Old 3rd January 2016, 11:48   #1486
virgopal's Avatar
Thanked: 80 Times
Default Re: Bangalore - Pondicherry : Route Queries
Thanks ampere.I will try adding via points and create/save the route on device.
Exploring the procedure.Looks bit complex:(
virgopal is offline   Reply With Quote
Old 3rd January 2016, 15:39   #1487
ampere's Avatar
Thanked: 9,107 Times
If you have a 24xx series device, then it's quite easy. You can install the same map on the PC the one you have on the device. Then you can plan the route on the PC and transfer the route on to the device.
ampere is offline   (1) Thanks Reply With Quote
Old 10th January 2016, 08:26   #1488
virgopal's Avatar
Thanked: 80 Times
Nuvi 42LM has provision to add only ONE via point unlike in some other higher versions.
As such no idea how to proceed reg route planning/alternate methods.
Old 10th January 2016, 16:01   #1489
ampere's Avatar
Thanks ampere. I am proceeding accordingly.I am plotting Mysore/Blr/Pondy via the tried and tested Krishnagiri/Arcot/Vandavasi Tindivanam route. Let me see how it pans
I would still suggest Mysore-Chamarajanagar-Sathy-Bhavani-Salem-Ulundurpet-Tindivanam-Pondicherry.
Much less traffic to worry about. And Bhavani onwards its 4-lane all the way.
Old 11th January 2016, 15:56   #1490
virgopal's Avatar
Thanked: 80 Times
I meant that I am planning to plot the above route on Basecamp for trial purposes only.
However, whenever we actually decide,I plan to follow due to the advantages .:chamrajnagar/Sathy/Bhavani/Salem/ulundurpet/Tindivanam/Pondy,as suggested by you.
Thank you
Old 12th January 2016, 15:46   #1491
Fortuner71's Avatar
Thanked: 273 Times
Yes i did this 2 weeks ago fantastic no traffic
Fortuner71 is offline   (1) Thanks Reply With Quote
Old 13th January 2016, 09:36   #1492
virgopal's Avatar
Thanked: 80 Times
Great.How did you find the ghat road driving over the 36 hair pin bends? Is it easily doable by a hatch back like my Spark?
Any tips to have a pleasant stress free drive as I dont have hill driving experience:(
Old 13th January 2016, 10:03   #1493
Awaiting Email Confirmation
Thanked: 4,225 Times
Easily doable.
Use the engine brake as far as possible, while descending by driving in lower gears without bothering about the sound. The thumb rule is to use the same gear for both ascending and descending. Always give the right of way for the vehicles climbing the hill. While waiting near a hair-pin bend to give right of way for the upcoming heavy vehicle, ensure that you stop well before the bend by leaving enough space as the heavy vehicle will be tackling the curve by going to his extreme right.
J.Ravi is offline   (1) Thanks Reply With Quote
Old 13th January 2016, 10:07   #1494
suresh_gs's Avatar
Thanked: 1,249 Times
Are you talking about Dhimbham ghats ie the ghat road from Sathy to Chamarajanagar. If so, it has 27 hair pin bends and very much doable. Just keep your fingers crossed that no truck breaks down enroute as this can create a major traffic jam.
The Masinagudi ghat road to Ooty has 36 hair pin bends.
suresh_gs is offline   (1) Thanks Reply With Quote
Old 13th January 2016, 10:33   #1495
virgopal's Avatar
Thanked: 80 Times
Yes @suresh, I was referring to Dhimbam ghats from Chamarajnagar to Sathy-27 HP bends,only.
Truck breakdowns of course will be a problem,I agree.Thats one of the reasons for hill driving hesitation.
As an alternative,If I follow,Bangalore/Krishnagiri/Arcot/Vandavasi route:-the Mys-Blr route issues and long Krishnagiri toll wait are cons.But driving wise, no issues as it is ghat free and I am comfortable there.However,yet to decide.
Old 13th January 2016, 18:57   #1496
Thanked: 139 Times
I keep using 42LM for long drives.
The way I use it is keep the broad route division handy, decided based upon feedback from various sources, and use the breakup to set up small trip plans on the device.
Take a broad view of path before starting for each via point and route suggested between each pair, this avoids searches on the run and unnecessary diversions.
deepv is offline   (1) Thanks Reply With Quote
Old 13th January 2016, 19:13   #1497
virgopal's Avatar
Thanked: 80 Times
Thank you deepv for this useful and practical suggestion. Will try this as a project, for a short trip soon following this tip.
Old 14th January 2016, 11:24   #1498
Thanked: 163 Times
So! Going to Pondicherry tomorrow. Google throws this suggestion of taking the Chitoor route, starting point being my home. My last two trips has been from Hosur-Vellor-Cheyyar-Pondicherry back and forth, I was thinking if this route suggested by google is better? Last time I was stuck in Krishnagiri and Hosur toll for more than 90 minutes. Don't want to experience that ever again.
https://goo.gl/maps/SeHPmdB1mGB2
creative420 is offline   Reply With Quote
Old 14th January 2016, 11:30   #1499
suresh_gs's Avatar
You can expect long waiting time this evening at the toll plazas considering the sankranti holiday + the regular week end. Start early tomorrow morning say by 4 30 AM and stick to the GQ as against the Old madras road.
Old 14th January 2016, 11:31   #1500
reignofchaos's Avatar
Thanked: 1,298 Times
Road widening is going on in certain sections of NH4 but its not anything unmanageable. You'll face a bit of traffic around Ranipet. Other than that, it should be a fairly easy drive.
reignofchaos is offline   (1) Thanks Reply With Quote
Rajahmundry to Pondicherry : Route Queries penpusher Route / Travel Queries 11 11th November 2015 08:47
Bangalore-Pondicherry : Best route to take? binz Route / Travel Queries 4 27th May 2009 10:04
Bangalore -Thiruvannamalai - Pondicherry route. Ram Pratap Route / Travel Queries 2 25th September 2007 15:49
