Old 3rd April 2013, 20:04   #1066
Thanked: 111 Times
Default re: Bangalore - Kannur : Route Queries
I'd be visiting Kannur and plan to take the route suggested by sandsun7. I need help on the return.
On the way back, after leaving the resort, I plan to visit Parassinakadavu and Taliparamba temples. Google maps shows me the following route to join back
the Iritty-Virajpet road:
Talliparamba-Sreekandapuram-Payyavoor-Kunnoth
Is this road decent enough or is there a better alternative.
Thanks,
Prasad14
prasad14 is offline   Reply With Quote
Old 3rd April 2013, 20:31   #1067
sandsun7's Avatar
Thanked: 629 Times
Originally Posted by prasad14 View Post
Thanks,
Prasad14
Taliparamba-Sreekandapuram-Irikkur-Iritty road is in good condition except that somewhere near Sreekandapuram town, there is a major work going on to increase the height of the road to avoid flooding during monsoons, where you would have to drive very slow. But this is only for a short distance, perhaps for around 200-300 metres. Link for this route: http://goo.gl/maps/Ey8XD
Where is your resort located? If you are planing to visit Parassinikadavu first and then Taliparamba, then this route would be the best option. If you plan to cover Taliparamba temple and then Parassinikadavu, then you could cross the parassini bridge and join Mayyil road from where you could come to irikkur and head on to Iritty. Link here:http://goo.gl/maps/48HWa
(Slightly OT: Do remember, entry for ladies is permitted only after the night pooja (athazha pooja) in Taliparamba Rajarajeshwara temple)
sandsun7 is offline   (1) Thanks Reply With Quote
Old 3rd April 2013, 21:50   #1068
Thanked: 111 Times
Thanks Sandsun7. Our resort (CheraRocks) is in Thottada, south of Kannur as per Google maps. So, I thought of going to Parassinakadavu and then to Taliparamba. Is this correct?
Also, should I touch Iritty town to proceed towards Virajpet (as per your map) or is there some other way I can join the Iritty-Virajpet road?
However, the info on Taliparamba is very useful, which means I'll have to change the plans.
Thanks again,
Prasad14
Old 4th April 2013, 09:43   #1069
sandsun7's Avatar
Thanked: 629 Times
Prasad14
This should be alright! Try to be at Parassinikadavu by around 3 in the afternoon so that you can watch Muthappan theyyam performance.
You will not enter Iritty town at all when you are coming from Taliparamba and going towards Virajpet. Taliparamba-Iritty road will join Kannur-Iritty-Virajpet road just before the Iritty bridge.
This image will give you a clear idea.
Bangalore - Kannur : Route Queries-iritty.jpg
Map courtesy: mapmyindia
Old 4th April 2013, 17:26   #1070
Thanked: 9 Times
Need to do Bangalore-Iritty tomorrow afternoon.
After reading through the threads, I'm little confused with the right option with respect to quality of roads. Is the route via Gonikoppal better than the one via Ammathi?
Can one of you who frequent this route share the best option possible on google maps?
Is it safe to take this route in the night? Not much exposure to this part of the world, that's the reason for this question.
Rex
rex_varghese is offline   Reply With Quote
Old 4th April 2013, 17:32   #1071
ampere's Avatar
Thanked: 8,823 Times
As @Sandsun mentions best option is :
Bangalore-Mysore-Hunsur-Periyapatna-Siddapur-Amatti-Virajpet-Iritty.
I wont advice night drive. Because a 10km section between Periyapatna and Siddapur is quite bad. Rest of the route is superb.
I myself was on this stretch last weekend and it was brilliant (apart from that 10km odd section)
Old 4th April 2013, 17:48   #1072
Thanked: 9 Times
Thanks much, ampere!
If we are able to cover the bad stretch in day light, rest of the route (forest, ghat section, etc) is safe to be driven in the night, I suppose.
Rex
Old 4th April 2013, 18:43   #1073
sandsun7's Avatar
Thanked: 629 Times
If you are driving in the night, this route (mysore-Hunsur-Periyapatna-Siddapura-Ammathi-Virajpet-Perumpadi-Koottupuzha-Iritty) is the only option because the other route via Nagarhole is closed for traffic from 6 PM to 6AM.
Gmaps link: http://goo.gl/maps/30ich
What time are you planning to start? If you plan to leave at least by 2 in the afternoon, you would be able to comfortably clear the bad stretches in daylight/twilight. Else, I could suggest a slight deviation (recommended in a previous post by Nalin Kumar) Instead of turning towards Siddapura from Periyapatna, proceed till Kushalnagar on Mysore-Madikeri road and from there, turn on to Siddapura through Dubare road, Nellihudhikeri and proceed then on to Virajpet. This route I believe would be around 20km more, but would avoid the bad stretches.
I don't think there is any issue driving through Makutta ghats in the night. Fog could have been an issue, but not during summer.
sandsun7 is offline   Reply With Quote
Old 4th April 2013, 19:45   #1074
Thanked: 9 Times
Thanks for your reply and the map link, sandsun!
We'll be starting around 2pm, so expect to cover the bad stretches in the daylight.
Rex
Old 6th April 2013, 14:08   #1075
Question re: Bangalore - Kannur : Route Queries
My scorpio was all battered and rattling like crazy after 35kms of drive through hell. Hell as in Hunsur -- Gonikoppa route. One of the worst roads I have driven through in the recent times and this was about 2 weeks back.
So stay away and do the siddapura--virajpet -- amatthi route to kannur. Just about 6/7 kms of not so bad roads.
Just a question. Has anyone tried Hunsur-Nagarhole (Murkal Checkpost) and right turn INSIDE the sanctuary to join back to Gonikoppal? The right turnoff is about 5 kms after Murkal gate while coming from Hunsur side and is the Thithimathi-Konankatte link road via Karmad-Nittoor-Balele. This can potentially avoid the bad stretch between Periyaptne and Siddapur (provided the forest road is in motorable condition).
aithal303 is offline   Reply With Quote
Old 7th April 2013, 09:48   #1076
Thanked: 239 Times
Done Bangalore - Payyanur yesterday. Started from BLR around 11:30am and reached Payyanur at 9pm via Srirangapatna byepass - Hunsur - Periyapatna - Siddapura - Iritty - Srikantapuram - Thalipparamba - Payyanur with lots of breaks in between
Took the srirangapatna byepass to view some green and calm places and wanted to avoid the hot and boring mysore ring road. In this stretch, the first 200mtrs just after the KRS turn off has completely spoiled..but it looks like they are going to re-lay the road. Overall this stretch is quiet doable and time saving.
After Ammathi, road is getting re-laid till Perumpadi checkpost. The work is still on. There are constructions happening at Chengalayi after Srikantapuram. You need to be very much carefull in night..!!
Rajesh
RajeshK is offline   Reply With Quote
Old 8th April 2013, 12:52   #1077
Thanked: 9 Times
We drove Bangalore-Iritty on Friday afternoon. Started around 2pm from Hennur and hit Iritty by 9pm or so. We could cover the bad stretch of road after the Periyaptna turn just as it was getting dark. Road beyond this point is bumpy too but compared to this bad stretch it's good. Most of the stretch is patched and not very smooth. Road re-laying is in progress after Virajpet.
A km or so of road on the Srirangapatnam-Yelawala stretch, after the KRS turn, is really bad. One layer of road is taken off for re-laying. It's as if driving on a freshly plowed dry land.
We had to do some driving around before returning, visiting some relatives. We drove to Perambra on Saturday afternoon, then to Pullooampara. And started the return trip around 9 on Sunday morning via Wayanad-Gundlepet-Chamaraj Nagar-Kollegal-Kanakapura to hit home around 5pm. Ghat section is amazing to drive. Never seen the ghat roads so nicely done and maintained. Most of the Gundlepet-ChamrajNagar-Kollegal-Kanakapura stretch is excellent and very peaceful to drive.
Rex
Old 8th April 2013, 13:51   #1078
ampere's Avatar
Take the regular Mysore ring road on the way back. Thats much better. Just that at night be careful about abrupt diversions at one or two places.
Old 9th April 2013, 16:05   #1079
Latheesh's Avatar
Thanked: 2,838 Times
Driving to Kannur tomorrow
What is the status of Hunsur-Gonikoppal stretch?
Latheesh is offline   Reply With Quote
Old 9th April 2013, 16:57   #1080
ampere's Avatar
Not worth taking. Take the alternative via Periyapatna/Siddapura/Ammathi.
Pune-Bangalore-Mysore-Kannur-Bangalore ambivalent_98 Travelogues 4 17th November 2010 11:39
12 hours to do B'lore-Kannur-B'lore - Best Route? Steeroid Route / Travel Queries 38 7th January 2009 21:43
Bangalore Munnar-kannur-bangalore -1500kms Round Trip ad75 Travelogues 25 23rd April 2008 13:25
Travelogue - Bangalore - Mysore - Nagarhole - Kannur - Bangalore anainar Travelogues 10 16th January 2008 18:56
Bangalore Kannur route?? amitoj Shifting gears 23 27th May 2005 11:18
