Old 4th October 2013, 15:51   #346
rahul_sinha's Avatar
Thanked: 156 Times
Default re: Bangalore - Kochi : Route Queries
I am travelling to Kerala and TN in Nov from Pune.
Leg 1: Pune - Bangalore
Leg 2: Bangalore - Ernakulam (via Coimbatore)
Leg 3: Ernakulam - Yercaud (via Salem)
Leg 4: Yercaud - Kozhikode
Leg 5: Kozhikode - Bangalore
Leg 6: Bangalore - Pune
While Pune - Bangalore - Pune is fairly straightforward, I am planning on exact routes for Bangalore - Ernakulam, Ernakulam - Yercaud, Yercaud - Calicut and Calicut - Bangalore.
All driving will be in the day time, max stretchable to 8pm. I have low GC sedan Cruze automatic and will be travelling with family.
While I will be going through this whole thread on actual stretches to avoid et al, would be grateful for a good heads up so that I can plan better.
Thanks,
Rahul
rahul_sinha is offline   Reply With Quote
Old 4th October 2013, 16:40   #347
ampere's Avatar
Thanked: 9,122 Times
Originally Posted by rahul_sinha View Post
Yercaud on the way back seems out of place. You should do Yercaud on the way to Ernakulam. If you cant do it, I would say chose a place around Kozhikode. I dont think Yercaud is a place worth such a deviation.
Old 4th October 2013, 17:12   #348
Thanked: 156 Times
I have a booking at Club Mahindra Yercaud and need to pick up folks from Ernakulam
Old 8th October 2013, 08:55   #349
McTurbo's Avatar
Thanked: 11 Times
Hello,
Planning for a Bangalore - Kochi drive on the 12th of Oct. What would you all suggest if I am constrained to leave Bangalore only around 1.00 PM?What should I be prepared for, considering half the journey could be night driving? Saw good reviews on this route "Bangalore-Salem-Avinashi-Palladam-Pollachi-Kollengode-Alathur-Wadakancheri-Thrissur-Chalakudi-Edappally-Kochi". How safe is it to do this route in the night with family?
McTurbo is offline   Reply With Quote
Old 8th October 2013, 08:59   #350
ampere's Avatar
Originally Posted by McTurbo View Post
Hello,
Its safe. But the bigger problem is minimal service available on the road. Also there is possibility that you may lose your way and there may not be folks to guide you to the right one.
ampere is offline   (1) Thanks Reply With Quote
Old 8th October 2013, 10:46   #351
Thanked: 107 Times
Hello,
If you start at 1, you can get to Chengappalli by 5:30-6. I saw some caution against Avinashi-Palladam stretch from ranjitp1 and hence would recommend turning off at Chengappalli towards Uthukkuli, Tirupur ring road bypass. You'll do this stretch through Palladam, Pollachi, Kollengode, Nenmara until Vadakkenchery in dark (around 2.5-3 hrs). Road surface is not a concern but you'll not have options to stop for breaks. If you are comfortable with Malayalam then you could ask in case of route confusion else you could end up taking a wrong turn consequently making it a longer detour.
You could consider the regular route though Coimbatore, Walayar. Avinashi-Coimbatore is very much doable upto Madukkarai. Around 30-40 Kms from Madukkarai till Palghat is iffy and I don't have direct feedback on that but others can probably update you. I do read in the papers that NH47 from Palghat to Trichur is being repaired but not sure of the work progress between Palghat and Vadakkenchery. You could do Palghat-Ottappalam-Shornur-Wadakkancherry-Trichur as a decent alternative.
Mnjdnght is offline   (1) Thanks Reply With Quote
Old 8th October 2013, 12:55   #352
McTurbo's Avatar
Thanked: 11 Times
Thank you. I think I will stick to this regular route unless someone updates on some serious time killers. Will try to get some local inputs at the Palghat bypass on the current condition of Palghat - Thrissur stretch and take a decision.
Old 8th October 2013, 14:53   #353
mallumowgli's Avatar
Thanked: 760 Times
Palghat - Thrissur is not a very smooth stretch, but very much doable. Patchy at most places from Madukkarai(L&T bypass) till vadakkenchery.
Check this thread for more details for stretches beyond that (post by Mnjdnght himself)
http://www.team-bhp.com/forum/route-...ml#post3257011
mallumowgli is offline   (1) Thanks Reply With Quote
Old 9th October 2013, 14:15   #354
Does anybody have an update on the repair of the Pallkad Thrissur leg? I heard they were starting repairs after the protests in August but not seen any updates since. I plane to drive to Kochi on this route 01 November...Thanks
pramodh is offline   Reply With Quote
Old 9th October 2013, 14:28   #355
Thanked: 760 Times
Sir - the previous post itself gives the answers that you are looking for!!
mallumowgli is offline   Reply With Quote
Old 9th October 2013, 15:50   #356
Thanks but the more important question is the update from somebody who has driven that stretch post post August or post repairs to be precise.
Old 10th October 2013, 07:45   #357
denver85's Avatar
Thanked: 230 Times
The Palakkad-Thrissur stretch (NH47) is in good condition and doable as per the report from 2-3 members in the thread 'All roads to Kerala'. As per the latest news only a small section (4-5 kms between Pattikad and Mannuthy) was pending and work was progressing there. Hope that also is completed by now. Kuthiran section is completely repaired.
denver85 is offline   Reply With Quote
Old 14th October 2013, 07:28   #358
pramodpk's Avatar
Thanked: 474 Times
Drove from Vaikom to Bangalore yesterday. See my updates here.
http://www.team-bhp.com/forum/route-...ml#post3264975 (All Roads to Kerala)
pramodpk is offline   Reply With Quote
Old 23rd October 2013, 12:48   #359
Ice
Ice's Avatar
Thanked: 102 Times
I plan on leaving Bangalore around 4 AM for a trip to Cochin. The route that I know and am comfortable with is:
1. Bangalore - Salem - Coimbatore - Walayar - Palakkad - Thrissur - Cochin,
I heard that the following routes are pretty good too :
2. Bangalore - Avinashi - Palladam - Pollachi - Alathur - Wadakancheri - Thrissur -Edappally - Cochin
and
3. Bangalore - Mysore - Gundlupet - Gudalur - Nilambur - Perinthalmanna - Shoranur - Wadakancheri - Thrissur - Edappally - Cochin
Which would you recommend?
Car : Innova/Fortuner
Passenger count : 3 adults + 1 surprisingly well-behaved 3-yr old
Ice is offline   Reply With Quote
Old 23rd October 2013, 14:03   #360
pramodpk's Avatar
Thanked: 474 Times
Originally Posted by Ice View Post
and
Take the regular NH 7 - NH 47 route via Salem - Coimbatore - Palakkad - Thrissur. It would be the fastest in the current conditions. See details of my drive on Oct 13th in the below post.
pramodpk is offline   (1) Thanks Reply With Quote
Kochi - Goa - Hubli - Bangalore - Kochi : Route Queries MilesAndSmiles Route / Travel Queries 41 10th November 2015 16:16
Speedway Kochi: A Go Karting Race track @ Kochi arjuunz Indian Motorsport 16 4th August 2014 03:43
Kochi - Gavi - Kodaikanal - Kochi jas_mirage Route / Travel Queries 10 27th September 2011 00:03
Five Days - Kochi - Kalpeta - Kodaikanal - Valparai - Kochi NutsNBolts Travelogues 28 6th June 2010 16:56
