Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Product Discussions
Old 24th January 2008, 01:18   #1
vebmetal's Avatar
Question HUs with USB pen drives - Playlists
So the latest decision in ICE stuff on my end is to get a USB model (most probably Kenwood MP4036U) and buy one or two 4GB pen drives, since they have hit the below Rs. 1,000 price range.
Usually, I just do "play all" with shuffle on my mp3 player. I am assuming that this would be possible and not a problem at all.
But other than that I usually have a playlist of songs that are let's say palatable to the average person, that is to say no metal etc. Sometimes I even have an old person friendly playlist of Indian music, fusion etc.
Do USB HUs have playlist functionality with pen drives? If so, would the playlist be in m3u format, or something else? And how does one select it from the HU menu?
vebmetal is offline   Reply With Quote
Old 24th January 2008, 14:26   #2
vebmetal's Avatar
what? no one uses flash drives here with their HU?
Old 24th January 2008, 14:41   #3
Even though the manual says no playlist support, you can do it
1. Use M3U lists
2. While creating, ensure to load tracks from the external drive,
so this wont cause any "drive letter mismatches."
3. Save the files in the same folder as the list or preferably use only the ROOT directory on your pen drive.
Old 24th January 2008, 15:01   #4
Ajaybiz's Avatar
Thanked: 56 Times
Infractions: 0/1 (5)
In my player(Pioneer DEH 7950UB) its very easy either play in shuffle mode or one by one you you can select track or folder too by using list option.
Ajaybiz is offline   Reply With Quote
Old 24th January 2008, 15:20   #5
vebmetal's Avatar
Thanks Ajaybiz, I thought as much. "Play All Tracks" with "Shuffle" should be pretty much standard. So really now I am wondering about playlists.
@souljah: How do you use the .m3u playlist then? Does it show up when you scroll through the file names? Also then are playlists easy to use? (As in can you change from one playlist to another while driving or would one have to stop?)
Old 24th January 2008, 17:17   #6
Unfortunately I dont own a HU yet. If someone would be kind enough to donate / lend me a pioneer USB HU for a few weeks I will report back
Vebmetal when you plug in the HU should pick up the playlist, try it and report back.
Old 24th January 2008, 17:32   #7
vebmetal's Avatar
I think I will just go to Lajpat Nagar tomorrow with my pen drive and check it out there.
Old 24th January 2008, 17:58   #8
NIP
NIP's Avatar
Thanked: 54 Times
oh gawd !! here we go again. vebmetal...you better get a damn HU before your grandkids gift you one for your 99th birthday !!
NIP is offline   Reply With Quote
Old 24th January 2008, 18:06   #9
vebmetal's Avatar
You guys will miss me once I get my ICE
Old 24th January 2008, 20:40   #10
nvc_4125's Avatar
there is opption in new pioneer serise XX50UB.
i resently upgrade my HU with pioneer 5050UB and y can see folders and from them u can also select songs.
it has 3 pre. output with 4 volt.
i use my 1 gb pen drive with it.
its a nice head unit.
nvc_4125 is offline   Reply With Quote
Old 24th January 2008, 23:15   #11
Thanked: 216 Times
No then upgrade time will come.
Old 25th January 2008, 13:31   #12
DerAlte's Avatar
Thanked: 953 Times
"Jaiye aap kahan jayenge, ye nazar laut ke phir aayegi..."
Old 25th January 2008, 16:20   #13
vebmetal's Avatar
So will this work on the Pioneer 7950UB? :
I keep all my mp3s on the flash drive in a Folder called "Music"
In the root directory I create two .m3u playlists - allsongs.m3u and easylistening.m3u. The first playlist would have a link to all songs in "Music" e.g \Music\Metallica - One.mp3. The second playlist would only link to a few songs.
So then when I press "List" on the HU, am I guessing correct that three things will appear like this? :
allsongs.m3u
easylistening.m3u
Music
Could someone with this HU please experiment and report back? pretty please, pretty please.
Old 26th January 2008, 12:53   #14
vebmetal's Avatar
^ oh c'mon, no volunteers? :(
anywya, in the pdf manual for the DEH-P7900UB I found that under "Additional Information" related to USB memory, it says that it supports .m3u playlists! yippee! So how does it work? And can I do what I want to do above ^ ?
Old 26th January 2008, 13:39   #15
Read my earlier post.
Playlist and files in the same directory would be your best bet. Everything in the root folder will make it easier.
What I do when I want files to show up at the top of the list is to mark them 00_filename 01_filename 02_filename etc
Baaki some 7950 owner must report back, but im pretty confidant about this should is the way it works.
All about USB Flash Drives a.k.a Pen Drive / Thumb Drive / Memory Stick / Jump Drive KSM-Vtec Gadgets, Computers & Software 1 28th February 2012 11:04
800 bucks USB Pen Drive only HU with no CD & no casette kittigadu Product Discussions 88 4th February 2011 12:27
How to connect USB pen drive to AUX port? forbhaskarm Ask the Gurus 4 15th December 2008 11:06
Scorpio slx Nippon HU USB not reading pen drive easyrider Ask the Gurus 22 13th August 2008 18:40
USB head units destroy pen drives (due to heat?) akash_m Product Discussions 69 30th July 2008 10:24
