| Product Discussions Discuss the equipment that makes the ICE |
| | Thread Tools |
| | #46 (permalink) |
| BHPian | I have a spare Sony CDX-MP50 on which I tried some home made hack (it has a BUS IN, so hoped I can push an AUX-IN through it, but the HU didn't know anything coming in through that because the control wire is not connected, so it didn't let me select the `changer' as a source at all); then I took that to a local installer (professional sound: near thippasandra (bangalore)) and asked him if he can bring out an AUX-IN. He tried but at the end of the day called me to say it is not possible. I gave him the idea of cutting AM tuner, even I said I wouldn't mind if we have to do the same for the CD (coz I wouldn't play a CD if it works out), but he is probably not expert enough to execute it. I read in net I can use Sony's XA-300 which will convert a BUS-IN to an AUX-IN. But no idea of availability/price in India. If it is $100, which is 3931/- I may as well buy the cheapest HU with an AUX-IN. Kousik |
| | #47 (permalink) |
| BHPian | hi guys, i dont understand the need to buy ip bus aux in cable if your pio HU has au in. i dont know if any one has done this but i have been doing this since quite long when i bought my first pio HU. You can use the REAR LINE OUTS as aux in if there is no amp connected to that channel. first switch on the aux in from the setup menu by pressing the function key for 3-4 seconds when the HU is off. then just connect an rca lead to the rear pre outs. job done. im using this in my 770mp and have done on my older 5650 mp3. im sure it works. if it does then you dont need to buy that stupid ip bus cable. send me a draft of 50% of the value of the ip bus cable. kidding lol. cheers clip |
| | #48 (permalink) | |
| BHPian Join Date: Jan 2008 Location: Mumbai
Infractions: 0/1 (4) | Quote:
Also, does it charge the iPod while playing?
__________________ If I could wake up in a different place, at a different time, could I wake up as a different person? ~Chuck Palahniuk, Fight Club Last edited by nishantgandhi : 15th February 2008 at 10:29. | |
| | #49 (permalink) |
| Team-BHP Moderator ![]() Join Date: Mar 2007 Location: Bangalore
| No, the one that the dealer has told you is the AUX-IN (EP to RCA) cable. There is another cable - "iPod interface cable" Part No 7 607 540 500, MRP 5750 - that charges the iPod and also allows track selection at HU.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #50 (permalink) | ||
| BHPian | Quote:
). But as you say it sounds terrible, and i am again in a dilemma should i go ahead and buy it!!?? The shop keeper has quoted me price of 2k for the "intex" fm modulator. Advice/ suggestions please.Quote:
Guys what to do? help please Thanks.
__________________ FORD | ||
| | #51 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
But are you sure the AM signal would have a seperate track to the "mixer"? Could it be possible that all the bands of tuner use the same channel and only the source is switched?
__________________ Operator! Give me the number for 911! | |
| | #52 (permalink) |
| Newbie Join Date: Jan 2007 Location: Hyderabad
Infractions: 0/1 (7) | This should be a regular 3.5mm Male to 3.5mm Male which shouldnt cost anymore than Rs100 and is available at any local audio video / electronics store. But do check if your AUX IN takes a 3.5mm else you would need a convertor from a 2.5mm to a 3.5mm which is another Rs100. |
| | #54 (permalink) | ||
| Quote:
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | ||
| | #55 (permalink) | |
| BHPian | Quote:
What are you planning? Do keep me posted.
__________________ ------------------------------------- Ford Fiesta 1.6 sxi 2007 WagonR LXi 2001 | |
| | #56 (permalink) |
| BHPian | @ vnabhi After reading some of the posts I am really confused all over again. Yes you are right the fm quality on the stock system is not at all that bad, and instead of doing some jugaad with the stock HU I see this as a harmless option to go for, both for me and for the car's HU. As and when the time permits I am going to the car accessory shop, for the shopkeeper has readily agreed to give me a demo before I go ahead with the purchase. Will keep you posted as to what happens. For a fact till date I do not have an I-pod, but around two-three flash drives , so instead of buying an I-pod and then this, only buying this is a cheaper option, IMO.
| | #57 (permalink) | |
| BHPian | Quote:
| | #58 (permalink) | |
| BHPian | The system shows the option of AUX mode ![]() ![]() And the owners manual says this: Quote:
__________________ FORD Last edited by dhaval : 28th April 2008 at 13:07. | |
| | #59 (permalink) |
| BHPian | dhaval, I too read the manual and the line you have quoted above. But when I asked Mody Ford guys to verify, they said there is no aux input at the rear ! It is quite baffling to me. I heard that an Endeavour does have a aux input at the rear of the HU. So do you think they have copied the lines from the Endy manual? O ne more item that confused me is the clock setting on the HU, though the manaul mentions about it, I could never get to see it. Anyways, there is another clock cum temp guage on the sxi, but how could wrong info be given on the manual?
| | #60 (permalink) |
| It is possible that the HU HAS AUX-IN. Not as RCA sockets, as expected with Pio and other HUs, but as a part of the regular block connector. 1. Could you please check in the manual for any of the following? - Connection diagram for the AUX-IN - Connection diagram for the main wiring block connector (which includes wiring for battery, ground, antenna connector, etc.) - Text which describes where the AUX-IN pins are 2. Could you ask the showroom guys if they will allow you to take a photo of the rear of the HU, with the connector taken out and connector in place?
| Thread Tools | |
Similar Threads | ||||
| KDC-MP3038 - Rear Aux - iPod? | isacM | Ask the Gurus | 2 | 13th December 2007 12:37 |
| The Great Ipod Thread - All Ipod and MP3 player related threads are merged here. | gunbir | Ask the Gurus | 154 | 8th November 2006 09:55 |
| Connecting iPod to CD-changer input | desmoquattro | Gadgets, Computers & Software | 4 | 7th April 2006 23:01 |
| Need a Pioneer AUX cable for iPod.... | normally_crazy | Ask the Gurus | 12 | 29th June 2005 17:44 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
