Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Product Discussions
Product Discussions Discuss the equipment that makes the ICE
Thread Tools
Old 1st March 2008, 22:32   #16 (permalink)
thanks, that is a good place for technical information.
Old 1st March 2008, 22:57   #17 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Originally Posted by NetfreakBombay View Post
Can you quote some source for that? If that is indeed the case it would be interesting to read about it.
Since you are a software developer I assume you are familiar with NDAs? Many of us will be violating NDAs if we did!
Reason I am skeptical is, even 1000 - 2000 Rs devices have more power then that. We are talking about 9000 Rs device here.
Even a 1700 Rs Wireless router that I am using has a 32 bit MIPS processor (BCM3302) running at 200 MHz and runs VxWorks. ...It has 16 MB RAM.
My second PC was pentium 100 MHz with 8 MB RAM and it could do MP3
Perhaps it would be very illuminating if you compare the BoMs of that Router and an average HU. Now compare the BoM cost with the selling cost per unit. If you were an HU designer, you would be hard-pressed to use a micro-controller at all.
Why? In the router, there are 2 chips and a handful of passive components + 8 LEDs for display. In the HU, there are 20 chips, a bushel full of passives, and you wouldn't buy it unless there is a hi-funda DM display. How much cost will you allocate for each function in the HU? And - finally - which micro will you choose in the money left over?
Your second PC would have costed 30K at least - just to play MP3, since when it was playing MP3 it couldn't have done much else!!!
Not very apparent, no?
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 2nd March 2008, 00:43   #18 (permalink)
RAC
I vaguely recollect reading somewhere that some Pioneer models may not support Apple Loseless.
Not sure about it, never tried it.
RAC is offline   Reply With Quote
Old 2nd March 2008, 08:50   #19 (permalink)
Agree that it might be economical to build a single chip that does all things all things instead of building HU using generic microprocessor + RAM + Flash etc. Specially if volume is high.
But its hard to digest that integrated chip would be 8 bit.
And reasoning is the same.. it has to do MP3/WMA etc + USB + FAT and many more things.
Old 2nd March 2008, 09:52   #20 (permalink)
greenhorn's Avatar
Yes , eventually if volumes are high, someone will put them all into one LSI chip, but the whole point of using dedicated decoders etc is to do the job with the least processing power and cost .You may need a good processor to playback Mpeg 4 corrrect ? Yet the same can be done fairly easily by most low end GPU's these days. Pretty much the same thing .
The uC in this case doesnt have to be very high performance at all. All it needs to do it sit on the I²C Bus (which doesnt need many bits ) and send commands and/or move small bytes of data ( like the song name etc) around. You certainly dont need horsepower for it. You're thinking of it running on an OS , or something of that variety - I think that's overkill... Some custom C coded ASM should be more than enough for it.
__________________
2007 Indica DLG
My next Truck will be a Safari!
Old 2nd March 2008, 09:56   #21 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Sir, why should the core controller run the CODEC? The dedicated silicon CODEC + separate controller is cheaper than higher power micro running a soft CODEC!!!
__________________
Old 2nd March 2008, 09:57   #22 (permalink)
And that CODEC chip is 8 bit?
Old 2nd March 2008, 10:12   #23 (permalink)
greenhorn's Avatar
The controller may be .
The codec needs to decode 16 bit audio at the least , so obviously not
but the codec is not a 16 bit microprocessor, if thats what you're driving at. Its a digital signal processor
__________________
2007 Indica DLG
Old 2nd March 2008, 10:50   #24 (permalink)
I don't think a processor that can handle just 8 bits will be able to act as a controller either.
Yes CODED should so some custom chip with MP3/WMA/AAC etc logic implemented on DSP.
Old 2nd March 2008, 14:03   #25 (permalink)
Team-BHP Moderator
DerAlte's Avatar
To give you some examples of 8-bit micros being currently used, apart from HU controller:
1. The venerable old company Zilog still makes a Z80-derived micro, which is the mainstay of most Remote Controllers for TV, HT, DVD etc., apart from the programmable remotes
2. Most of the engine management ECU for low-end cars are based on 8051 derivatives
3. Most digitally controlled elevators in operation today are controlled by 680x-based control systems
4. Most common PMPs are based on a Philips chipset, which has an 8 bit controller internally (not the CODEC)
Most of us get carried away by Moore's Law and Intel's advertising, forgetting the fact that the bulk of micros and processors working in the field (outside of PCs) are in fact the old clunky slow ones like Z80, 8051, 6809, 68K, 99xx, etc. and their derivatives. They outnumber Pentiums et al 10:1!!! Of course they are not sexy or news-worthy, so you wouldn't have heard of them.
Why can an 8 bit micro not decode to 16-bit audio? The stream is 8-bit bytes only, no?!
By your logic, a bus-driver should be 3 times the size of an average M800 or Alto driver!!!
__________________
Old 2nd March 2008, 15:07   #26 (permalink)
ScarySkulls's Avatar
I heard the 6050 wont play VBR mp3 tracks.
Can somebody confirm this?
__________________
Punjabi for Life.
ScarySkulls is offline   Reply With Quote
Old 2nd March 2008, 15:21   #27 (permalink)
greenhorn's Avatar
Well, I meant that the codec was 16 bit
most 8bit audio codec chips are voice (~48 dB S/N) variety .
__________________
2007 Indica DLG
Old 2nd March 2008, 16:18   #28 (permalink)
Team-BHP Moderator
DerAlte's Avatar
We are on parallel tracks! I meant internal Data bus width of the micro, and you were talking about Data width per sample!!! You really need to roll up your sleeves and get your hands dirty, you white collar intellectual
__________________
Old 2nd March 2008, 18:26   #29 (permalink)
I can understand remote controls using Z80. No idea about elevators but that makes sense as well (not too many parameters to process).
But ECU in today's cars??
I have Alto that is pretty much as low end as you can get (it shares engine with 800). And it has some 32 bit ECU.
Alto's spec page :
Maruti Alto. Know about the specifications of Maruti Alto.
Similarly Maruti 800's spec page talks about 32 bit ECU
Old 2nd March 2008, 18:48   #30 (permalink)
greenhorn's Avatar
I was replying to Netfreak's question when I said that the codec was not an 8 bit.
I had added that the controller could be an 8 bit in the reply above
If You'd taken my replies in context, you'll see that you're the one who's taking me on a parallel path
__________________
2007 Indica DLG
Thread Tools
Which Pioneer HU 4050\5050\6050 ? ddd08 Ask the Gurus 114 4th May 2008 01:37
Specs Req Pioneer 2950 and Pioneer 4950 HU nicejits Ask the Gurus 3 23rd November 2007 11:03
Fitting max MP3s on a new CD kkdelhi Gadgets, Computers & Software 14 26th June 2007 08:43
For Sale: Pioneer FH-P 6200 2 Din and Pioneer EQ 6500 Equalizer . sam_78 Shifting gears 4 28th April 2007 12:16
Looking for PIONEER P-80 cartouch_56 Product Discussions 1 10th June 2006 13:47
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
