Old 27th December 2013, 21:57   #1
Thanked: 17 Times
Default Bangalore to Tiruchendur
My grandmother passed away last week and I need to travel to Tiruchendur on the 31st. I am going to be driving alone- from Bangalore to Tiruchendur and back. I need to be there at an odd time is why bus and train don't work out for me.
I plan to leave 31st early morning by 6:00AM and drive with a couple of stops in-between for breakfast/lunch. I plan to go via Salem, Karur, Madurai, Virudhunagar, Kovilpatti, Sattur, Tirunelveli. People tell me it would take about 10 hours. I don't usually drive faster than 100KMPH. I listen to audiobooks (fiction) while driving. I plan to start a fresh book on 31st. Wanted to know if there is any cause for concern about the road, some new diversions, some new bad patches or some sudden bump to be weary of- if anyone knows anything. Also, if you feel going via Tuticorin is better, let me know. Thanks for the help and thanks if you are reading, but don't see a concern.
Hey, also, if anyone has to go that side at that time, wants to join me, let me know.
ananth_blr is offline   Reply With Quote
Old 27th December 2013, 23:36   #2
ampere's Avatar
Thanked: 9,126 Times
Default Re: Bangalore to Tiruchendur
I think you should do NH7 till Madurai and then NH45B to Tuticorin bypass. And then take the ECR from there on. That should be a better option. Even Madurai-Tuticorin is a 4-lane end to end.
ampere is offline   (1) Thanks Reply With Quote
Old 28th December 2013, 07:30   #3
Thanked: 17 Times
Thanks Ampere. Does that mean Madurai-Tirunelveli road is not as good? Even if it is a bit longer (by about 25 Kms, I guess), I would prefer to do the Tirunelveli route, as I have many memories attached to that place. But, if the roads are not as good, then Tuticorin it is.
Old 28th December 2013, 12:46   #4
mallumowgli's Avatar
Thanked: 760 Times
Ampere meant it in terms of distance I presume - no need to go till Tirunelveli. But if you want to do Tvly, then also it should be OK. Madurai Tirunelveli is good. Am not sure whether Tirunelveli-Tuticorin road work is complete
mallumowgli is offline   Reply With Quote
Old 28th December 2013, 17:14   #5
ampere's Avatar
I think both are just fine. You get 4-lane till Tirunelveli as well. Since you can get 4-lane all the way till Tuticorin, I suggested that option.
Old 7th January 2014, 21:21   #6
Thanked: 17 Times
So I left bangalore at 5:45am, took the tirunelveli route and reached Tiruchendur by 2:00PM. I stopped just once for a brunch. But while returning, I took about nine and half hours, as I left only by about 11:45 and part of my journey after krishnagiri was slow due to traffic and because it had become dark. Listen to an audiobook and it was good. Apparently, the road between Tiruchendur and Tuticorin is not as good and everyone recommended I come back via Tirunelveli.
ananth_blr is offline   (1) Thanks Reply With Quote
Old 8th January 2014, 09:25   #7
ampere's Avatar
Did not realize the last mile is that bad. Now that you mention, I also feel, Tirunelveli is better. Another reason for the same is that you are onto NH7 much earlier and crossing Madurai is easier. No need to go via airport ring road and all.
Old 1st April 2014, 11:26   #8
Ramp's Avatar
Thanked: 19 Times
Just Come back from Bangalore - Tiruchendur - Bangalore trip.
Bangalore to Tiruchendur => Took Tuticorin route and the road from Tuticorin to Tiruchendur (38kms) was in bad shape. Till Tuticorin the road was very good and all the way it was 4 lane except Madurai by pass.
Tiruchendur to Bangalore => Took Tirunelveli route and the road from Tuticorin to Tirunelveli was good 2 lane road. From Tirunelveli to Bangalore as usual all the way 4 lane.
Better to take Tirunelveli route and it was worth even if you spent 10 - 15 kms extra and approx Rs 38 extra on toll.
Ram.
Ramp is offline   (1) Thanks Reply With Quote
Old 1st April 2014, 18:58   #9
Blue Thunder's Avatar
Thanked: 335 Times
Question Re: Bangalore to Tiruchendur
Originally Posted by Ramp View Post
... Tiruchendur to Bangalore => Took Tirunelveli route and the road from Tuticorin to Tirunelveli was good 2 lane road. ...
I guess you meant "Thiruchendur to Tirunelveli" ?
I know Tuticorin-Thirunelveli is 4-laned.
Blue Thunder is offline   Reply With Quote
Old 1st April 2014, 19:14   #10
ampere's Avatar
Looks like the ECR is in quite bad shape and the NH7 access is far-far better. I also presume that the Tiruchendur exit on the Tirunelveli bypass would be well marked.
Old 2nd April 2014, 11:46   #11
Thanked: 846 Times
Yes ampere. IIRC Tiruchendur exit is marked in NH7 in Tirunelveli bypass.
-Ravi
ravib is online now   (1) Thanks Reply With Quote
Old 2nd April 2014, 14:26   #12
Ramp's Avatar
Thanked: 19 Times
[quote=Blue Thunder;3403456]I guess you meant "Thiruchendur to Tirunelveli" ?
Yes, I was meaning Thiruchendur to Tirunelveli, some how i typed wrongly.
Ramp is offline   Reply With Quote
Old 2nd April 2014, 14:55   #13
suresh_gs's Avatar
Thanked: 1,249 Times
[quote=Ramp;3404020]
How are the road conditions from Tiruchendur to Tirunelveli.
suresh_gs is offline   Reply With Quote
Old 2nd April 2014, 16:06   #14
ampere's Avatar
[quote=suresh_gs;3404055]
Check Ananth's post above. Its much better to take NH7 instead of NH45B. Tirunelveli-Tiruchendur is in much better condition than Tuticorin-Tiruchendur.
Old 3rd April 2014, 11:54   #15
Thanked: 899 Times
SH40 is good, traffic is a bit on moderate side. Not a problem in the day, at night was a bit irritating to drive (especially I went in Jan when there were tons of people walking to Tiruchendur). As ampere mentions, its better to stick NH7 than NH45B.
narayans80 is offline   (1) Thanks Reply With Quote
Pillaiyarpatti - Tiruchendur Route query chandras Route / Travel Queries 10 2nd April 2014 20:58
Thiruvananthapuram-Tiruchendur-Madurai-Rameshwaram darklord Route / Travel Queries 21 25th October 2012 00:24
Chennai to Tiruchendur kshivaa Route / Travel Queries 13 24th January 2010 18:32
Bangalore-Nagpur-Bangalore tsk1979 Travelogues 16 1st August 2007 14:10
Bangalore - Calicut - Bangalore, Crv 3.5 k kms Jaggu Travelogues 10 23rd April 2005 11:08
