Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Product Discussions
Product Discussions Discuss the equipment that makes the ICE
Thread Tools
Old 29th February 2008, 10:45   #91 (permalink)
amit_mechengg's Avatar
ok then i think i shall call up the philips company guys. there are no specs written on the box or manuals about the speaker size. ya i can make out from the talks of the dealers that they are nuts and dont know about the speaker sizes. according to them the bigger the better.
__________________
" I dont Drive Fast , I Fly Slowly "
Old 29th February 2008, 11:07   #92 (permalink)
low_bass_makker's Avatar
If the enclosure is a ported one. Correct. I agree with them but hey dont get all confused here. Seal the ports and reduce the volume and check out the results.
__________________
If you are good at something do not do it for free !!!!
Old 29th February 2008, 12:14   #93 (permalink)
ya did that. blocked the ports and tried. but still the woofer doesnt give crisp bass. the movement of the cone of the woofer is not smooth. but i have kept the level knob amp on the minimum side. the range is from 6v to 0.3v.
i think the tray should be removed and the rear speakers be put in the sealer enclosure. the gap between the woofer and tray is very less. the air punch coming from the woofer hits the tray.
__________________
Old 29th February 2008, 20:12   #94 (permalink)
hey gurus. today i got rid of the tray and put the rear speakers in the boxes. now there is bit of gud sound effect. thought not 100% but atleast 15-20%.
i went for hunting glass wool. but didnt get anywhere in pune. and there was one place where it was available but not on loose. 25 KG bag was there.
guys please tell me how much glass wool do i have to fill. do i have to fill the whole box upto the brim with the glass wool or just at the bottom??
__________________
Old 1st March 2008, 10:56   #95 (permalink)
Team-BHP Moderator
navin's Avatar
about 1/2 kg per cu ft.
__________________
Scixelsyd Etinu
navin is online now   Reply With Quote
Old 1st March 2008, 11:39   #96 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Navin, wouldn't polyfill (pillow / cushion stuffing) work too for him? He could buy a cheap pillow on the roadside and use it.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
DerAlte is online now   Reply With Quote
Old 1st March 2008, 11:53   #97 (permalink)
that means i have to put around 1 kg max.
can i do it with pillow stuff. do u mean the cotton ones or different ones. sir wont the glass wool or pillow stuffing material come out of the ports ? will it block up in the cones and other components of the woofer?
__________________
Old 1st March 2008, 12:05   #98 (permalink)
hydrashok's Avatar
Yup. Polyfill from the pillows would do just nicely. No itching-vitching from the glass wool either.
Reliance pillows are good candidates for butchery. Well, any polyfill-wallah pillows would do I guess.
@amit, don't use cotton.
__________________
Seven are my colours
Many are my lovers
What was three will soon be two
The music will again sound pure and
true
Old 1st March 2008, 12:48   #99 (permalink)
thanks hydrashok. what is the method of filling polyfill into the woofer. do u have to remove the subwoofer from the box first? or shall i pour it down through the ports? and the sub punches the air out from the ports. wont it punch out the polyfill into my car?
__________________
Old 1st March 2008, 15:23   #100 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Arey nahin yaar, you have to put it in a cloth bag and put it inside, unless it is in a felt roll form.
You can definitely pour it through the ports, but then it will create some nice theatrical effects. You can then invite your GF for a 'romp in the snow'
__________________
Old 1st March 2008, 15:38   #101 (permalink)
ha ha ha...and after the snow romp i will have to sit the whole night cleaning the stuff.
well then in that case can i directly put the pillow inside without cutting it ?
__________________
Old 4th March 2008, 21:14   #102 (permalink)
hello gurus,
first of all thanks for ur valuable guidance. now with all the above stuffs i landed up in changing my HU to pioneer 5050, JBL GTO927 at rears and a sony 2 channel amp for powering the philips subwoofer.
the old dynamo amp i am using to power the rear jbl speakers.
is this correct now. though i am very new to the settings and menu , the quality has increased drastically. any more stuffs needed??
__________________
Old 5th March 2008, 09:26   #103 (permalink)
Team-BHP Moderator
navin's Avatar
why not?
I use rubber gloves but polyfill does nicely too. cottom will only filter the midrange.
Youd have to do this. Normally damping is added before the box is laminated/veneered etc.. and normally one woulduse a staple gun to staple sheets of damping to the walls but I guess your box is already finished.
I've never tried this but it seems like a good idea.
flatten the pillow and ensure that that the cover is acoustically transparent.
My methods are more rigourous becuase I expect more.
1. staple damping to walls
2. cover stapled damping with loose damping
3. staple damping to bracing in inside box so that the damping hangs this hanging damping converts the kinteic energy in the box to potential ennergy and heat.
__________________
Scixelsyd Etinu
Old 5th March 2008, 09:58   #104 (permalink)
yes sir my box is already done and in use. now i have to open the woofer and put there stuffs inside through the 12" cut made for the woofer.
i didnt get ur point, using sheets of damping. what have u used in ur box for damping?
sir this was a real bouncer to me. sir can u please tell me whether i have to staple the pillows now? or shall i just put 2 small pillows in the woofer. how do i make the pillow cover accoustically transparent?
__________________
Thread Tools
Will installing subwoofer & amp void manufacturer warranty? lordofgondor Ask the Gurus 7 20th August 2007 13:13
Sony 4 channel amp' and Pio subwoofer for sale rjstyles69 Shifting gears 10 14th August 2007 19:18
Look at what is hanging out in my Town. vcash The International Automotive Scene 18 9th July 2007 18:25
MODIFIED suggestions for 4 ch. amp & subwoofer ggoyal_83 Ask the Gurus 114 15th December 2006 19:07
Which AMP and Subwoofer for the Innova!! Shan2nu Ask the Gurus 24 25th March 2006 15:43
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
