Go Back   Team-BHP > Team-BHP > Road Safety
Old 12th August 2015, 19:52   #571
Thanked: 2,394 Times
Default re: The ABS discussion thread
Originally Posted by DerAlte View Post
The ABS ECU *doesn't calculate vehicle speed* - it doesn't need it.
Any need for 'Estimated Vehicle Speed'?
On another matter, below a (pretty low) threshold, I believe it's common to switch off ABS.
Sutripta
Sutripta is offline   (1) Thanks Reply With Quote
Old 12th August 2015, 20:56   #572
im_srini's Avatar
Thanked: 397 Times
Post re: The ABS discussion thread
Originally Posted by Viju View Post
Just posting a capture from the Ritz Owner's Manual Page 64 for reference.
PS : This need not be the case for all OEMs / models.
All they are saying is that the ABS will not work if the vehicle speed is below 10 km/h.
I'm with Viju on this, remember reading somewhere ( I think the Gen-1 Swift's Service Manual ) that the minimum speed for the ABS is 11 Kmph.
Initially was under the impression that there was a minimum "resolution" for the ABS reluctor ring + sensor combo ( sort of like that with mouse wheels ).
The Swift came with 165/80-R14 wheels, which means that at 10 Kmph, the wheel RPM is ~ 1.4 RPS ( is 1 RPS at 7 Kmph ).
But then came across this IEEE document which I think indicates the real reason.
RotationalSensors.PDF
To quote from the document [ Page 19 ] :
Saturation Effect
There is also an important saturation effect here.
If the angular speed is too small compared to the sample interval, then (10) collapses, since no pulse will be available.
This gives a lower bound on the sampling interval for a given minimum speed.
As a practical consequence of this, the ABS has to be turned off for low speeds.
A remedy would be to sample the analogue sensor signal, rather than converting it to a square wave, and use the phase information, but this would affect the price of the sensor.
Disclaimer : I'm no automotive engineer, hence 'am completely out of depth here & could be barking up the wrong tree...
im_srini is offline   Reply With Quote
Old 13th August 2015, 13:48   #573
DerAlte's Avatar
Thanked: 2,879 Times
... I know of multiple models in which the transmission output speed was unreliable ...
:O Difficult to believe it is not reliable - it is a simple reluctance sensor near the output drive shaft.
... they are just giving an approximate vehicle speed below which the WSS pulses may no longer be reliable for the functioning of the ABS. ...[/quote]
Originally Posted by im_srini View Post
I'm with Viju on this, remember reading somewhere ( I think the Gen-1 Swift's Service Manual ) that the minimum speed for the ABS is 11 Kmph. ...
The Swift came with 165/80-R14 wheels, which means that at 10 Kmph, the wheel RPM is ~ 1.4 RPS ( is 1 RPS at 7 Kmph ). ...
I used to drive a rental VW Jetta (with ABS) in Germany, 20 years back. Everyone was headed home early one day as there was a weather announcement of impending bad weather. All of a sudden it started snowing heavily. First time experience in those conditions, and I was crawling (with heart in my mouth) looking for a slot to park the car on the street near my house. The speed was really low - low enough that the speedo needle was just intermittently flicking above 0. Braked hard (pushed pedal suddenly) when I saw in the ORVM someone pulling out, and promptly ABS acted - causing a loud shudder through the brake pedal and making me almost jump out of my skin.
The lower limit is just an arbitrarily declared figure to put the monkey on someone else's shoulder.
Any need for 'Estimated Vehicle Speed'? ...
Not sure I understand why it would be required, but no, Prof!
... below a (pretty low) threshold, I believe it's common to switch off ABS. ...
Manually? There is no switch, unless a switch is manually added by vehicle owner in his off-roader. ABS doesn't act on a wheel only if that wheel's sensor is faulty. There is no other way to switch ABS off.
Old 13th August 2015, 14:00   #574
batterylow's Avatar
Thanked: 711 Times
I am curious why most bikes equipped with ABS provide a facility to switch it off, while cars only have an ESP off switch.
To enable pulling off stunts maybe!
batterylow is offline   Reply With Quote
Old 13th August 2015, 14:02   #575
Viju's Avatar
Thanked: 1,694 Times
Unfortunately, I cannot name all the models, but an example in India is the A-Star Automatic. I am talking from first hand experience as I am involved in ABS/ESC development for passenger cars and motorcycles for a living.
Spot on! This is the fact. These are all disclaimers to avoid market claims. I just didn't want to put it out bluntly.
There is no manual switch for ABS in passenger cars, unlike for ESC/ TCS (many motorcycles do have ABS ON / OFF switches though). But to switch ABS off, all you have to do is open the fuse box cover and remove the correct fuse for the ABS pump motor. The ABS warning lamp will come ON and ABS will be disabled.
What Sutripta was talking about was turning off the ABS through the software logic below a certain speed which again I personally don't think, is the case. Even at <5 kph, if there is a big enough slip (an example being hard braking on wet ice), ABS control will start.
Viju is offline   Reply With Quote
Old 13th August 2015, 14:07   #576
Thanked: 129 Times
Can ABS be fitted into a non ABS vehicle? I have a 2013 Dzire VDI which did not have ABS, however the newer model of Dzire VDI has ABS.
ILTDrive is offline   Reply With Quote
Old 13th August 2015, 14:10   #577
Thad E Ginathom's Avatar
Thanked: 8,374 Times
I tried the ABS on my Rover 620 (British-built Honda). It was on ice, and less than walking speed. Juddering in the foot told me that it was working.
As I understand it, ABS operates just before wheel lockup, to prevent the wheels becoming locked. It must work then, when the wheel rotation speed is almost zero. I don't see any relevance in the original speed of the car at the moment that the breaks are applied. Am I missing something?
Old 13th August 2015, 14:16   #578
batterylow's Avatar
Thanked: 711 Times
Its not advisable to retrofit ABS. Factory fit is the best bet!
Old 13th August 2015, 14:29   #579
DerAlte's Avatar
... I am involved in ABS/ESC development for passenger cars and motorcycles for a living. ...
Jolly good - we need more people like you pitching in.
Which company, may one ask?
It is possible if the base model is the same - theoretically. The snafu is that Suzuki will charge you for all the components at Spares rates, making it economically unviable!
... As I understand it, ABS operates just before wheel lockup, to prevent the wheels becoming locked. It must work then, when the wheel rotation speed is almost zero. I don't see any relevance in the original speed of the car at the moment that the breaks are applied. Am I missing something?
You are missing nothing at all, sir!
The key criteria is the rate at which the (rotating) wheel is slowing down. The ABS ECU just calculates angular speed difference every few milliseconds. If the deceleration rate is higher than a trigger point (which is a pointer to impending wheel lockup), ABS acts. It has nothing to do with the speed of the vehicle.
DerAlte is offline   (1) Thanks Reply With Quote
Old 13th August 2015, 14:30   #580
Chetan_Rao's Avatar
Thanked: 4,312 Times
ABS works on the (sensor-measured) likelihood of losing traction and locking wheels, not driving speeds! Someone better acquainted with the technicalities can explain the exact mechanism, but that's the gist of it.
If an ABS-equipped vehicle loses traction at single-digit speeds, ABS will still kick in.
Chetan_Rao is offline   Reply With Quote
Old 13th August 2015, 14:35   #581
Viju's Avatar
Jolly good - we need more people like you pitching in. Which company, may one ask?
Sure. I currently work for Continental Automotive Corporation, Japan as a Vehicle Test Engineer for Motorcycle ABS.
Viju is offline   (2) Thanks Reply With Quote
Old 13th August 2015, 14:49   #582
itwasntme's Avatar
Thanked: 1,721 Times
In my Cruze, ABS definitely works regardless of speed.
Just this morning outside my sons' school, I parked at around 5 km/hr and the ABS immediately kicked in as there was a layer of very slippery mud.
My overall take is that even at very low speeds on icy/muddy roads, ABS will avert the common rear-ending incidents because 99% of Indian drivers don't know how to maintain a safe distance in such conditions.
itwasntme is offline   Reply With Quote
Old 13th August 2015, 15:08   #583
commonman's Avatar
Thanked: 133 Times
One of my friend's Ritz ZXi (ABS) suddenly lost the brakes on a downhill as she was unable to stop by pressing the pedal.Some how she stopped the car and she went in to tears as there were school children in front of her car.She couldn't bear the fact that, if something had happened to those kids, how will she live with that. Later on, upon inspection,we found that the car had no fuel and may be because of that, the vehicle had lost the brakes. Even if the vehicle is switched off,there will be some amount of brake.Then why did this happen? Currently, there is no issue with the brakes.The car is braking and running good.Can the experts comment ?
commonman is offline   Reply With Quote
Old 13th August 2015, 15:14   #584
vibbs's Avatar
Thanked: 869 Times
It is a little confusing. You say that there was no fuel in the car. Does this mean that the car was switched off and coasting downhill?
All vehicles now a days have power assisted brakes. Which means the brakes will cease to function/ become extremely hard if the engine is switched off. The residual vaccum in the system may help you with some braking action initially but as you keep pumping the brakes you will lose that too in no time. Only hope might be to literally stand on the pedals.
It is highly unsafe to coast downhill on a car with no power.
vibbs is offline   Reply With Quote
Old 13th August 2015, 15:48   #585
saket77's Avatar
Thanked: 5,038 Times
Although the advise by Vibbs is spot on, but even if the car is out of fuel, but rolling downhill in a gear (not advisable to do so), the engine will keep generating the required vacuum for the brakes as the engine will be driven through the rotation of wheels through the transmission. However, the brakes would be lost if the transmission is set to neutral.
Saket
saket77 is offline   Reply With Quote
The DATA Card and USB Modem discussion thread (Reliance/Airtel/Tata) sk456 Gadgets, Computers & Software 720 11th December 2015 09:00
Windows Vista Discussion Thread normally_crazy Gadgets, Computers & Software 663 2nd December 2014 02:18
Chennai General Discussion Thread slipstream The Team-BHP Meet Section 11 9th August 2006 15:43
