Go Back   Team-BHP > BHP India > Vintage Cars & Classics in India > Pre-War
Old 7th November 2010, 14:05   #1
Thanked: 105 Times
Post A Grounds up job...restoring a rundown pre-war Morris
Hey Guys, A Little Help Required Here... Need To Retore This From The Grounds Up.... (Literally LOL!!)
Some Help In Sourcing the required Parts....??(( Or The Car????))
Micki9559 is offline   Reply With Quote
Old 7th November 2010, 14:52   #2
Thanked: 2,469 Times
Wow.
All i can say is "ALL THE BEST"
Looks like a herculean task, i got my Beetle in the same shape
You must have enough money and patience to restore this car . Do keep us posted
Old 7th November 2010, 14:55   #3
Thanked: 31 Times
Are you serious of this restoration?
What are those pics of motherboard for? Computerized restoration?
EARTHed is offline   Reply With Quote
Old 7th November 2010, 18:04   #4
vintagepoint5's Avatar
Thanked: 40 Times
Wow, it is not easy task, time, money and patience. BTW which car is this Morris 8 pre-38 or Ford Y also have similar front design. Where is the engine, gear ? do you have it or need to source it.
Good luck!
vintagepoint5 is offline   Reply With Quote
Old 7th November 2010, 18:13   #5
Thanked: 105 Times
Engine and Gearbox are very much there, and in great shape. Documents are also There.
Just a case of Gross neglect on the owner's part. It's a Pre-War Morris.
@ The mobo pics?? i dunno how they got there???
Old 7th November 2010, 18:18   #6
Thanked: 105 Times
@ mods? Please remove the Irrelevant Pics from the thread.
Old 8th November 2010, 09:38   #7
wasif's Avatar
Thanked: 372 Times
Micki.
Withall due respect I woudl suggest you leave that car alone.
Firstly its going to cost a bomb and even then you might not end up with a quality restored car as many small bits would have been lost over time and would not be availabe locally.
It could serve as a donor car for parts if youc an find a similar car that is in a better shape.
Its not that restoring thsi is not possible its just the costs wich will be probably more that twice the value of a fully restored carof similar age.
Think about it before you dive into it.
Alternately I would suggest using the body and chassis to turn it inot a hot rod. Way more cooler and much more fun
wasif is offline   Reply With Quote
Old 8th November 2010, 10:06   #8
Thanked: 3,768 Times
Originally Posted by wasif View Post
Micki.
+1 on that Wasif bhai.
I think you should drop of the idea of restoring this car and start looking for something better.
SILVERWOOD is offline   Reply With Quote
Old 8th November 2010, 10:54   #9
Thanked: 105 Times
Hey!! Thanx For Your Suggestions!! It's Not My cup of tea Either. But The Owner Insists that He wants it restored. So Plz Help Me out Guys.... PLzzz???
Old 8th November 2010, 10:58   #10
wasif's Avatar
Thanked: 372 Times
PM Replied to.
Firstly suggest you ask around if anyone has a parts manual and a workshop manual for this car and are willing to share. If not look on Amazon for them and only start once you have all the above and detailed pictures of similar cars to use as reference.
Old 13th November 2010, 00:02   #11
vintageman's Avatar
Thanked: 569 Times
Hello Micki 9559 ,
With the work involved in restoring this car , you have an interesting and involved restoration project on you hands.
Is the car being restored for sentimental or emotional reasons , if so , it will be wonderful project - to bring the car back to life.
From the photographs posted , the car seems to be missing the following body parts :
- grill
- bonnet
- roof
- mudguards
- floor
- bumbers
- seats
- trims , handles , frames
Understand the "Engine and Gearbox are very much there, and in great shape" , are these from a donor car ? because from the condition of the car it does not seem likely that the engine would be functional.
Does the engine have all the peripherals :
- radiator
- starter motor
- dynamo
- fuel pump
- shaft & couplings
- carbeurator
- distributor
- pulleys
- mountings
Has the engine been checked to ensure all internal parts - crankshaft , camshaft , guides , tappets , valves , connecting rods , seals , bearings , pistons etc are available inside the engine and the head / block is without damage ?
Further to above you will require the seats before upholstery work is undertaken.
Are you doing the restoration yourself or are you outsourcing to a garage
There should be reasonably priced Morris 8 available , which would cost less than the price of restoring this car ?
But if there are sentiments attached to this car , please go ahead with the project , it is doable and it will end on a most satisfying note.
vintageman is offline   Reply With Quote
Old 13th November 2010, 00:29   #12
Thanked: 105 Times
Originally Posted by vintageman View Post
Hello Micki 9559 ,
- grill
- bonnet
- roof
- mudguards
- floor
- bumbers
- seats
- radiator
- starter motor
- dynamo
- fuel pump
- shaft & couplings
- carbeurator
- distributor
- pulleys
- mountings
Hi vintageman!!!
I really do Appreciate your Help here.... let me give you the facts first.
The engine and gearbox had been removed from the car so they are in great shape as they had been stored inside a warehouse. will try to upload some pics soon.... and yes, i do need to source the rest of the parts that you mentioned. i'm getting it restored under my personal supervision from a well known garage in my town. so any other help regarding the parts and where i could source them from would be great!!!
And to answer your question, ya the car has some sentimental reasons to be resurrected from the current state.
Restoring Morris Minor 4x4forever Post-War 13 1st July 2011 23:43
Portion of Palace Grounds might be sold! speed kills Shifting gears 16 16th December 2008 23:44
Restoring a Morris khanak Technical Stuff 11 11th June 2008 16:13
Iron Maiden @ Bangalore Palace Grounds, March 17th zaphod Shifting gears 50 21st March 2007 16:52
