Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Product Discussions
Product Discussions Discuss the equipment that makes the ICE
Thread Tools
Old 2nd June 2006, 21:05   #16 (permalink)
low_bass_makker's Avatar
the rms rating of the amp at 12 volts is not listed anywhere on the site. But it could be nearly 400-500 rms at 2 ohms at 12volts.
And the amerage I will Keep my mouth shut as I dont wanna start again.
__________________
156.6 db, naa....time is coming to cross it......
Old 2nd June 2006, 22:58   #17 (permalink)
panky12345's Avatar
thanx LBM....2 things plz if u can help me again:
1. did u experience ANY trouble with ur set-up as far as amperage goes?
2. wat wd be, according to you, wd be the current drawn by a) Pioneer GM-6100F b) the amp in question (650)?
__________________
SINGH IS KINNNNNNNG..
Old 2nd June 2006, 23:38   #18 (permalink)
Yes man the voltage drop is still there like i play the system for 15 min the voltage goes down to 13 volts and If i stop play or playing at low volume it returns back to 14.7 volts and I avoid playing at high volumes for long time. But till now every thing is ok report.
about the 6100 the current draw is max 35 amps and the average current in 4 channel 4 ohms mode ->9 amps. and in 2 channel 4 ohms mode is -> 15 amps.
And about the alpine I cannot comment as I dont have any info about the same to support.
__________________
Old 2nd June 2006, 23:52   #19 (permalink)
panky12345's Avatar
i dunno much, buy my cap always show a rating of 13.25 whenever i switch on the car (not system)....as soon as i switch on the system, it tends to be between 11-13 all the times.
BTW, thodi si light to dalo, what do U guess the amperage shd be? even if u have nothing to support ur claim. am not gonna hold u liable for anything yaar!
__________________
Old 3rd June 2006, 00:52   #20 (permalink)
There are many experts in this forum they can help u on this. BTW why do u need the amperage for ???????
__________________
Old 3rd June 2006, 00:59   #21 (permalink)
panky12345's Avatar
just to make sure that i need not upgrade my alternator/battery if i use both of these. TATA says my alternator is 75 amps.
__________________
Old 3rd June 2006, 01:07   #22 (permalink)
my swift is also 75 amps every thing is fine u can give it a go for sure.
__________________
Old 3rd June 2006, 10:02   #23 (permalink)
Team-BHP Moderator
navin's Avatar
Arrey LBM why be shy! :-)
The alternator delivers 75A. the battery can deliver more. Only the alternator will charge the battery at the rate of 75A.
500W amp at 2 ohms = 16A to the speaker. Assuming 50% efficiency the amp could draw as much as 30A from the battery. Remember this is not continous. Music is not a continous tone so at low levels the amp will put less amps etc...
Suffice to say that a 75A alternator and a good battery will easily power 2 or even 3 or 4 such amps.
__________________
Scixelsyd Etinu
Old 3rd June 2006, 10:21   #24 (permalink)
navin good battery = stinger or stock (exide) wd suffice? am in similar situation.
mercedes is offline   Reply With Quote
Old 3rd June 2006, 11:12   #25 (permalink)
Bass&Trouble's Avatar
Sorry to elbow Navin on this one, but stock batteries are ok unless you have a high power requirement. Actually, I am of the opinion that anyone with a decent car audio setup should have a battery capable of deep cycling. The current is cleaner and more stable in addition to the battery having a higher Amp-hour rate. Stock batteries are provided by the manufacturer with the sole purpose of providing power to crank the engine. Stinger is good, even the SP800 should do the job for a small to medium petrol car.
__________________
Operator! Give me the number for 911!
Thread Tools
Mono Amp Wanted Lifewater Shifting gears 10 4th October 2007 15:23
Polk MOMO Swift blueraven316 Sound Off and Show Off 44 13th August 2007 20:49
Polk Momo Demo Car blueraven316 Product Discussions 56 31st July 2007 07:36
Mono Amp somebodystopme Ask the Gurus 29 1st March 2007 22:20
HU Query for JBL speakers was "Polk MOMO vs db Compos" hyper-VTEC Product Discussions 43 13th December 2006 14:03
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
