| Product Discussions Discuss the equipment that makes the ICE |
| | Thread Tools |
| | #61 (permalink) | |
| Senior - BHPian | Quote:
What is the fader setting on the HU?
__________________ PIGZILNKILJBSCOMB | |
| | #62 (permalink) |
| Team-BHP Moderator ![]() Join Date: Mar 2007 Location: Bangalore
| @amit_mechengg, "Bass : Zero, Treble : +3 , Fad : +2" is not flat - all at zero will be. "preety flat" No, she's not, she is quite decently endowed!!!![]() "The amp is set to LPV mode and not the full mode" - this is OK, you are basically telling the amp not to waste power on mid and hi frequencies. "subwoofer is bridged to the amp with negative grounded": Not understood. "Bridged" means connected to + of L and - of R, and - of R should NOT be grounded! If you mean - of power supply, I'm not sure if you have +ive or -ive ground in your vehicle. We don't even know what else do you have: HU, speakers, etc. "the tuner which tunes from 0-6 v ... HU is 45 X 4 watts and the line out is 1.5 volts against the pioneer/ sony 50X4 watts and line out 2.5 V": data not relevant. What IS relevant is that a. your fader is set to +2 to rear - this should be 0. Come on, you have an amp, and amp GAIN should take care of this b. keeping fader at +2 you would be keeping the volume higher than normal to get decent volume in front c. You have not tuned your system well d. Don't go by 'declared' engineering data, unless you are measuring it properly. "i dont get the complete punch from the woofer it seems. the woofer is very powerfull. its 250 RMS i.e more than the JBL base tube i.e 125 rms": The woofer can take 250W rms, but is the amp able to give it? Maybe not. Post pictures of your installation, so that we are able to relate to it and see if something else is wrong. Now, try this: 1. Connect the RCA cables going to amp to the FRONT pre-amp out, not rear 2. Set all tone controls flat, set fader to zero 3. Play some normal tracks, which are not bass heavy 4. Keep amp gain at 0 (for the time being) 5. Keep HU volume at a comfortable hearing level (OK, OK, no bass, but still...) 6. Now slowly raise the amp gain till you can just feel the bass from the sub. Don't look at where the knob is set, unless it already reaches max before you feel it 7. Play a set of bass heavy tracks (drum & bass, for example) and see if the setting is OK. Increase gain if you feel lack of punch. If bass is becoming overpowering when you increase volume, reduce the gain a bit. Set fader to front if the image is too close to you
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #64 (permalink) |
| BHPian |
__________________ 2007 Indica DLG My next Truck will be a Safari! |
| | #65 (permalink) |
| BHPian | ![]() The Power Cable for Amplifier power in the engine bay. Make : Soundstream, Price : Rs.950/- ![]() Front 4" Sony Explod Speakers. i dont like Sony speakers that are in the front. ![]() The JVC car tape model KS- F171, 45 X 4 watts ![]() the adaptor cassette which converts car tape to MP3. it has a sony high quality audio head in it. ![]() the Malasian Sony MP3 player my friend had bought for me 4 years back. I also have a Hitachi Hard disk 80 GB DVD/VCD/MP3 player which can be coupled directly to the Lcd display and the cigarette lighter adaptor for best digital picture experience. ![]() my new Dynamo Philips 2 channel Amplifier. ![]() woofer out connections bridged Negative Rear and Positive Left. Also shown the battery , Rem and Ground. the ground is attached to body for earthing.
__________________ " I dont Drive Fast , I Fly Slowly " |
| | #67 (permalink) |
| BHPian | ![]() Rear japanese make speakers. Forgot the brand. had purchased it from a friend who has customs electronics shop. sounds good since 3 years. ![]() ![]() The rear speakers and the woofer. The flap is custom made from 12" wooden ply perfectly blended with the contours of the boot fibre. ![]() the custom made box for woofer made up of particle board and air ducts. ![]() subwoofer, Make : philips, 1300 watts 250 Rms. it has a very good finish and quality. ![]() now i have removed the grill over the subwoofer. it was touching the subwoofer rubber bidding. might be it obstructs the movement of the woofer.
| | #68 (permalink) | |
| BHPian | Quote:
The fader setting on HU is +R2
__________________ " I dont Drive Fast , I Fly Slowly " | |
| | #69 (permalink) | |
| BHPian | Quote:
now my HU doesnt have a front Pre-Amp out. it has just a rear line out with left and right sockets. also i tried the above method u told me with keeping all the settings flat. i have reduced the gains a bit. please tell me one thing. 45X4 watts is the delivery of the HU. and this is input to a AMP which gives 60X2=120 Rms out. whats the sum that the Subwoofer gets in total. Also what extra will i gain if i go for a 50X4 watts HU. Also i didnt get the funda where it says my HU gives out 1.5V at line out and the other HU gives 2.5V at line out? i may sound nuts but please explain.
| | #73 (permalink) | ||
| Senior - BHPian Join Date: Mar 2006 Location: Dubai (3-10 July)
| Quote: Quote:
__________________ Operator! Give me the number for 911! | ||
| | #74 (permalink) | |||
| OK, now it is easier to visualize. * First of all, what is the orange wire that is peeping out from behind the speaker wires? (Pic 7, amp wiring) Where is this wire connected? * The woofer is fine, but the box and grill do not seem to be anywhere near what one would expect of a Philips associate! Is the dealer giving the box deal? As @Hydrashok said, the box is HUGE! Could you tell us what are the external dimensions of the box, the size of the hole(s) and length of pipe (the grey plastic pipe)? Quote:
Nothing, nichts, zero, zilch, shunya; see above Higher Line-out voltage (used to be 0.4V standard in home audio earlier, but in ICE there is no standard) is a design issue. Yes, it is easier to reach full capability of higher power amps (like in LBM's case) with lesser noise and distortion if you feed a higher voltage at the input. But, at your amp's level, it does not play that significant a role.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | |||
| | #75 (permalink) | |||
| BHPian | [quote=DerAlte;736069]OK, now it is easier to visualize. Quote:
and one more thing please suggest me. now i have removed the safety grill. please look at the pic no 9. it shows the placement of the rear tray and the woofer. there is a very less gap in between the two. is it affecting a proper functioning of my system?
__________________ " I dont Drive Fast , I Fly Slowly " | |||
« USB Pen Drive speeds and HU
New Pioneer Tsw305 Car Woofer 500 Watts for 2998 - Is the deal good? »
| Thread Tools | |
Similar Threads | ||||
| Will installing subwoofer & amp void manufacturer warranty? | lordofgondor | Ask the Gurus | 7 | 20th August 2007 13:13 |
| Sony 4 channel amp' and Pio subwoofer for sale | rjstyles69 | Shifting gears | 10 | 14th August 2007 19:18 |
| Look at what is hanging out in my Town. | vcash | The International Automotive Scene | 18 | 9th July 2007 18:25 |
| MODIFIED suggestions for 4 ch. amp & subwoofer | ggoyal_83 | Ask the Gurus | 114 | 15th December 2006 19:07 |
| Which AMP and Subwoofer for the Innova!! | Shan2nu | Ask the Gurus | 24 | 25th March 2006 15:43 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
