Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Product Discussions
Product Discussions Discuss the equipment that makes the ICE
Thread Tools
Old 31st August 2006, 17:49   #31 (permalink)
The pricing is almost same for most brands except Dynamat Extreme I think!
Old 1st September 2006, 00:42   #32 (permalink)
Ok Zak... more or less the same price for fonomat VS wurth...
At the time of your purchase
*What size do the wurth sheets come in ?? (b&t mentioned roughly 3ft * 1.5ft)
*Cost per sheet ?
Then we can make a comparison.
As mentioned earlier fonomat sheets are available in 10"x10" @ INR 220/-
__________________
No fate but what we make!
Old 1st September 2006, 01:03   #33 (permalink)
shrivz's Avatar
I remember EVO6 mentioning some material which is used for damping, i think it was Cross link foam if i'm not mistaken.. probably the gurus can shed some light on this.. and if im correct he said it was easily available, cheap and it does a pretty decent job..
cheers!
Shrivz...
__________________
Don't part with your illusions. When they are gone you may still exist, but you have ceased to live.
Mark Twain
shrivz is offline   Reply With Quote
Old 1st September 2006, 07:36   #34 (permalink)
cheers!
Shrivz...
Yes! true to a certain point.
Those are good for stopping vibrations, jarrings etc.. But it wont work good as for sound deadening\damping. Road noise will filter through and your music will be leaking out too.
Old 1st September 2006, 15:55   #35 (permalink)
zak chetta you skipped my post (The Damping Material and Sound Deadener Thread)!!!!
More info on this please... I tried searching the ICE section...
__________________
Old 20th March 2007, 11:57   #36 (permalink)
Default VFM Damping product ?
Hi folks,
I accidentally bumped in to this page where it says secondskin audio damping products fare better than other damping products I am a newbie and i have heard only about dynamat's and wruth.
Link to the article.
Sound Deadener Showdown
conculusion page here
Was wondering any body has real world experiences with this ? Was planning for some damping (a friend of mine coming from US..)
Thanks in advance..
Note from the Support Staff: Thread merged with existing.
Last edited by aah78 : 22nd August 2007 at 21:29. Reason: threads merged. note put up.
prashantk007 is offline   Reply With Quote
Old 20th March 2007, 13:23   #37 (permalink)
navin's Avatar
Originally Posted by prashantk007 View Post
Hi folks,
I accidentally bumped in to this page where it says secondskin audio damping products fare better than other damping products I am a newbie and i have heard only about dynamat's and wruth. Was wondering any body has real world experiences with this ? Was planning for some damping (a friend of mine coming from US..)..
Of what I have seen Dynamat Extreme is good. I have not tried Wurth or Fonomat and the regualr Dynamat is not much help.
I would love to see a cheaper but just as effective product than Extreme.
__________________
Scixelsyd Etinu
Old 20th March 2007, 13:48   #38 (permalink)
hydrashok's Avatar
I use Fonomat in my car and it does the job pretty well. I've sat in a car that had WURTH damping, and that did the job well too.
That was a really nice article! Thanks! Made for good reading.
If you plan to buy from the US, I'd say Dynamat Extreme would be the best choice. It is a little expensive, but it will definitely get the job done properly.
__________________
Alpine 9887 | TRU Tech STEEL S44 & S500 | Image Dynamics XS65 & CTX6 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 20th March 2007, 17:41   #39 (permalink)
yes i guess dynamat extreme should be a safe bet...The article was quite interesting for sure...thanks to google...
Old 20th March 2007, 18:31   #40 (permalink)
aZa
aZa's Avatar
Guys what bout "FATMAT" and "edead" ???
__________________
-[ " Objects in the mirror are loosing. " - Getz CRDi ]-
Old 20th March 2007, 18:36   #41 (permalink)
there are many damping products....buy that one which one can find easliy...or which one is the cheapest......
Old 20th March 2007, 18:42   #42 (permalink)
aZa
aZa's Avatar
LBM bhai how is edead ??? it sells for about 1$ per foot
__________________
Old 20th March 2007, 19:09   #43 (permalink)
like I said before these damping sheets majorly the same stuff...expect the few like dynamat extreme....so if you find them cheap and easily avalable then get it.....
anyways any link of edead.....
Old 20th March 2007, 23:42   #44 (permalink)
panky12345's Avatar
whatever u buy, be sure its 80 mils and not 50 mils.
__________________
No signatures..
Old 21st March 2007, 01:03   #45 (permalink)
50 mils is equal to 50 thou...and 1 thou is 1000 th of a inch it means that 1 thou = 25.4/1000=0.0254 mm...
50 mils = 50 thou = 1.27 mm
80 mils = 80 thou = 2.032 mm
so the sheet thicker than 2 mm is fine....
Thread Tools
Alternative material for damping amit_sound Ask the Gurus 159 10th August 2009 13:08
Sound Proofing material for car ezee Modifications & Accessories 19 24th June 2009 01:53
How effective is sound deadening material in tackling rattling ? swathyd Ask the Gurus 19 15th August 2008 21:15
sound proofing material query makanaka Product Discussions 3 11th August 2008 12:53
Regarding Hood Damping (Sound Proofing)? ezee Modifications & Accessories 10 18th July 2008 13:50
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
