Old 21st July 2016, 12:18   #2371
Thanked: 7 Times
Default Re: Bangalore - Chennai - Bangalore : Route Queries
An update on the Poonamalle - Walajahpet toll road
http://www.financialexpress.com/econ...ilders/272706/
The Essel group has been playing truant for a while now. They don't seem to be committed to this project. There were similar issues raised prior to starting work in 2013 as well. Hope the project goes to L&T. Their stretch is the best I've seen.
Mubeen is offline   (2) Thanks Reply With Quote
Old 21st July 2016, 13:09   #2372
Turbohead's Avatar
Thanked: 284 Times
L&T is also one of the most expensive too. They used to produce really smooth roads like the Krisnagiri- Salem highway. Now though, it's bumpy.
Turbohead is offline   (1) Thanks Reply With Quote
Old 10th August 2016, 14:01   #2373
NPV
NPV's Avatar
Thanked: 5,298 Times
What is the best way to get to VGP Prabhu Nagar (Perumbakkam Road) from Kancheepuram after lunch at Regency (GRT) ?
How are the State highway roads - Walajahbad, Vandalur, etc ?
Google is suggesting this route - Link
NPV is offline   Reply With Quote
Old 10th August 2016, 21:18   #2374
Thanked: 170 Times
You could take the blue route highlighted by Google. Please note the roads will be congested when you near Tambaram.
searacer932 is offline   (1) Thanks Reply With Quote
Old 11th August 2016, 11:24   #2375
NPV
NPV's Avatar
Thanks!
How about this one ? Only difference is the portion circled. Instead of going all the way till the Vandalur junction, can we take this road to the left ?
Map Link
Map image here:
Bangalore - Chennai - Bangalore : Route Queries-route.png
Old 11th August 2016, 11:59   #2376
hserus's Avatar
Thanked: 2,701 Times
Thanks!
Map Link
Map image here:
Attachment 1540633
That takes you through west tambaram (Selaiyur etc). That is a single long road, mostly smooth - but careful as there are occasional groups of stray cattle happily resting on / beside the road's median.
hserus is offline   (1) Thanks Reply With Quote
Old 11th August 2016, 12:21   #2377
NPV
NPV's Avatar
From the map, it seems that is better to via Mudichur road since there is just the junction with the Chennai ORR (is there an underpass or flyover here ?) and after that one can get on to the Tambaram-Velachery road directly.
As compared to that if one stayed on the Vandalur road, ends up at the Tamabram flyover (several junctions there and difficult for a first timer to easily spot the road to take).
Hence the above plan, let me know if that's a good idea
Old 11th August 2016, 12:40   #2378
hserus's Avatar
Is compared to that if one stayed on the Vandalur road, ends up at the Tamabram flyover (several junctions there and difficult for a first timer to easily spot the road to take).
The junctions are clearly signposted and there's always google maps
Don't worry it is a straightforward route.
Old 11th August 2016, 13:28   #2379
Makin Rulesz's Avatar
Thanked: 199 Times
For crossing the ORR, you will take the underpass, not much confusion here. The section highlighted in your previous post is 2 lane road separated by divider and mostly in decent condition.
You need to take the ramp from GST to climb the flyover, and take the second exit at the roundabout towards Tambaram.
It is better to take the first route, since sometimes the traffic around Vandalur could get chaotic depending on your time of travel.
By the way, I stay near to your destination place, so in case of any help, you can reach me. I will PM my number
Makin Rulesz is offline   (1) Thanks Reply With Quote
Old 16th August 2016, 11:39   #2380
NPV
NPV's Avatar
Thanks @searacer932, @hserus and @Makin Rulesz for all the inputs, had a peaceful drive.
Took the Kancheepuram-Chengalpet Road (SH 58)-Walajahbad-Oragadam-Mudichur Road (SH 48) and Velachery-Tambaram road (SH 110) to get to Perumbakkam and reached in about 2 hours.
SH 58 is 2 laned and narrow at some places but road conditions are good with the odd rough patch. From the SH 48 turn off, it becomes a 4 laned road with median but not very wide. After the Apollo tyres factory at Oragadam, 6 laning work is in progress so there are several deviations with 2 lanes usable for traffic in both directions but wasn't too slow since traffic was low. The construction zone continues till the Mudichur road turn off to left near Mannivakkam. From here it becomes 2 lane road with median and quite narrow. It goes below the Chennai ORR and gets you to the flyover roundtana near Tambaram and the second exit joins the Velachery-Tambaram road. This road is quite wide with many traffic signals and road widening work. Since it was late afternoon, traffic was manageable.
Next day, took the Velachery road to get to T Nagar in the afternoon. Nearing Mount Road, the traffic was very heavy especially at the large junction before CIT Nagar (Anna Nagar ?) due to Metro construction work. Took almost 1.5-2 hours to reach T Nagar.
And, the usual drama around Panagal Park, there are probably more humans on the roads here than vehicles
Old 16th August 2016, 12:02   #2381
Gokrish's Avatar
Thanked: 165 Times
The junction you are referring here is CIT Nagar, Nandanam and not Anna Nagar. The road next DSC Hyundai Show room at this junction will lead to T Nagar Bus Terminus via South Usman Road. The stretch from Saidapet Junction till Gemini Flyover is in a complete mess nowadays due to Metro work and the traffic chaos is intense during peak hours!
Gokrish is offline   Reply With Quote
Old 22nd August 2016, 16:42   #2382
Recently on Aug 15th holiday I did Bangalore-Chennai trip.
After Essel Walajahapet toll gate the road (> 110 km stretch) was pretty bad in condition that the patchy worked road did slow down the speed to <80 kmph. The toll 45 Rs. is not justified at all. The 3 lane widening seems stopped or I am seeing in the same state for a quite a long time now.
manickaraj is offline   Reply With Quote
Old 22nd August 2016, 21:37   #2383
concorde24's Avatar
Thanked: 58 Times
After Essel Walajahapet toll gate the road (> 110 km stretch) was pretty bad in condition that the patchy worked road did slow down the speed to <80 kmph. The toll 45 Rs. is not justified at all. .
Oh yeah, this weekend was specially worse on Chennai - Kanchipuram segment of Bangalore highway. As per my friend, T.Nagar to kanchipuram trip took 3 hours instead of normal 1.5 hours. From kanchipuram, he came back via Tambaram in 2 hours instead of taking the same route back
concorde24 is offline   Reply With Quote
Old 27th August 2016, 14:48   #2384
Thanked: 1,668 Times
Came to Chennai for some personal work. Started at 7, and at 12 was turning off the GQ at Sriperumbudur towards Oragadam (with a 45-minute fuel+breakfast break in between at BPCL/A2B Shoolagiri). I thought that was a very good run - in fact, did Krishnagiri-Pallikonda toll to toll in about 70 minutes (100 km). More enterprising drivers might be able to manage this in less than an hour.
The Oragadam-Vandalur stretch is being 6-laned. Which tells me how long it has been since I came to Chennai - last time I came bulk of this sector was single carriageway. :-) What is the status of the alternative route from Sriperumbudur to Vandalur via Manimangalam - is it all good roads?
It seems to me Bangalore-Chennai is now possible within 5 hours. By which I mean Hosur-Sriperumbudur (270 km) in more or less 3 hours.
Now what they need to do is to expand the capacity of the toll booths. Apart from fixing the terrible stretch after Chennasamudram toll towards Sriperumbudur.
binand is offline   Reply With Quote
Old 27th August 2016, 16:16   #2385
ampere's Avatar
Thanked: 9,126 Times
If you plan to head on radial ring road via Pallavaram, Manimangalam makes much more sense.
Cant comment on timings. But it sure has improved. What has helped is Bangalore-Krishnagiri 6-lane. So Bangalore-Arcot can be covered swiftly.
And beyond is the bus and truck menace. Sriperumbudur-Tambaram-Destination can be deterministically managed in 1 hour easily
Chennai - Coimbatore - Ooty : Route Queries bharanidharang Route / Travel Queries 239 21st May 2018 11:04
Chennai - Kumbakonam : Route Queries polopm Route / Travel Queries 451 25th April 2018 20:43
Chennai-Mumbai-Chennai route queries jeevmenon Route / Travel Queries 89 7th November 2017 14:40
Bangalore, Chennai via Chittoor : Route Queries Blue Thunder Route / Travel Queries 234 19th October 2017 18:25
Chennai - Hampi : Route Queries saurabh711 Route / Travel Queries 35 19th December 2015 13:13
