Go Back   Team-BHP > Team-BHP > Road Safety > Ride Safe
Old 10th May 2018, 18:35   #2611
dass's Avatar
Thanked: 442 Times
Default Re: Which Helmet? Tips on buying a good helmet
Which is the best place to buy a original LS2 helmet here in Bangalore, anything close to marathalli would be preferred or if the place comes highly recommended for authentic stuff, I do not mind travelling far as well.
dass is offline   Reply With Quote
Old 12th May 2018, 10:44   #2612
Who_are_you's Avatar
Thanked: 25 Times
Talking Re: Which Helmet? Tips on buying a good helmet
My new lid SMK Twister - Unicolor.
  1. Visor has pin lock with the anti-fogging feature. Not tested yet.
  2. ECE Certified weighs around 1.4 Kg
  3. It comes with dual visor and I can wear spectacle with black shades down.
  4. Dedicated slot for Bluetooth headset.
  5. No wind noise even at triple digit speed.
  6. Got it for 4,000 INR. VFM ?
A dedicated slot of fitting Bluetooth headset.
ECE Certified. Air vents: 2 in the back, 1 in front and 1 at the top.
Who_are_you is offline   Reply With Quote
Old 12th May 2018, 13:40   #2613
KK_HakunaMatata's Avatar
Thanked: 466 Times
Originally Posted by Who_are_you View Post
My new lid SMK Twister - Unicolor. [list=1][*]Visor has pin lock with the anti-fogging feature. Not tested yet.[*]ECE Certified weighs around 1.4 Kg[*]It comes with dual visor and I can wear spectacle with black shades down.[*]Dedicated slot for Bluetooth headset.[*]No wind noise even at triple digit speed.[*]Got it for 4,000 INR. VFM ?[/LIST
I also bought a twister 2 weeks back as an additional helmet and like the features given for the price, it's a very good entry level helmet I think. Got it for 3900. It's very well worth the price.
Only problem with the helmet is, at speeds above 45/50, you can feel a gush of air/noise from the left side of the helemt, which is coming from the gap at the internal visor switch. Just try and cover the bottom side of internal visor switch with thumb and you can make out that the air/noise stops immediately.
Will try and fix this thing in the coming days, it is quite annoying on the go.
Otherwise I like the fit and finish of the helmet and also the internal visor and pin lock given.
KK
KK_HakunaMatata is offline   Reply With Quote
Old 22nd May 2018, 12:15   #2614
Mafioso's Avatar
Thanked: 98 Times
any place in bangalore or online where we can source helmet inner liners for MT helmets? After 4 years the liners have worn out and lot of wind noise seeping through it.
Mafioso is offline   Reply With Quote
Old 22nd May 2018, 23:48   #2615
nikhn's Avatar
Thanked: 131 Times
Hi. I had written to Spartan Pro Gear regarding inner liners for my MT helmet of 4 years as well. They are charging ₹1650 for the inner liners only. I felt it's quite expensive for a 4 year helmet which would also reach it's usable life of approximately 5 years. Hence ended up buying a new helmet itself.
nikhn is online now   Reply With Quote
Tips to drive better: But are the tips correct? Spinnerr Technical Stuff 11 22nd June 2009 13:00
Need Help/Tips in Buying Used Lancer in Hyderabad rajatkumar Sedans 11 19th February 2008 17:15
Tips needed for buying a Used Zen mithun Hatchbacks 12 30th August 2007 01:56
Secondhand Avenger buying tips realmumbhai Motorbikes 7 28th September 2006 09:37
