Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Product Discussions
Product Discussions Discuss the equipment that makes the ICE
Thread Tools
Old 22nd May 2006, 12:38   #1 (permalink)
Default URGENT! amp question:sony xm 55fzr
hi guys,
i am in a super confused state, can some more-knowlegeable persons enlighten me??
i'm gonna put an audio setup on my swift vxi model:
HU: pio 6850 mp3 Rs.9k
front: jbl 6.5 components OR Jbl 6.5 triaxials (Rs.3950) + pioneer t520 (or ts20?) tweeters (the tweeters are oval-ish)
rear: jbl 6.5 triaxials OR jbl ovals (Rs.4200) ??
sub: pioneer 400watts RMS 1000w max. (Rs.3650)
amp: sony xm 55fzr (Rs. 4950)
amp specs are: Rated Output Power:
4 Ch x55W at 4 ohms (0.04% THD)
2 x 65W+1Ch x130W at 4 ohms (0.1% THD)
4 Ch x 65W at 2 ohms (0.1% THD)
now my question is: the dealer says this amp is enough to drive the subwoofer as well as all the four speakers??? but it looks to me like theres not enough power?? what do you guys think?? also he says the triaxial with pio tweeters and back ovals are better combo than jbl comps front and 6.5 triaxials in rear. what are your views?
also please recommend me from the different choices that i have given for fronts and rears, and a different amp (maybe pio gm x944) if this sucks i am goin to fix this in like another 5 hours, so its urgent!!! thanks
sleepy is offline   Reply With Quote
Old 22nd May 2006, 13:06   #2 (permalink)
Sam Kapasi's Avatar
Originally Posted by sleepy
hi guys,
Hi Sleepy,
1)The HU is fine.
2) Components are the ones to go for. I do NOT recomend buying 2/3 way speakers in the front and then adding (shudder) a pioneer TS20 tweeter. Dont do it. Buy the component set for the front, REGARDLESS of what your dealer said. Trust me.
3) The swift will originally accomodate 6" triaxials in the rear with no modification. Putting oval speakers will mean parcel shelf mount. Since you have a sub, you dont need the ovals. Put the components (6") in the front and 6" coax in the rear.
4) The pioneer sub is ok. There are better subs. Unless you are going to a very good installer ( If your installer is saying the things he is, then he is not good) then you should either get a proper box made, or buy a PRE boxed subwoofer. Believe me, the box is 50% of the sound.
5) The amplifier is not enough to drive all of this. Perhaps the amp can drive all 4 speakers and you can buy a monoblock amp (if you have the budget) or a 2 channel amp and bridge it to the subwoofer.
6) EVEN if you buy a more powerful 4 channel amplifier, i dont recommend putting all 4 speakers and the amp on it. If your budget permits you only this amp, then connect your front components and the sub to it and let the rear speakers run off the HU.
__________________
Live the YetiLife®
Madonna is a Goddess.
Old 22nd May 2006, 14:05   #3 (permalink)
hey sam,
thanks so much for those views man, it was very helpful!
okay so based on your suggestions i'm planning to go for a second 2ch or mono amp. sub box is one of those premade ones (slanted on one side, straight other side), its plywood, around 1.5 inches thick... cost abt Rs.500, is it any good?
how are pioneer amps compared to sony? i dont have the budget to go for more expensive ones, as this setup will itself cost around 30k.
can you recommend a sony or pio 2ch or mono (no too exp.) amp to drive the 400w rms sub?
thanks
Old 22nd May 2006, 14:13   #4 (permalink)
low_bass_makker's Avatar
Infractions: 0/1 (5)
I totaly agree with what sam just said...........
__________________
156.6 db, naa....time is coming to cross it......
Old 22nd May 2006, 14:16   #5 (permalink)
Box must be of MDF not PLYWOOD never ever....
From my personal experince pioneer amps are good than sony one so go for pioneer.......
__________________
Old 22nd May 2006, 14:23   #6 (permalink)
thanks lbm. your setup looks kick *** dude!
can you give me your detailed audio specs?? couldnt find it in your profile..
Old 22nd May 2006, 14:45   #7 (permalink)
Check the profile home page for the specs..........
__________________
Old 22nd May 2006, 14:55   #8 (permalink)
speedzak's Avatar
Hi sleepy.
I totally agree with Sam especially about that installer.
Components in front and co-ax or tri-ax in the back. No need for ovals. Mount the component woofers in the front doors and the component tweeters somewhere facing you (but not above your ear height). Mount the rear speakers in the rear doors for some depth in your sound image.
Your best bet is to get a monoblock Amp and let it fire the SUB. And if your budget does'nt allow it, get a good 2 channel or 4 channel and bridge all the channels to fire the SUB.
Your current AMP (Sony XM55) can power the components and rear speakers. And tune it to play mids and highs only. All the bass will come from the subwoofer and your speakers will handle all the mids and highs.
And if you cannot afford a new AMP now, Let your Sony AMP power the components and SUB. Bridge 2 channels and power the sub from it. The other 2 channels can power the compos. Later You can buy a decent monoblock and power the sub from it.
Your Pioneer SUB, (if you have'nt yet bought it) is not much of a musical sub. And it just punches Bass and not always sounds sweet. (though it is good VFM). Maybe you can browse some of other available SUBs in the same category.
My advice is to buy good quality ICE for your setup. And if you cant afford all at one go, then do it one by one. Buy speakers, later buy a nice SUB, then buy a monoblock, then a 4channel amp, then components etc....
Enjoy the sound!
__________________
Music heaven a touch away!
SK456's Santro.
speedzak is online now   Reply With Quote
Old 30th May 2006, 11:51   #9 (permalink)
thanks speedzak and everyone else for their inputs. you guys make team-bhp the place to be!
sorry i didnt reply earlier, was a lil' busy with work.
okay, so as i said earlier, i put the front 6.5 inch JBL comps, reas 6.5 inch JBL Triaxials, and a 150W RMS pioneer 12inch sub along with a XM55 4ch amp. for rating please take a look at the first post.
Now i agree that all four speakers + sub cannot be handled by that little amp, so i thought i was going to put one amp now and prob. another one later. but the dealer suggested that he could install all four door speakers in 2 channels, and the other 2channels bridged for the sub, so i told him to do it just to see what happens.
well he did it, and it didnt seem underpowered to me as i thought it would. now i am no audiophile like you guys, but i couldnt detect any distortion or anything abnormal coming out of the speakers. yes the sub wasnt too much to my liking, it sounded a bit dead, but otherwise, the system seemed pretty good.
What do you guys make of this?? what would happen if i install another mono amp for the sub?? as it is, it seems to have quite good bass and volume.
Old 30th May 2006, 16:49   #10 (permalink)
navin's Avatar
Originally Posted by low_bass_makker
Box must be of MDF not PLYWOOD never ever........
Well if you use void free marine grade ply you can make a nice box too.
__________________
Scixelsyd Etinu
Thread Tools
For Sale - Sony 4ch 444 Amp & Pio 6981 Co-ax Vista2Swift Shifting gears 4 30th January 2008 10:12
for sale:sony xm-zr 604 amp. man_1 Shifting gears 1 23rd December 2007 23:47
Which amp is better Sony XM-554ZR or Sony XM-ZR604? prakasse Ask the Gurus 3 5th November 2007 15:29
Little question about amp overdose14 Ask the Gurus 16 1st November 2007 18:29
Pioneer Sub & Speakers, Sony Amp. for Sale in NCR manveet Shifting gears 1 20th July 2007 11:16
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
