, the DeSoto which I saw had a regular engine, a 7-seater which I saw has a Spitfire engine. Any comments?
Cheers harit
harit is offline   Reply With Quote
Old 10th November 2013, 11:14   #60
Thanked: 100 Times
Originally Posted by harit View Post
I am a bit puzzled about the engines in 1947 Chrysler (Dodge, DeSoto and Chrysler) cars. There are 8 cylinder engines, no problem for those. But there may be two types of 6 cylinder engines, Spitfire and non-Spitfire? If I remember correctly, the DeSoto which I saw had a regular engine, a 7-seater which I saw has a Spitfire engine. Any comments? Cheers harit
Hullo Harit :
Some research on Chrysler engines resulted in a site that has so much information and photos that it is worth sharing . It also has a photo of the spitfire engine you mentioned.
http://www.allpar.com/mopar/flat.html
1946-1948 Chrysler pilotcarl Post-War 37 24th March 2018 08:56
Tata Aria Pride - Zero Pride in Ownership indian21r Test-Drives & Initial Ownership Reports 283 6th March 2014 13:30
Fiat & Chrysler in partnership talks! EDIT: Fiat completes Chrysler buyout madan80 The International Automotive Scene 61 30th January 2014 15:43
Chrysler in Deep trouble. Daimler-Chrysler Divorce? GTO The International Automotive Scene 21 5th April 2007 16:28
