Go Back   Team-BHP > Team-BHP > Road Safety
Old 21st September 2016, 12:16   #61
Thanked: 49 Times
Default Re: Global NCAP: Updated Renault Kwid and Honda Mobilio tested
Originally Posted by AutoNoob View Post
Am I the only one smelling something foul ?? The scoring for Renault KWID for Adult Occupant Protection is 0.00 out of maximum possible 17.00 points. As per NCAP Rating system, the score becomes zero if chest compression on impact is severe. GNCAP noted the same for KWID : "the protection to the chest due to high chest compression was poor and the passengerís chest received weak protection as well". Yet it is given1-star.
As per my limited understanding of NCAP system, no star should have been given (similar to Honda Mobilio without Airbags).
The reason for giving 1 star is that, in a Kwid there is good protection for the head (Green Color) against Mobilio's poor protection for the head (red color).
Global NCAP: Updated Renault Kwid and Honda Mobilio tested-mobilio-head.jpg
rselva is offline   (2) Thanks Reply With Quote
Old 21st September 2016, 16:23   #62
AutoNoob's Avatar
Thanked: 278 Times
I humbly but strongly disagree with this statement.
Overall score for frontal impact (full / offset) is taken as the Worst score from : (Head contact with CRS + Head Excursion + Head Exposure) + Score from Neck Tension + Score from Chest.
As per Euro NCAP 2015 rating system, following minimum scores are needed (out of max. 17.00) for respective star ratings for Adult Occupant Protection :
***** - 80% (13.6)
**** - 70% (11.9)
*** - 50% (8.5)
** - 30% (5.1)
* - 20% (3.4)
Since, in KWID, high chest compression was observed, the Chest score was 0.00, therefore overall score was 0.00. In such a scenario, how it got 1-star, I can't understand.
For year 2016 & 2017, the score requirements have been made further stringent by Euro NCAP (GNCAP team might still have rated the cars based on earlier point system, as they are last year's models) :
***** - 80% (13.6)
**** - 70% (11.9)
*** - 60% (10.2)
** - 50% (8.5)
* - 40% (6.8)
References :
1.
Sharing the following document for everyone's reference. I hope this would be helpful.
Global Automotive Safety Regulations in Nutshell - January 2015
Source : http://www.wissenbaumllp.com/download.aspx
Direct PDF Link : Global Automotive Safety Regulations in Nutshell
Refer pages 32 to 39.
2. Euro NCAP - Assessment Protocol - Overall Rating Refer pages 5 to 8.
AutoNoob is offline   (2) Thanks Reply With Quote
Old 21st September 2016, 17:18   #63
Thanked: 49 Times
***** - 80% (13.6)
**** - 70% (11.9)
*** - 50% (8.5)
** - 30% (5.1)
* - 20% (3.4)
Since, in KWID, high chest compression was observed, the Chest score was 0.00, therefore overall score was 0.00. In such a scenario, how it got 1-star, I can't understand. .......
How do you know the Chest compression score was zero? Have attached an excerpt from the excel sheet used for NCAP rating. As you can see there are lot of variables which would explain a score above zero. Unless you have access to these variables' scores, you can't suggest the rating is influenced by Renault ( I don't know what else your statement implies).
Source: From http://www.euroncap.com/en/for-engin...g-information/
rselva is offline   Reply With Quote
Old 21st September 2016, 17:46   #64
AutoNoob's Avatar
Thanked: 278 Times
I am aware of this excel sheet and its working. And I agree that I don't have any reference for the point you raised. However, I arrived at that conclusion as the injury pattern on rest of the body is better than chest and there is no other negative modifier specified for AOP.
Now, even if my conclusion on method to arrive at zero score was incorrect, the fact remains that the score is zero. In such a case, how 1-star can be assigned?? Minimum score of 3.4 (as per 2015 rating system) is required for that.
I might have inadvertently suggested something similar, but that was more out of astonishment based on two contradicting facts [0.00 score, 1-Star] and nothing else. I do not have any evidence to point finger at anyone.
AutoNoob is offline   Reply With Quote
Old 21st September 2016, 18:04   #65
CrAzY dRiVeR's Avatar
Thanked: 19,844 Times
Either ways, a rating of zero AOP and a one star rating doesn't make much sense to me. It's like saying this is a better way to die than hitting the head on the steering. Isn't it?
By the way, quite surprised that Global NCAP give so many chances for a company to test one single car from their lineup again and again.
Old 26th September 2016, 03:52   #66
RSR
RSR's Avatar
Thanked: 4,549 Times
Am I the only one smelling something foul ?? The scoring for Renault KWID for Adult Occupant Protection is 0.00 out of maximum possible 17.00 points. As per NCAP Rating system, the score becomes zero if chest compression on impact is severe. GNCAP noted the same for KWID : "the protection to the chest due to high chest compression was poor and the passenger’s chest received weak protection as well". Yet it is given 1-star.
There was a mistake in the earlier pdf, I think. Global NCAP have uploaded an updated pdf with the correct points for AOP, and it explains why the Kwid (IV) with a driver airbag was given a 1* G-NCAP rating for AOP (by scoring 8.28 points out of 17):
Global NCAP: Updated Renault Kwid and Honda Mobilio tested-screenshot_20160926031538.jpg
Full report: http://www.globalncap.org/wp-content...ER-Airbags.pdf
Not really that surprising, since Global NCAP's aim is to make cars safer for occupants. So any manufacturer who willingly carries out improvements would get additional chances (I believe the manufacturer partly funds subsequent tests i.e. reimburses the cost of purchase for the improved versions). The Polo got an additional chance after airbags were made standard, the Mobilio got a variant with dual airbags tested after the initial car got a 0* rating etc.
Although the 1* rating for a car with a driver airbag is still worrisome, Renault have indeed shown interest to make improvements. Even in the videos, the difference between the Kwid (I) and Kwid (IV) is very obvious. I still think Renault have not done enough! The reinforcements have been added only to the driver's side and the driver airbag is still optional only on the top variant.
I would have preferred a test of the Brio/Amaze by Global NCAP instead of the Mobilio. The Brio & Amaze have their top speeds electronically limited to 140 kmph (for both petrol & diesel versions), while the Mobilio & BR-V don't have such a restriction on top speed - something that's very strange indeed.
In fact, I'd love to see every car in India whose base variant costs below 1 million rupees (ex-showroom) being subjected to the Global NCAP treatment!
RSR is offline   (3) Thanks Reply With Quote
Old 26th September 2016, 06:17   #67
On a serious note though, the front end of the Mobilio is structurally identical to the Amaze & Brio. So it does tell us a little bit about the smaller cars.
Originally Posted by Rajeevraj View Post
On the plus side, with a 3 star for a Mobilio with airbags, one can safely assume that the rest of the portfolio will score equal or better considering the Mobilio appears to have the most cost cutting involved with respect to build quality.
One point that was noticed very recently in the Jazz thread was that the petrol versions of the Jazz doesn't have pre-tensioners fitted on the vehicle. It is only present on the diesel variants and only for the driver seat, as clarified by Honda customer care.
Pre-tensioners are mentioned clearly for the Mobilio, but I don't see them mentioned for Amaze or Brio. And seeing the Jazz effect, makes me wonder if those have it. Would be difficult for these two products to achieve a 3 star rating without it, as we have already seen with the Kwid how much of a difference the pre-tensioner makes.
CrAzY dRiVeR is offline   (3) Thanks Reply With Quote
Old 26th September 2016, 11:20   #68
heavenlybull's Avatar
Thanked: 112 Times
The Amaze and Brio websites mention "Front Seat Belt Pretensioner with Load Limiter" in the top 2 variant of Brio and its optional in lower variants on the Amaze. Are we to assume then that they are present only on the driver side?
heavenlybull is offline   (3) Thanks Reply With Quote
Old 17th November 2017, 23:55   #69
Thanked: 341 Times
Made in Brazil Renault Kwid scored Three-Star Rating in Latin NCAP.
The hatchback showed adequate frontal protection and marginal side impact protection, though with weak protection to the chest of the adult, resulting in three stars.Child occupant safety was also deemed adequate thanks to the child seat mounted on the Isofix seat mounts and Top Tether anchorage. However the lack of an airbag disconnection switch in the front passenger area and lack of 3-point seat belts brought the rating to a three out of five. Kwid in India misses out on the Brazilian versions’ passenger side front airbag and side airbags, along with the Isofix child seat mounts.
link
Last edited by Aditya : 19th November 2017 at 23:09. Reason: Latin NCAP, not Global
Highh5 is online now   Reply With Quote
Toyota Etios awarded 4-Stars in Global NCAP Crash Test technicalytuned Road Safety 53 2nd January 2018 19:03
Maruti Swift, Datsun Go fail Global NCAP tests too... rajess_in Road Safety 644 10th June 2017 10:52
Indian Nano, Alto, Figo, i10 & Polo FAIL Global NCAP Safety Test volkman10 Road Safety 348 15th May 2017 12:52
Global NCAP tells Indian carmakers to adopt UN car safety standards a4anurag Road Safety 9 19th April 2016 07:37
Indonesia: Updated Honda Mobilio launched; gets all-new interior Tushar The International Automotive Scene 7 1st February 2016 20:51
