Go Back   Team-BHP > BHP India > Vintage Cars & Classics in India > Pre-War
Old 12th September 2011, 21:12   #16
V-16's Avatar
Thanked: 862 Times
Default Re: Willy's Knight in India
This looks like a Roadster to me, maybe even a sports roadster, owing to the peculiar shape of the headlamps. It is a 1923-26 but more so 1925-26 because of the wheel design and the hood ornament cum radiator cap, not to mention the triple horizontal strip bumper.
Im guessing its a 1926 model 66 roadster.
This type of hood ornament with the Knight in his helmet with two horizontal bars is called "Knight on the dog bone"
This is a rare find and please let us know whatever history you can find about the car. May i add that its very very well preserved and that is a very welcome sight.
V-16 is offline   Reply With Quote
Old 13th September 2011, 08:59   #17
Thanked: 1,926 Times
The center knob or pedal could be a starter and the bottom flat one could be the accelerator.
Some clearer snaps of the body and sides and rear if possible. which part of the country is this car ?
Originally Posted by .sushilkumar View Post
Dear wasif Sir
There are two point circled in below picture. you mean that one of them is accelerator ( off course pedal is missing ) than what;s the use of other one. I remember me and dad tried to move both and one was connected to accelerator but i not sure for what other one was . we both were not able to trace it ..
I have no idea when the car run last . most probabaly she is lying like that for 10 + yrs now . excellent thing is that she is stored properly and jawans make sure that she is well taken care of .
On a separate Note :
- any ideas where can i find the chasis no / info sheet on this car. usually cars from that era come with a metal plate riveted to the chassis . if i can find out that info , most probably we can find out the actual history of the car.
Attachment 608086
kasli is offline   (1) Thanks Reply With Quote
Old 13th September 2011, 10:52   #18
wasif's Avatar
Thanked: 373 Times
That car looks more like a four door Tourer to me.
Kasli....The center knob is actually the accelerator and that bracket below it is where you rest your heel when you are driving.
Your toes press the knob to accelerate the car.
I think it is a 1927 Model 66 A as the air intake and the head light surrounds point to it being a 66 Series
Here is a link to the WORK Club showing the Sleeve valve engine in detail
http://clubs.hemmings.com/clubsites/...ery/wk_78c.htm
Here is the link to the club home page, you should sign up with them and get them to guide you on where to find the engine / chassis number and once you have them maybe the club can help you get the early history of the car.
http://clubs.hemmings.com/clubsites/wokr/index.cfm
wasif is offline   (1) Thanks Reply With Quote
Old 13th September 2011, 16:48   #19
mbz180's Avatar
Thanked: 584 Times
What a rare find and that too in original well preserved condition. Yes, Daimler's and Minerva's too used sleeve valve engines; Daimler till a certain point and I think Minerva right till the end.
I have read in books that sleeve valve engines were far smoother than conventional poppet valve engines in use at the time, though the former consumed much more engine oil and left a trace of blue smoke from the exhaust as the car went along
Prithvi
mbz180 is offline   Reply With Quote
Old 14th September 2011, 11:12   #20
wasif's Avatar
Thanked: 373 Times
The Willys Knight Regestry feels its a 25 to 26 66 Series Willys Knight.
Those triangular headlamp surrounds are peculiar to the Model 66 and 66A only.
The actual year can only be confirmed once the Chassis / Engine numbers are found.
I am trying to get them to advice where to look for the numbers.
The chassis number starts with the model number so it should read 66 - or 66A -
The model 70 had just a 113.25 inch wheelbase whereas the 66 had a 126 inch wheelbase so it's a bigger vehicle.
The chassis number identifying chart is on this link below
[COLOR=#810081]www.wokr.org/gallery/WK_HIST.HTM[/COLOR]
wasif is offline   Reply With Quote
Old 14th September 2011, 18:19   #21
wasif's Avatar
Thanked: 373 Times
The car is most definitely a 1926 Model 66.
The ngine number would be on a small plate attached to teh lower crankcase just left of the carburetor. If teh plate is missing there will be four small holes showing where it was mounted and if you gently scrape teh paint between the holes teh number will be found stamped into the metal as well.
The chassis number can be found on the following places.
1. A small aluminum tag 3/4" tall by 1 1/2" long should be behind the left front wheel attached to the chassis.
2. Second tag should be found attached on top of the right rear frame rail about 12" up from the spring hanger.
3 Third plate should be attached to the seat frame under the the front or rear seat cushions.
I a sure you should be able to find atleast one of the chassis plates so please have a look and lt us know what engine / chassis numer turns up !
Happy hunting !
Old 15th September 2011, 02:54   #22
V-16's Avatar
Thanked: 862 Times
Thanks for confirming my doubts Wasif. Its comforting to know my years at looking for the rare oddity here and there weren't wasted
It would be interesting to know what cars came with the triple strip bumper at that era. Surely there must be something.
Old 15th September 2011, 05:11   #23
vivekgk's Avatar
Thanked: 433 Times
I think the throttle is in the steering wheel itself. Cars of similar vintage often had such controls. If you look at the picture, there are two slider controls on the steering wheel, one for ignition advance/retard, and another that's labeled open/close. My guess is that this is the accelerator.
vivekgk is offline   Reply With Quote
Old 15th September 2011, 09:55   #24
wasif's Avatar
Thanked: 373 Times
Cars of this period always had two ways to accelerate, the standard or normal way was with the foot accelerator pedal (which in this period was always between the cluth and brake pedals) and once on the move you could use the hand lever to set the speed after which you could lift your foot off the actual accelerator pedal.
It ca be considered as an early form of cruise control.
The reason these cars featured an accelerator lever on the steerings is thant most of them would need to be had cranked to start and if you were alone it would be a nightmare to simultanously crank the car and hit the gas pedal so you set the lever to open the throttle a little bit and then cranked the car to start it.
V 16 ....your knowledge is encyclopedic .....will try to see what I can turn up on those bumpers !
Old 15th September 2011, 11:30   #25
manishalive's Avatar
Thanked: 734 Times
Nice info there, my fiat also have a similar function pull knob on the centre of the dashboard, the early form of cruise control.
Old 15th September 2011, 21:46   #26
Thanked: 219 Times
Apologies for being off this thread gents. works taking it;s toll . posting some more Pics.Nice to get some Knowledge about this Beauty.
few more pictures of the engine bay , a closer look at the Tyre. definitely not original but can some body identify that trade mark in second picture and last one is the Back Side. it;s a 2 door .
Last edited by .sushilkumar : 15th September 2011 at 21:52. Reason: added comments
.sushilkumar is offline   (1) Thanks Reply With Quote
Old 5th October 2011, 16:32   #27
Thanked: 15 Times
Interesting Thread and Iteresting Find. Would love to know the status of the vehicle as of now, and some more pictures if possible.
ab500 is offline   Reply With Quote
Old 13th March 2013, 07:32   #28
moralfibre's Avatar
Thanked: 6,533 Times
Here's how the advertised the Willys Knight back in the day:
moralfibre is offline   (2) Thanks Reply With Quote
Kaiser and Willy's randeep04 4x4 Vehicles 25 9th July 2014 11:37
Russian Uaz-469, Ford and a Willy's randeep04 4x4 Vehicles 77 6th May 2012 10:51
1945 Willy's? Is it original? How much is it worth? navial 4x4 Vehicles 11 4th January 2010 16:04
Suspension for Willy's jeep chiragh_bir Modifications & Accessories 3 11th September 2006 13:04
Willy's or Classic needed naveen.mathew SUVs, MUVs & 4x4s 13 30th June 2006 14:51
