Old 13th April 2016, 13:38   #466
Thanked: 81 Times
Default Re: The mega "Road Updates" thread
Preferred route now is Jaipur - Kota - Ratlam - Vadodara - Thane - Hubli - Bangalore.
You can check with most of the folks on HVK forum where they have taken this route. This helps you avoid the busy sections between Vadodara - Ahmedabad - Himmatnagar - Udaipur sections.
So via Ratlam is the way to go.
Parag Bhai, thank you for this. I am the one who will be doing this route at the end of April, early May. We will have 2 vehicles with us, the Cruze and the Ecosport. I want to reach Bangalore at the earliest after departing Jaipur. How long should it take to reach Bangalore using the Jaipur - Kota - Ratlam - Vadodara - Thane - Hubli - Bangalore route?
I assume this would mean 2 days of driving with 1 night halt. Where should we halt? I will be travelling with my wife, 2 kids (5 and 3) and in-laws. Father in Law is 66 and have 3 sis-in-laws. So we need a decent place to stop. Preferably 3 or 4 star accommodation.
You valuable inputs will be highly appreciated.
SumitB is offline   Reply With Quote
Old 13th April 2016, 13:52   #467
ampere's Avatar
Thanked: 8,168 Times
Originally Posted by couswheels View Post
Parag, isn't this a longer route instead of coming via Dhule - Nashik to Thane?
If thats the case, as you mentioned earlier, one might as well take the Dhule-Pune option and bypass Bombay. That would much easier an option than going to Bombay. Looks like thats one of the reason, many use the central India route as, it tends to avoid many cities.
ampere is offline   (1) Thanks Reply With Quote
Old 13th April 2016, 20:39   #468
Thanked: 9,259 Times
Isn't Ratlam-Baroda via Godhra/Dahod ? Remember reading it was quite un-safe at nights. And quite many sections were bad? Looks like that has changed?
Ratlam - Baroda via Dahod. The route via Godhra is still work in progress and not fully done although this has improved a lot. Last I took the Godhra route was when we returned to Bangalore from Indore and it was very bad.
Agreed. I kept thinking Vadodara/Mumbai to be the ultimate destination when it is Bangalore .
So the route would be : Jaipur Kishangarh Chittorgadh Neemuch Mandsaur Ratlam Dahod Dhule Malegaon Shirdi Pune Bangalore
Option 1:
With the Ratlam - Dhule option your break-up should be:
  • Jaipur - Dhule - Full day drive
  • Dhule - Hubli - Full day drive
  • Hubli - Bangalore - 6 Hours max
Option 2:
With the usual route i.e : Jaipur Kishangarh Chittorgarh - Udaipur - Himmatnagar - Ahmedabad - Thane - Pune - Hubli - Bangalore your break-up will be:
  • Jaipur - Vadodara - Full day drive
  • Vadodara - Belgaum - Full day drive
  • Belgaum - Bangalore - 7-8 hours max
Both these routes more or less will take the same time. The choice should not be the distance or the route but what you want as must have (facilities) and what you want to avoid (crossing too many urban areas)
Option 2 will be the one to opt for if you want facilities all the way. That road will not disappoint you in terms of places to break and you will be greeted by the them frequently.
Option 2 would also mean you do the busy Udaipur (bypassing itself is a time consuming task) - Ahmedabad - Baroda - Surat - Vapi - Thane sections. The good thing is that there will be a lot of company for you on this route at good pace. The bad thing is the time of the day you pass each of these locations. That can at times be irritating. Else Ahmedabad - Thane is an easy 7 hours drive without even exceeding 100 KMPH.
I have responded with both the options. You must halt twice. No choice there and considering the crowd you are traveling with, I will suggest that. Remember that summer is a wrong time to drive at nights due to truckers who prefer nights because of the heat.
For halts here are my suggestions based on what I am aware of. Based on your progress there are chances that you are either too early or too late that you may want to halt few 100 kms before or after:
  1. Dhule - Got no clue & hence won't suggest any (check online)
  2. Satara - Mahendra Executive
  3. Kolhapur - Hotel Opal (A popular one here although others might be good too, Located inside city but)
  4. Belgaum - Sankam Residency
  5. Hubli - Clarks Inn
  6. Davanagere - Sankama Hotel
  7. Davanagere - Apoorva Resorts
Between the 2, If I were you & with family and elders with me along with another car in tow and the fact that I am not a regular on this circuit I will stick to the Western India route & may be return via the Central India route.
Actually passing Bombay has never been a pain at all. The real pain is when you do this at Peak Hours or exactly when you enter Mumbai after entry for trucks is allowed. Else its mere 60-75 minute affair.
Ghodbunder Junction after Vasai Creek Bridge where you make an entry to Mumbai till Thane is a brilliant 16 kms road that now has all functional flyover including an interchance loop at Kapurwadi that helps you join onto Eastern Expressway without stopping.
The Central India route like you said helps one avoids passing cities.
With Malegaon - Shirdi - Pune route you have to drive in thick traffic all the way till you cross Pune too.
paragsachania is online now   (3) Thanks Reply With Quote
Old 13th April 2016, 20:42   #469
Thanked: 81 Times
Parag Bhai, I am indebted. Thank you!
By the "Western India Route", you mean the Jaipur - Kishangarh - Chittorgarh - Udaipur - Himmatnagar - Ahmedabad - Thane - Pune - Hubli - Bangalore route?
SumitB is offline   (1) Thanks Reply With Quote
Old 13th April 2016, 20:45   #470
That is exactly what I meant. Central India will be Ratlam-Dhule- Malegaon-Pune.
From Pune its common for both the options.
paragsachania is online now   (2) Thanks Reply With Quote
Old 13th April 2016, 20:49   #471
Thanked: 81 Times
Any hotel recommendations for Vadodara?
Old 13th April 2016, 20:59   #472
Should fit into 3/4 Star and is located bang on the highway.
Banyan Paradise Resort.
The how can we forget Plazzo that is one of the most famous hotels on Baroda Bypass and exactly opposite to the Banyan Paradise.
Old 16th April 2016, 16:09   #473
Thanked: 11 Times
Any ideas regarding road condition from Khamgaon to Amravati via Akola?
nityaya is offline   Reply With Quote
Old 18th April 2016, 05:35   #474
nileshch's Avatar
Thanked: 365 Times
That should be NH6. It is a two-lane highway. I haven't travelled beyond Shegaon on that route but I am thinking it should be ok to good surface.
nileshch is offline   Reply With Quote
Old 18th April 2016, 06:47   #475
Thanked: 686 Times
I am doing a Chennai - Hyderabad - Nagpur drive starting tomorrow. Any recommendations or follow just Google maps through NH7?
I want to do night halt somewhere after Hyderabad near Nirmal, anyone know where I should? I would like to get into Nagpur by noon on 20th.
gsurya is offline   Reply With Quote
Old 18th April 2016, 07:33   #476
ampere's Avatar
Here is the last I remember reading about it.
http://www.team-bhp.com/forum/travel...ml#post3553371 (A road trip from Chattisgarh to Vibrant Goa (Bhilai-Pune-Goa-Hyderabad-Bhilai))
May help, to check with @sommos.
Old 18th April 2016, 11:45   #477
Thanked: 82 Times
You will find many stay options at Nizamabad. But you have to deviate from the NH 7 for about 15 kms.
Very limited options at Nirmal. Hotel Mayuri Inn is a good option, few bhpians have given positive feedback.
Landkruzer is offline   Reply With Quote
Old 18th April 2016, 14:18   #478
Thanked: 11 Times
The route taken by @sommos is the regular Mumbai - Pune - Nagpur route. I need to know about the road condition from Khamgaon to Shegaon and then from Shegaon via Akola to Amravati. Also any suggestions for night stay at or near Shegaon. This is my first visit there, I have enquired regarding Anand Vihar A/C room which are available but not sure about the cleanliness of the room and the toilets.
Old 6th May 2016, 10:20   #479
NPV
NPV's Avatar
Thanked: 4,292 Times
Bangalore - The Elevated Corridor Project proposed by the Bangalore Development Authority (BDA) has been approved by the state government as per this report (and as per their "highly placed" source ).
The state government has given the green signal for the proposed alignment of the Elevated Corridor Project of the Bangalore Development Authority (BDA). The nod came after a high-level meeting between top BDA and government officials on Wenesday night, said a highly placed source.
Source:With Govt Nod, Elevated Corridor to be a Reality
NPV is offline   Reply With Quote
Old 6th May 2016, 11:00   #480
inder's Avatar
Thanked: 32 Times
Hi,I am planning a holiday in Coorg. Wanted to know if I can drive from Kutta (south Coorg) to Hunsur via Nagarhole forest in my own car. Have not been getting concrete info. Some websites mention have to cross the forest before 6pm.
inder is online now   Reply With Quote
OE Replacement - Navigation System for Cruze "Mega Audio" lawyer In-Car Entertainment 46 22nd June 2014 18:39
The Mega Auto Expo 2014 Thread: General Discussion, Live Feed & Pics Irish The Indian Car Scene 266 17th February 2014 20:23
NCR MEGA Meet on 14th March 2008: "Dhoondte Rahe Jaaoge" extreme_torque The Team-BHP Meet Section 83 10th March 2009 22:28
Mumbai Speedrun MEGA National Meet @ Sea Lord! 17th Feb 2007 - List Updates on Pg 20 manson The Team-BHP Meet Section 430 26th February 2007 22:52
