Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Product Discussions
Product Discussions Discuss the equipment that makes the ICE
Thread Tools
Old 9th March 2008, 21:17   #1 (permalink)
adityamunshi's Avatar
Default Pioneer 6950 CD Eject problem
Guys, my Pio 6950 is just 4 months old and its already giving problems. The CD doesnt eject fully. When i press the eject button, only ~1 cm of the disc come out, then i have to pull it out manually.
I think the problem is with the soft packing on the lower egde of the 'slit'. Its rubbing against the CD.
__________________
And Michael Schumacher is actually in a very good position to win the race. He is in last place. - Murray Walker
adityamunshi is offline   Reply With Quote
Old 9th March 2008, 21:33   #2 (permalink)
i also have a pioneer HU and was experiencing the same problem. however after a couple of days it sorted out and didnt bother about it after that.
however now the cd does not come out at all, not even the 1 cm it used to. been having this problem for about 3 days now.
__________________
and no, i didn't really shoot my dog....
ishotmydog is offline   Reply With Quote
Old 9th March 2008, 21:46   #3 (permalink)
ramie2400's Avatar
the foam used at the slot becomes hard due to heat results problem in letting the CD out... it happenes in most of the HU but Pioneer is the No.1 in its place.(this is what i have noticed in all my Hu till now) get it serviced and the problem will go.
__________________
"Whenever I find the key to success,..... someone changes the lock.
Old 9th March 2008, 21:53   #4 (permalink)
apart from the ejecting problem the 'source' button which is used to switch between radio and cd player sometimes also stops working.
is it only button malfunctioning or is there something wrong wit the HU??
__________________
Old 9th March 2008, 22:16   #5 (permalink)
praveen_v's Avatar
My Pio which is almost 4yrs old gives me this problem from three months of it's use and now i'm used to living with it
__________________
Anyone driving slower than you is an idiot, and anyone going faster than you is a maniac. ~Author Unknown
praveen_v is offline   Reply With Quote
Old 9th March 2008, 22:38   #6 (permalink)
Location: Chennai (formerly Madras, even more formerly Chenna Patnam)
Exclamation
Aha ! and i thought I was the odd man out, when my Pioneer started refusing to part with the CDs : looks like this is a common problem.
Anyway, my solution is to try the eject button a couple of times, then switch on/off the HU : if this does not work, then use another CD to cajole the one inside to come out, this has worked so far
Blue Thunder is offline   Reply With Quote
Old 9th March 2008, 22:57   #7 (permalink)
kuttapan's Avatar
Does it show any error code when trying to play CD's?
kuttapan is offline   Reply With Quote
Old 9th March 2008, 23:03   #8 (permalink)
it shows nothing. it merrily keeps on playing the radio.
__________________
Old 9th March 2008, 23:14   #9 (permalink)
DerAlte's Avatar
Get the HUs serviced, guys!
Simple thing: the belt that drives the carrier mechanicals (which holds the CD while accepting or ejecting it) from the drive motor would be slipping on its pulley. This prevents sufficient force from being delivered to the mechanism, hence its malfunction.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 9th March 2008, 23:20   #10 (permalink)
speedzak's Avatar
A simple problem caused by D U S T ! Get the HU blown with some low pressure air. Or if you're comfortable with opening things and putting all back comfortably, then open the HU cover and clean all dirty parts which moves. Be careful with the lens though.
__________________
Music heaven a touch away!
SK456's Santro.
speedzak is online now   Reply With Quote
Old 10th March 2008, 11:31   #11 (permalink)
No, it isnt dust. I had the same problem with my old Pioneer 5850. My dealer said it was common among most pioneer cd players, so he just opened the HU and removed the foam which protects the HU from DUST.
He did this only because I told him that I never remove my faceplate. Otherwise, the dust would enter and cause the HU to malfunction. Always protect your HU, speakers and amp's from dust and they'll have a longer life.
amitwiz1 is offline   Reply With Quote
Old 10th March 2008, 12:14   #12 (permalink)
greatDrive's Avatar
Another thing which I have noticed is the type of music CDs I use. I get this problem only when I use cheap CDs being bought form road side. Never had this issue with CDs Sony written at home.
cheers
greatDrive is offline   Reply With Quote
Thread Tools
advice for all you people with pioneer HU problem(alt whine) clipto333 DIY - Do it yourself 39 10th October 2008 14:36
Connect N73 Music Edition to Pioneer 6950 using Aux IN coolsats Ask the Gurus 8 1st May 2008 17:44
pioneer 5850 problem deepak_ms Ask the Gurus 5 16th July 2007 17:41
pioneer 7850bt backlight problem hemanthisgreat Ask the Gurus 8 15th July 2007 00:04
HELP!Problem with my Pioneer HU(DEH-740MP) somebodystopme Ask the Gurus 9 16th February 2007 23:04
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
