| Product Discussions Discuss the equipment that makes the ICE |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Oct 2007 Location: Bangalore
| I recently installed a new Sony GT460U in my Ford Fusion (Petrol). The unit keeps switching off momentarily and resetting itself every few minutes when I am driving. This NOT just when I start the engine or anything. I didnt observe any electrical problem with any other component in the car (lights, AC). I tried having the whole thing rewired, changed the system and the panel - but I still have the same problem. Any suggestions? Thanks, Nirmal |
| | #7 (permalink) |
| Team-BHP Moderator ![]() Join Date: Mar 2007 Location: Bangalore
| If another HU hadn't been tried one would have suggested why don't you (or your installer) unmount the HU, connect a battery to it OUTSIDE the car and check if it does the same thing. Could have been a dry soldering problem, but this cannot happen with 2 HUs. Otherwise, connect a lamp (yes, any automotive 12V lamp) to the reset wire (I think it is a red with yellow strip or the other way around) that is coming to the HU. This signal is supposed to go ON when you turn the key to crank the engine. If the lamp goes on intermittently WITHOUT you cranking the engine, there is some locha in that wire. Another way the installer could check would be to disconnect only that wire and play the HU.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #8 (permalink) |
| They did try checking by fixing a bulb and it didnt blink! Now here is something curious I discovered today - when I start the system, I turn the volume down to 0 and then slowly (not in one go) - increase the volume one notch by one wiaitng a couple of seconds before increasing every notch - when I do this, the system does not restart! I am not sure about this - I will try to do this a couple of times and see what happens... |
| Thread Tools | |
Similar Threads | ||||
| Which amp is better Sony XM-554ZR or Sony XM-ZR604? | prakasse | Ask the Gurus | 3 | 5th November 2007 15:29 |
| Sony 554 problem! | vidurm | Ask the Gurus | 7 | 24th October 2007 15:22 |
| Sony Ericsson W550i problem | Bass&Trouble | Gadgets, Computers & Software | 16 | 28th May 2007 11:46 |
| ICE for a Wagon R. Budget 10K. Sony CDX-GT460U Head unit with JBL speakers | parag385 | Ask the Gurus | 7 | 18th May 2007 09:04 |
