Old 9th June 2012, 11:42   #16
damanshaheed's Avatar
Thanked: 54 Times
Default Re: Kolkata - Siliguri route via Dumka, Bhagalpur. Avoiding NH34
A small heads-up -
Bhagalpur bye-pass is functional now. After crossing Vikramshila Setu and taking the right for Bhagalpur town, one may spot a BP fuel outlet. Alongside it, is a left turn which will take you away from Bhagalpur's madness & chaos.
Post 20th June, I shall post proper pictures of the other way and its directions.
Hey Sheel,I am leaving for Siliguri from Noida Sunday Morning, 10th. After a night halt at Varanasi, I was initially planning to take the Arrah - Patna route and join NH31 at Bhaktiarpur, but with the situation in Arrah off late, am a little worried, considering my wife and kids are travelling with me. SS-Traveller suggested you would be the right guy to ask. What's your take? Alternatively I could also bypass Varanasi and carry on all the way to Gaya for the night halt and take the Gaya - Mokameh highway to join NH 31. What is the general condition of the above mentoined highways and is it okay to carry on till Gaya. I would not make it before 8-9 at night. Or any alt route that you might suggest.
damanshaheed is offline   Reply With Quote
Old 11th June 2012, 23:40   #17
1100D's Avatar
Thanked: 2,503 Times
Originally Posted by 1100D View Post
this time will go to Siuri (From Bolpur) through Sattore.
However, I will try the more direct route from Bolpur to Siuri, without needing to go to Prantik etc (though the Prantik road is very good visually)
Just did this route this Sunday
However before describing this route, will first try to address the following, have been asked by others as well so it will help to document it.
Originally Posted by hvkumar View Post
Assuming you turn off at Bardhaman & go via Bolpur, where does one exactly turn off at the expressway
The turn-off (right) for the Bolpur road at Bardhaman from the DGP expressway comes up after around 6kms as you are flying past the Bardhaman PWD building
(pink coloured building). This turn comes up quite fast as the expressway curves to the left. There is an opening on the right. One needs to take this
opening to the right, cross the expressway, turn right again and within 100 meters turn left onto the Bardhaman Bolpur route (NH2B).
The right turn at Bardhaman from the NH2/DGP Expressway comes up at
26.4 kms from Palsit tolltax
51.1 kms from COCO BP Azad Hind Dhaba
6.4 kms from passing the Purtobhavan (wrongly referred in my previous post as PWD building). This building
The entry point is first marked by the transmission line (excuse the haziness of the pic)
The road curves to the left, masking the entry point, but this is what it progressively looks like
a little more closer
Once the right turn is taken, within 50 yards another right turn has to be taken as the vehicles are taking in the pic
The moment the previous right turn is taken, a road on left becomes evident(within 100 yards), though hid from view (the boards indicate that something is there)
A little closer and the wide road makes itself visible
Just 4 kms from this point is the level crossing (I had to wait 5 mins for the gate to open as 3 trains passed in that time)
Once beyond the level crossing this is how the road looks
Watch out for two culverts which are rather narrow and at an angle to the road, if there is a vehicle on the opposite side, be sure as to what it is about to do, on the culvert the space is very restricted for two vehicles to pass side by side. However this space restriction is not evident looking at the angle these make with the road. The second of these culverts at 15.5 kms from Level crossing at Bardhaman
Guskhara comes up at 24 kms from Level crossing at Bardhaman
There are two massive bumps (for low ground clearance vehicles) at 33.7 kms from Bardhaman LC and 9.6 kms from Guskhara Junction
Another aspect of this road, although the surface was smooth, are these culverts that are about a foot higher from the road and these can actually make vehicles go airborne. So if you like that, this road is promising.
As one nears Bolpur (towards the end of this road)
The entry into Bolpur on this road happens at Shibtola, here is a pic of the crossing (Shibtola crossing/more)
The road straight ahead is the one I had described earlier, but has now been completely metalled
The road ends in a sort of junction after 48 kms or so. (On google maps its going to look like a T junction, but it is not, its a proper 4 way junction).
Going straight (though the road does not come up on G-map) is a village, gravel road that meanders through huts and reaches the Sriniketan market , the
startpoint of the Bolpur-Siuri route via Sattore. This road is the one to enjoy in Richard Burns mode, more-so if your vehicle is rear wheel powered, min
was! However since its a proper village road, theres always thepossibility of chickens crossing.
and do you have to go through Bardhaman & Bolpur towns?
Take this road to go to Siuri, it takes 3.6 kms on this road to reach the Bolpur Siuri road junction (Sriniketan Bajar crossing/More). This junction looks like this, and you take the road straight ahead.
However the road on right (on the previous snap at Shibtola junction) takes one into Bolpur town/Rlwy station. (The road on left goes to Illumbazar)
And over the years a market grows around the Rly Stn. Ergo, to cross the line, one has to drive through the market. So the question
is is it possible to avoid it?
Sutripta
If you are talking about Bolpur, its yes, you can avoid the station area and is also recommended.
At the junction at NH2B (The Bardhaman Bolpur rd). There will be a wide road on left soon after it, take it. You will meet another junction, wide road, take
right, go straight till you cross the railway tracks.
Will take this road on right a bit to depict the way to avoid the Bolpur station area. This will be helpful if one needs to go to Prantik or Sainthia.
2.2 kms from Shibtola (once you have taken road on right at shibtola crossing coming from Bardhaman) is the Bolpur entry tax gumti. The tax is Rs 5. Right
after this toll is a road on left. This road is called the Kashipur Byepass.
Take this road and it goes for 2.7 kms and ends into a T-Junction.
The right will enable you to cross the railway tracks and then take the Bolpur-Prantik route.
The left will take you towards Illumbazar and the Sriniketan Bazar junction/more (for taking the road on right) for Siuri will fall 2.2 kms from this point. The junction to go to Santiniketan (ROR) will also fall on this route, its 1.5 kms from the T-junction.
This junction for taking the road on right to Siuri is the same as the one that comes up after you take the road ahead at the Shibtola crossing (after 3.6 kms). Only difference, coming from Shibtola directly one will keep straight, whereas coming from the Bolpur side, one has to take a right turn.
Now coming to the Bolpur Siuri route
3kms from the Sriniketan Junction at Bolpur comes up this makeshift brige, used to be a Bailey Bridge. This is the only section where the road surface is presently non existent.
Right after this on the left is the Kopai Resort.
Picture from the route
The smaller towns that come up are
Sattore about 7 kms from junction at Bolpur
Debagram about 10 kms from junction at Bolpur
Panrui about 15.7 kms from junction at Bolpur
Ultimately this road merges with SH6 at Purandarpur 24.7 kms from junction at Bolpur
Purandarpur town has narrow roads and although traffic isn't much but the busses travel real slow here and moreso if there are two crossing each other. However it is only for about half a km.
7.2 kms from the Purandarpur merge point is the Siuri Level crossing beside the railway station. One will have to drive through Siuri town to reach the other end of it, where it meets the NH60 (Panagarh Moregram highway) at 4.8 kms from the Siuri LC.
This is the view of the Bus stand area at Siuri, remember that this is a Sunday morning, its going to be more congested on other days.
Will describe the junctions inside Siuri as well for easy pass through the town.
2kms from the Siuri LC is this fork, keep right
1km from the previous fork is this fork, keep right
500 meters from the previous fork is this fork, keep right
NH60 is 1.3 kms from the previous fork. Go straight towards Tilpara Barrage Seorakuri (For Messanjore)
Now the big question is, does this route (Bardhaman-Bolpur-Siuri) help over Bardhaman-Bolpur-Illumbazar-Dubrajpur-Siuri?
1100D is offline   (3) Thanks Reply With Quote
Old 12th June 2012, 09:06   #18
Thanked: 2,394 Times
This is great! Now to digest so much information.
You should have borrowed the GPS from Sumitro.
Sutripta
Old 16th June 2012, 10:16   #19
Sheel's Avatar
Thanked: 5,640 Times
I am really sorry mate that I couldn't reply to your query.
There are two routes. I have suggested most folks taking the route via Allahabad - Gaya. But this time around due to bad sections on NH 31, you may take the E-W corridor section. That is via Gorakhpur - Muzaffarpur. It is a 4 lane road and is quite fast with less traffic as near Forbesgunj, approx 40 kms of the road is under construction, but still worth skipping NH-31.
The Muzaffarpur - Purnea section via Darbhanga is deserted with less traffic, very few fuel stations & dhabas. It would be better to do it @ daytime.
Had my wedding on 13th, hence I was off-line
Old 18th June 2012, 00:30   #20
1100D's Avatar
Sutripta
Righto! In hindsight, I should have refrained from going with my own flow and posted the two different items separately
1> Alternate route to Siuri
2> Roads within Bolpur to avoid going through the station area (this is no way connected to 1 above)
But then, whats done is done. Was doing another analysis, was expecting greatly different results but am perplexed by the similarity! (Later in the post)
Congrats man
Now coming to the question of the prefferred route to Siuri while going to Siliguri
Here are the alternatives
Howrah-Bardhaman-Panagarh-Illumbazar Siuri (last entry point)
Distance- 235 kms
drive time 3 hrs 7 mins
Highlights - involved driving on the opposite shoulder at panagarh for almost the entire town weaving in and out of the line, traffic was just building up early morning at Panagarh. During the day it takes about 20 mins at best to cross.
Howrah-Bardhaman-Bolpur-Illumbazar-Siuri (last entry point)
Distance - 229.2 kms
Drive time - 3hrs 1 min
Highlights - at the time this drive was made (afternoon) Panagarh would have taken atleast 20 mins extra to cross
Howrah-Bardhaman-Bolpur-Sattore-Siuri (last entry point)
Distance - 205.7 kms
Drive time - 2 hrs 54 mins
Highlights - driving at a relaxed pace from Bardhaman, so the time taken here can even be reduced further (without breaching comfort zone)
Now since the driving mood was different on the last two, its more like an apples to oranges comparison,
To be able compare properly, just the comparing of the distance and time taken from Siuri to Shibtola would be sufficient
Siuri-illumbazar-Bolpur (Shibtola) - distance 64 kms - time taken 52 mins
Pros- has no bottlenecks, wider roads, faster average speed
cons - longer route, many trucks (more prone to damage during monsoons)
Siuri-Sattore-Bolpur(shibtola) - distance 40.5 kms - time taken 47mins
Pros - shorter route (2/3) , takes 5 mins less, relatively scenic
cons - has a couple of bottlenecks at Purandarpur and Siuri
The LC at Siuri is infamous for gate-down time, once down. The corresponding LC on NH60 stays closed for shorter duration (being on a NH)
Moreover one needs to traverse the Siuri Bus stand, which will invariably be more congested on a weekday
These two runs done at the same time of the day.
Verdict - still confused!
Old 18th June 2012, 20:37   #21
Guess as long as the Ilambazar road is OK, use it.
The satellite pic (and map) shows a track from just south of the Siuri LC to NH60. Any views?
Sutripta
Old 21st June 2012, 17:42   #22
1100D's Avatar
[quote=Sutripta;2812991The satellite pic (and map) shows a track from just south of the Siuri LC to NH60. Any views?
Sutripta[/quote]
You mean this one, right?
Kolkata - Siliguri route via Dumka, Bhagalpur. Avoiding NH34-siuri-railway-station.jpg
Looked to be an unpaved one. However from the entry of it, it looked going through a bazar type congestion. Moreover it is also close to the crossing. So if you have vehicles backed up long enough at the crossing, you might not be able to reach it.
But then, this could be a good alternative, should the LC be gates-down. In that case one can take a left turn and then drive upto NH60 then turn right to fact the other crossing and hope that the gates are kept open there.
1100D is offline   Reply With Quote
Old 21st June 2012, 20:30   #23
Yes.
Sutripta
Old 22nd June 2012, 10:28   #24
Sheel's Avatar
Did the route between Purnea - Bhagalpur - Deoghar - Dumka - Messenjore dam - Tarapeeth - Moregram - Maldah - Dalkola - Purnea.
Purnea to Deoghar has good roads.
Dumka on wards, the roads are in very bad shape till Moregram save for Messenjore hilly section. That road is a driver's/riders delight. How I wish I was in my Ford or my CBR.
Till almost Raigunj, the four-laning work is in good progress, post Raigunj onwards, it gets slowed and will take some time to complete.
Old 24th June 2012, 00:12   #25
1100D's Avatar
I was in my Ford (the original josh machine) a couple of weeks back. Infact it was not only for the hilly section near messanjore but also the road between Messanjore and Seorakuri (Near Siuri). Not only enjoyed the roads and the car, but also the tyres. Flipside, big hole in the wallet, the black thing just guzzled whatever I put in its tank!!
You mean, Moregram to Raiganj already has part of it 4-laned? What about that Kaliachowk?
Old 24th June 2012, 07:57   #26
Sheel's Avatar
Yes, one way or the other's surface is almost complete and vehicles ply on the same lane. Still the single lane is wider than erstwhile NH 34.
Kaliachowk? Don't recall seeing it.
The places where bridges are isn't complete and I have to visit Calcutta sometimes when the winter approaches. Thinking to take the good old NH 34.
Old 25th June 2012, 00:39   #27
rahul4640's Avatar
Thanked: 308 Times
Wish you a very happy married life. Can you tell us something in detail about the Bhagalpur bypass?
rahul4640 is offline   Reply With Quote
Old 27th June 2012, 22:31   #28
Sheel's Avatar
Recalled... Is this prior to Maldah? And are you talking about congestion? Yes, it took around 15+ mins to cross this stretch.
It is yet to be completed. I think it would be better to do the Bhagalpur stretch prior to 8 am or 8 pm.
Once completed, I shall up-date. (Looks unlikely prior to the Durga Puja though)
Old 2nd July 2012, 12:29   #29
noidea's Avatar
Thanked: 78 Times
How about a route from Kolkata to Siliguri through Bangladesh.
Google map throws up another route
noidea is offline   Reply With Quote
Old 5th July 2012, 18:34   #30
DriveTrain's Avatar
Thanked: 311 Times
Hi All , request your inputs please ..
Would it be advisable to venture upto Murti / Suntaleykhola in Dooars in a hatch back in mid to late August time frame , either through the Dumka Bhagalpur route or via the NH2 - Moregram - Dalkhola route ?
DriveTrain is offline   Reply With Quote
Kolkata-Siliguri through SH7, NH34 and Botolbari-Dhantola routes 1100D Route / Travel Queries 50 12th June 2018 06:26
Kolkata to Siliguri via Patna (4 lane highways only) haldar_siliguri Route / Travel Queries 3 7th March 2016 09:08
Where Time Still Stands Still - A Journey (Delhi-Dumka-Deoghar) anandjha Travelogues 11 29th November 2012 16:59
Kolkata-Siliguri-Mangalbaria-Ravangla-Geyzing-Siliguri-Kolkata Saurabh M Travelogues 125 9th April 2011 21:27
Update on Kolkata - Siliguri - Doars Road. Captdey Route / Travel Queries 0 5th April 2010 09:51
