Old 23rd July 2012, 13:17   #1
Rajeevraj's Avatar
Thanked: 7,955 Times
Default Pondicherry-Calicut Route Query
Hi All,
What would be the best route from Pondicherry to Calicut. Google Maps shows me the following options (high level)
1. Pondicherry-Villupuram-Ulurdurpet- Salem -Cbe-Palakkad-Kozhikode
2. Pondicherry-Villupuram-Ulurdurpet--Perambalur-Karur-Dharapuram-Pollachi- Palakkad-Kozhikode
3. Pondicherry-Villupuram-Ulundurpet-Perambalur-Karur-Kangayam-Palladam-Cbe-Palakkad-Kozhikode
This trip would be the weekend after Onam. So considering the Walayar block issues, option 2 looks better. But I have no idea on these routes or the conditions.
Another constraint is that a single person would drive the whole distance and the start time will be only mid morning. So one option we were thinking is to stop over in Cbe. But with route 2 that will not be possible.
The start is from Bangalore and 2 families would return to Bangalore. So coming back to Bangalore and going to Calicut the next day is also an option. Does that make more sense?
Any inputs/suggestions are welcome.
Rajeevraj is offline   Reply With Quote
Old 23rd July 2012, 13:45   #2
ampere's Avatar
Thanked: 8,592 Times
Default Re: Pondicherry-Calicut Route Query
A combination of 1 and 2.
Pondi-Villupuram-Ulurdurpet- Salem-Perundurai-Kangeyam-Palladam-Pollachi-Palakkad-Malappuram-Calicut.
This gives you :
- 4-lane from Villupuram to Perundaurai
- Fantastic roads from Perundurai till Palakkad
- Very good options for food break.
- Palakkad to Calicut is the standard NH213.
ampere is offline   (1) Thanks Reply With Quote
Old 23rd July 2012, 14:47   #3
Rajeevraj's Avatar
Thanks for the info. How much will be the approximate driving time from Pondi to Palakkad considering a mid morning start?
Old 23rd July 2012, 14:52   #4
shekaran's Avatar
Thanked: 63 Times
Route 1 is the best - mostly 4 laned, from villupuram till cbe, food joints in between, lots of good fuel stations, also for relaxed driving.
yes, if you start after breakfast, you can reach cbe for lunch, salem outer for evening tea/snacks and reach pondy for dinner. cbe to pondy takes approx. 7.5 hours driving without any pitstops.
after you cross villupuram, beware of local buses that run as though their tails are on fire...
shekaran is offline   Reply With Quote
Old 23rd July 2012, 17:02   #5
ampere's Avatar
Its about 450km to Palakkad and very good roads. Only deterrent is time taken to cross Pollachi. If you start by 6AM and assuming an average of 60kmph, you should be there by 3PM max (including breaks).
Old 23rd July 2012, 18:45   #6
Thanked: 742 Times
Why wouldn't Pondy-Ulundurpet-Salem-Sathy-Chamrajnagar-Calicut work ? It would avoid Palakkad or anywhere close to Walayar alltogether.
narayans80 is offline   Reply With Quote
Old 23rd July 2012, 18:51   #7
ampere's Avatar
I thought of suggesting that. But then we do two sections of ghats.
Thought that would delay the drive. Hence did not suggest.
Old 24th July 2012, 11:18   #8
Rajeevraj's Avatar
An interesting option. I assume that will be a good drive. And Charmrajnagar-Calicut is familiar roads due to frequent trips between Bangalore-Calicut. Issue is that the start is expected to be around 10am which means both ghats and forest sections will have to be tackled late evening/night. Also, in case there is some delay on the way, there is a risk of missing the 9pm cut-off to cross Bandipur.
Anyway, will keep this option also in mind
Old 24th July 2012, 11:30   #9
Thanked: 742 Times
You should be able to make it Sathy by 3. Till Athur it will be a fast drive, then might slow to Salem, again runway till Bhavani. Beyond that am not much aware, but reading BLR-CBE thread, Dimbam good seems to be in good condition. You should be able to make it before 9pm easily IMO.
Old 28th August 2012, 09:45   #10
Rajeevraj's Avatar
An update on this.
The start can happen only around 11am. And a single person driving. There are some friends to visit also at CBE. So we are thinking to halt at Coimbatore some point and resume the next day to avoid night driving. . So I guess then the route should be
Any thoughts?
Bangalore - Calicut : Route Queries MG1558 Route / Travel Queries 936 30th October 2017 16:05
1st ever Mini meet in Calicut. Post here for all future Calicut mini meets.. MaserQ The Team-BHP Meet Section 17 8th August 2017 04:32
3 bhpians coming to calicut, calicut bhpians want a meet? pramodkumar The Team-BHP Meet Section 9 26th September 2011 21:51
Need some pointers! Calicut - Aluva - Rameshwaram - Madurai - Ramakkalmedu - Calicut Klub Class Route / Travel Queries 8 18th March 2011 12:45
