Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Product Discussions
Product Discussions Discuss the equipment that makes the ICE
Thread Tools
Old 1st May 2008, 13:24   #1 (permalink)
akash_m's Avatar
Exclamation USB head units destroy pen drives
It has happened to me twice! My Transcend 4GB pen drive got corrupted while listning to music continuously for 1 hr in my Sony Single-Din car cd player (with USB). Similarly my sony 2 GB pen drive got destroyed (unusable anymore). I guess that there is no option of 'Safely removing Hardware' unlike the PCs to remove the pen drives from CD players. Also, these drives become literaly 'hot' even after playing 2 MP3 songs.
When I took the pen drive to sony dealer for replacement under warranty, he flatly refused saying that the warranty stands null void in such cases. He told that the pen drives are never ment for high speed continuous data transfer. Live audio streeming cannot be done using conventional pen drives!
Has anyone of you experienced similar issues..?
__________________
"Alcohol doesnt solve any problems", but if you think again, neither does milk...
akash_m is offline   Reply With Quote
Old 1st May 2008, 13:28   #2 (permalink)
low_bass_makker's Avatar
From when is 128-320 kb/sec is considered High speed
__________________
“First they ignore you. Then they laugh at you. Then they fight you. Then you win
Old 1st May 2008, 13:37   #3 (permalink)
No, the data rates of USB 1.0 and 2.0 are fixed and for usb 2.0 it goes at something like 4.5Mbps. They should be able to be used continuously without any problem. But check the specs for sure.
zaks is offline   Reply With Quote
Old 1st May 2008, 14:36   #4 (permalink)
vebmetal's Avatar
Hmmm. I hope this is not true for all, and you are just an unlucky fellow, akash_m.
I have been using my pen drive (8GB Corsair) for 2 - 3 months now, and the pen drive is still fine. I have used it upto 1 hour at a time in the Delhi heat. (But then again I only disconnect it physically when the engine and HU are off).
__________________
People who talk in metaphors ought to shampoo my crotch.
-Jack Nicholson
As Good as It Gets (1997)
vebmetal is offline   Reply With Quote
Old 1st May 2008, 14:54   #5 (permalink)
Infractions: 0/2 (8)
Talking
Hahahahahahah... Yaar you are the two muchs yaar... I'm no geek like you but even I know thats just the encoding bitrate and not the transfer speed of USB hahah...
Driven is offline   Reply With Quote
Old 1st May 2008, 15:13   #6 (permalink)
bblost's Avatar
Imagine this.
2 buckets, one bucket holds 20 liters and its is full.
The other bucket can only hold 100 ml at a time.
You have a mug that can take 1/2 liter at a time.
The small bucket has a leak and looses water at 10 ml a second.
so when you want to transfer water, you will move 100 ml from bucket 1 to bucket 2 every 10 seconds.
Now suppose you have a big bucket 3, that can hold 30 Liters.
You can move the water 1/2 ll at a time and finish it off in just 40 moves.
now replace
bucket 1 is your pen drive
bucket 2 is your HU
bucket is a PC.
__________________
ThunderBird 2003, no speedo, no range limits.
Wagon R, 2004.
Well trained reflexes are quicker than luck.
Old 1st May 2008, 16:33   #7 (permalink)
Spinnerr's Avatar
Well, my pen drive has now started acting funny. I too have been using it for some time now, but just on long drives, each time it was hooked on to the HU for about 4-5 hours at a stretch.
The problem with the pen drive is that you can open it (when connected to the PC) only when that window comes up, the one that pops up immedialty when you connect it to the computer. the one that lists Play, open folder...etc etc
It does come up as a drive in 'My computer', but double clicking it would not open. Gives one of those 'device error' messages.
So to reopen a folder on the pendrive, i have to reconnect it to the computer.
Strange, but it is happening. May be I should also try removing the drive only after I switch off the vehicle.
__________________
Zigged before you zagged
Spinnerr is offline   Reply With Quote
Old 1st May 2008, 16:53   #8 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Originally Posted by bblost View Post
Imagine this.
bucket is a PC.
OK, I give up - never did well in arithmetic in school! I am still trying to figure out which PC can hold 30l of water, and which pen drive can hold 0.5l. And your point was ...?
It has happened to me twice! My Transcend 4GB pen drive got corrupted ...
Commiserations, @akash_m, either your HU is giving a massive jolt of static to the pen-drives (HU grounding problem), or passing on massive amount of heat through the connector/tracks, or you have got 'lemons'/fakes twice.
Usually HUs will connect to USB devices ONLY in READ mode - they never try to write anything, so there is no possibility of spurious writes.
"Safely remove hardware" is required only with Windows machines, since directory changes may not be written to the pendrive if you remove it, resulting in a corrupted directory. If nothing has been written during a session, the pendrive can be removed anytime.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 1st May 2008, 17:00   #9 (permalink)
bblost's Avatar
OK I need to work on my communication with people.
I was trying to highlight that a device can support high rates of data transfer but will be limited by the amount of data the recieving device can take.
TO clear up the point raised in
"the encoding bitrate and not the transfer speed of USB"
__________________
Wagon R, 2004.
Old 1st May 2008, 17:42   #10 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Agree with derAlte, this looks to be a classic case of static damage.
__________________
My DCMAG Portfolio!
Old 1st May 2008, 17:50   #11 (permalink)
amit_mechengg's Avatar
even though the HU doesnt have the facility of "safely remove hardware" you can switch off the HU completely before pulling off the pen drive.
secondly you can do one thing. connect the pen drive to PC. on the drive click properties. one dialog box will open named removable disc properties. click on your pen drive from the list and click on properties. go to policies TAB and select " Optimize for Quick Removal " . your pen drive will be ready for removal without clicking safely remove hardware.
__________________
" I dont Drive Fast , I Fly Slowly "
Old 1st May 2008, 18:01   #12 (permalink)
Team-BHP Moderator
DerAlte's Avatar
No issues, happens to most of us.
You are absolutely right about the data transfer rate. Slight modification though - for audio / video, the actual transmission speed is limited by the amount of data the receiving device needs. The real rate expectation should be based on the actual byte offtake needs, not audio stream bps.
In this case, the bytes from the mp3 file on the pendrive is being buffered in the HU, which is being converted by the codec. The transfer happens in bursts based on HU buffer capacity and dynamic status.
__________________
Old 1st May 2008, 18:06   #13 (permalink)
I think it is done continuously not in burst rate or it may be different from model to model.
__________________
Old 1st May 2008, 18:14   #14 (permalink)
@akash - I have played music from my USB stick(Cruzer micro 4GB) for hours on end on my HU, and there has been no issues. My HU is a Pio, btw.
kuttapan is offline   Reply With Quote
Old 1st May 2008, 18:51   #15 (permalink)
Has it occurred to anyone that for some reason we assume that all these drives are built equally well.
I believe you get what you pay for.
Thread Tools
USB Pen Drive speeds and HU vebmetal Product Discussions 72 4th March 2008 17:18
Scorpio slx Nippon HU USB not reading pen drive easyrider Ask the Gurus 21 27th July 2007 14:33
Head units with USB input katalyst Ask the Gurus 19 22nd January 2007 14:05
HU with USB drives ? 4lacs Ask the Gurus 3 26th October 2006 00:32
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
