Go Back   Team-BHP > Team-BHP > Road Safety > Ride Safe
Closed Thread
Old 17th November 2014, 21:19   #31
Ricci's Avatar
Thanked: 995 Times
Default Re: Government could make ABS compulsory for two-wheelers
Originally Posted by basuroy View Post
The way ABS system works in current bike requires sensor in both wheels (ABS works by comparing the speed between 2 or in case of cars 4 wheels , if one is rotating slower than the other and crosses a certain threshold , ABS will kick in ) , as such having ABS for just one wheel will still require sensor in the rear , the money saved by axing the rear line is hardly worth the sacrifice and effort .
I don't think that is correct. ABS works on wheels independently, the comparison on wheel RPM is what stability control systems do. If on hard braking, the rear lifts and stops spinning, the front should not release pressure based on that, as that will reduce braking effectiveness , rather the front wheel ABS relies on front sensor data alone. Honda's CABS system may be like what you describe though.
I remember an article years ago about BMW just started with bikes featuring ABS. The general agreement was that ABS on bikes is a trickier phenomenon and hence the ability to switch off ABS should be provided. The reliability of ABS on some surfaces was suspect, so an off switch offers experienced riders to manage the braking themselves where they felt ABS hindered their braking efficacy.
Ricci is offline
Old 17th November 2014, 22:49   #32
Thanked: 246 Times
Yes ABS works independently but what I mean is it requires sensors in both wheels for working(even if for front only ) . It compares the speed between both wheels to detect lock and then makes a decision whether to actuate the valves . One can always axe the rear brake solenoid valve as I mentioned but that is hardly going to save much to justify the sacrifice because the system still requires the sensor to be present . If I am wrong about the part about the ECU basing its judgement on comparing both wheel speeds then I apologize , that is based on my recollection of what I read to understand the basics(it is of course possible a separate system exists which can work with only front sensor ) . At no point however I have implied that ABS works simultaneously on both wheels
There are also certain ABS systems to counter a rear lift up mid braking - those system release/modulates the front brake pressure when it detects the possibility of a rear lift up.
CABS I assume stands for combined braking , that is different and not what I am trying to describe .
EDIT : In light of our discussion , I on the off chance googled "motorcycle ABS front wheel only " and it indeed exists and as such I am wrong in saying it won't be cost effective . From description , it looks like no rear sensor is required either and apologies again for putting forward that misconception .
http://www.bosch-motorcycle.com/en/d...s_light_1.html
basuroy is offline   (1) Thanks
Old 19th December 2014, 13:16   #33
Thanked: 27,207 Times
The Automotive Research Association of India (ARAI) has proposed that two-wheelers with engine capacities more than 125 cc should be equipped with ABS.
Link to Team-BHP News Article
Aditya is offline   (1) Thanks
Old 19th December 2014, 13:59   #34
karzzexped's Avatar
Thanked: 57 Times
So I guess there will be a sizeable clump of 125 cc bikes after 2017. These bikes will dominate the two-wheeler buyer's segment and will be the neo-150 cc at that point, just like how sub-4m sedans are now.
karzzexped is offline
Old 19th December 2014, 14:09   #35
saket77's Avatar
Thanked: 5,039 Times
Quite incompetent on part of ARAI. Why should bikes only over 125 CC should have ABS? Most 100 CC bikes are capable of clocking about 100 KMPH anyway. I would call this again half baked policy. Will end up being a mockery like the ground clearance rule & sub 4m rule.
saket77 is offline
Old 19th December 2014, 18:57   #36
Thanked: 372 Times
Atleast there will be some ABS bikes. Seeing the economies of scale, they might decide to offer it on the <125cc bikes as an optional extra.
H_Dogg72 is offline
Old 19th December 2014, 20:38   #37
Thanked: 166 Times
What good is this rule if they cannot afford to fix all the roads in this country?
Nithesh_M is offline
Old 20th December 2014, 00:19   #38
Thanked: 227 Times
These are all pieces of the jigsaw puzzle. It's better to look at it as things getting fixed one step at a time. Else nothing will ever get done.
anilp is offline
Old 22nd December 2014, 09:27   #39
nishsingh's Avatar
Thanked: 515 Times
A little off-topic, but this means that a few (semi?) premium bikes like the Ninja 300 would start coming with ABS. That would definitely change a few things higher up in the market as well.
nishsingh is offline
Closed Thread
Kerala High Court moots Banning Sarees on Two Wheelers Steeroid Motorbikes 55 27th March 2013 11:03
Plan studied to make car phone kits compulsory in Dubai Parm The International Automotive Scene 6 12th November 2011 10:42
ABS - A plea to make this a compulsory standard absynthguzzler Technical Stuff 31 8th August 2008 12:01
Government to make crash tests mandatory for all vehicles deepaktpatil The Indian Car Scene 3 18th September 2007 11:40
