Old 20th December 2007, 21:02   #16
tadukuttan's Avatar
Thanked: 22 Times
Originally Posted by Surprise View Post
What would be the average travel time from Coimbatore to Pollachi & Pollachi to Valparai sections
Read in some blogs that Pollachi to Valparai (60+kms) itself will take a good 3 hrs journey as one need to cover 40 HP bends. Can anyone pls confirm
I did Valparai to the Coimbatore bypass in slightly less than 3 hours, and I was not driving fast(ok, not usual fast).
tadukuttan is offline   Reply With Quote
Old 23rd March 2009, 14:21   #17
Default Bangalore to Valparai
Was looking for distance and road conditions from Bangalore to Valparai.
Planning to leave Bangalore around 4 am so that we could reach Valparai by 3pm. Is the route via Tiruppur good?
Vimala is offline   Reply With Quote
Old 28th October 2009, 23:14   #18
Thanked: 63 Times
Has any one travelled in this route recently? How are the roads? How much time will it take for Coimbatore - Valparai?
RSimonS is offline   Reply With Quote
Old 3rd November 2009, 12:18   #19
blackstallion76's Avatar
Thanked: 12 Times
@Simons & Vimala:
Even I am planning to Valaparai/Topslip. I referred to one of the threads by Rocky.
Very informative.
Accomodation:
Green Hills - 04253 222262
Krishna Lodge - 04253 222234
You can also contact estate bungalows for stay. If you are lucky, you will get.
One of them is Stanmore (HLL) one of the best stays. But, too costly.
But, you can try for other estates as well.
For normal estates, dams, view points staying in Valaparai makes sense.
However, if you want some jungle experience; I suggest please look for accomodation at Topslip(TN Side) or Parambikulam(Kerala Side).
Topslip Warden office:
Wildlife Warden Office, 178 Meenkarai Rd, in Pollachi.
Open Monday to Friday between 9 am to 5 pm. Tel: 04259 222-5356
OR
The Wildlife Warden
Indira Gandhi Wildlife Sanctuary,
178, Meenkarai Road, Pollachi - 642 001.
Tel: 04259 238360.
Refer:
Topslip - Wikipedia, the free encyclopedia
Topslip has some forest guest houses. And accommodation is provided based on quota basis. Weekends tough to get one. But, you can try your luck.
But, better to stay in Topslip rather than Valaparai. Anyday.
If stay in Topslip not possible, please try to contact Parambikulam (Kerala Side).
Official website of Parambikulam Wildlife Sanctuary, Kerala, India
Refer:
Karthik's (We)b-log: Two days in Top Slip
Travelogues and pictures: Top Slip - Version 2
Places of Interest:
Welome to Valparai - Online
blackstallion76 is offline   Reply With Quote
Old 11th November 2009, 20:36   #20
Thanked: 63 Times
Thanks a lot BlackStallion. Where did you stay in your trip? How was it?
Old 12th November 2009, 18:53   #21
The Bangalore to Valparai route is pretty straightforward.
Bangalore - Hosur - Dharmapuri - Salem - Bhavani - Tiruppur - Palladam - Pollachi - Valparai
You will not need to go to Coimbatore. Taking the Tiruppur route is the best way to reach. From Pollachi you can either go to Valparai or Topslip/Parambikulam. It is kind of a 'Y' with Pollachi being the intersection.
The roads are absolutely great. The road-widening work in Dharmapuri - Salem route is almost done, and except some small pending stretches after Salem, most of the work is completed. So, it is generally a pleasure to drive in this route.
Bangalore to Pollachi takes approximately 8 hours. Reaching Valparai from there should take another 2-3 hours. It is a scenic route with hairpin bends. On the other hand, Pollachi to Topslip should take much lesser time, as it is not a ghat route. However, the last 7-8 kms to Topslip, the roads are bad, and will take some time to cover.
Accommodation in Topslip is virtually non-existant except if you have some influential contacts in TN govt. Parambikulam, however, is one of the best wildlife sanctuaries in South India, and is definitely recommended, though it is a good deal expensive when compared to Topslip. Taking treks in either of the sanctuaries will guarantee good animal sightings.
d4dpak is offline   Reply With Quote
Old 10th March 2010, 13:06   #22
ampere's Avatar
Thanked: 9,108 Times
For the Bhavani Tiruppur - Palladam section does one need to go via Perindurai, Kangeyam? Or there is a direct road from Bhavani to Tiruppur? Google maps show only the Perindurai, Kangeyam - Tiruppur as a viable route.
Old 10th March 2010, 13:18   #23
hvkumar's Avatar
Thanked: 3,365 Times
To go from Bhavani to Tiruppur, you join NH47, and then leave it before Avinashi.
The route from Bhavani to Tiruppur goes via Perunthurai but does not touch Gangeyam, which is Perunthurai-Chennimalai-Gangeyam or Coimbatore-Palladam-Gangeyam.
hvkumar is offline   Reply With Quote
Old 10th March 2010, 18:53   #24
ampere's Avatar
Thanks. How is the Tiruppur Avinashi Pollachi section? As they are all TN SH, hopefully they should be good.
Old 10th March 2010, 19:09   #25
hvkumar's Avatar
Avinashi-Tiruppur-Pollachi is normally good. However, take care to bypass Tiruppur town.
Old 4th December 2010, 11:22   #26
rki2007's Avatar
Thanked: 139 Times
Please suggest me a better route to reach pollachi from Bangalore instead of going via coimbatore. Also please tell me the distance.
Thanks in advance
rki2007 is offline   Reply With Quote
Old 4th December 2010, 11:31   #27
hvkumar's Avatar
Thanks in advance
Take Pollachi-Palladam-Tiruppur-Avinashi road. From Tiruppur, you can join NH47 beyond Avinashi by taking the Erode/Perunthurai road from Tiiruppur. Around 100 kms
Old 4th December 2010, 11:51   #28
ampere's Avatar
In GM I see one more deviation before Avinashi (Or rather I was looking for one as Avinashi gets muddy).
This deviation happens at : Perumanallur. Any feed back on this stretch?
Perundurai, Tamil Nadu 638052 to Pollachi, Tamil Nadu 642002 - Google Maps
Old 4th December 2010, 12:10   #29
rki2007's Avatar
Thanked: 139 Times
sorry sir i didnt get you. From Erode please say me the route.
Old 4th December 2010, 12:30   #30
Thanked: 142 Times
I still feel the Perundurai - Kangeyam - Dharapuram - Udumalaipettai - Kottur. This would enable you to byepass both Tiruppur & Pollachi.
Perundurai, Tamil Nadu 638052 to Unknown road - Google Maps
pypkmsrikanth is offline   Reply With Quote
A class apart, or so it seems! -Urs Kar Services, Mysore wind_rider Indian Car Dealerships 18 6th June 2014 20:15
Bangalore-Valparai-Munnar-Bangalore redballons Travelogues 11 4th December 2012 22:39
Liesure trip --- Bangalore - TopSlip - Parambikulam Forest - Valparai - Bangalore trtraj Travelogues 13 26th May 2010 14:26
1550 Kms:Bangalore-Parambikulam-Valparai-Cochin-Ooty-Bangalore in a DZire ZDi PearlJam Travelogues 38 6th May 2010 10:08
