Old 29th March 2014, 16:54   #286
mvp
Thanked: 18 Times
Originally Posted by Ravi Yadav View Post
Revvveendra,
How safe is the above route for a night drive. Any idea on the route condition between Solapur and Bijapur .
I did the Bijapur - Jevargi- Gulbarga and further Gulbarga - sedam - kodangal - mahabubnagar route recently and would not recommend night driving. If at all it is a must, ensure that you have powerful headlights.
But then, I am not aware of the road conditions in the other route discussed.
mvp is offline   Reply With Quote
Old 6th May 2014, 12:51   #287
Ajitsingh208's Avatar
Thanked: 100 Times
Default re: Mumbai - Hyderabad : Route Queries
Planning on doing this route this Friday. Will be leaving at around 3AM from Pune. Hopefully should hit Solapur by 6 AM. So which section is the most horrible after this?
I am thinking that since only 300 kms are left i should be able to do it in 6-7 hours in my TATA SAFARI. Am I being too optimistic?
Ajitsingh208 is offline   Reply With Quote
Old 6th May 2014, 13:51   #288
ranjitp1's Avatar
Thanked: 1,642 Times
Yes 5-6hrs should be good enough for you to cover Solapur-Hyderabad outskirts.The bad sections are uniformly scattered the worst being around Naldurg and Homnabad.
PS:Be prepared for the searing 40degree plus heat enroute
ranjitp1 is offline   Reply With Quote
Old 6th May 2014, 16:40   #289
Hi -
I plan to travel from Gachibowli (HYD) on Thursday early by 4am towards Andheri (MUM) & after going through the travelogue details of you all, I find this one suitable & less detouring.
Gachibowli - Sadashivpet (via ORR)
Sadashivpet - Zaheerabad
Zaheerabad - Bidar
Bidar (new bus stand road) - Humnabad
Humnabad - Solapur
Solapur - Pune
& thereafter ???
Since I'm leaving very early, I believe my 2006 model Optra should be in OK condition to bear this track. (I'm getting my car serviced & replaced with synthetic oil tomorrow with all other checks) Suggestions?
With this route, I believe I should be home (Mum) from home (Hyd) in 14hrs (including 1-2 breaks of 15-20 min)
rendezvous is offline   Reply With Quote
Old 6th May 2014, 20:14   #290
TaureanBull's Avatar
Thanked: 309 Times
I had taken Solapur-Akkalkot-Gulbarga route. 21 Kms from Akkalkot is horrible, except that its good roads. Especially the roads in Karnatka portion are too good.
I started at 6AM from Pune and was in Gachibowli by 4PM. 6-7 hours is sufficient for the 300km stretch. You should be in Hyderabad for lunch.
Originally Posted by rendezvous View Post
Hi -
Zaheerabad - Bidar
Humnabad - Solapur
Solapur - Pune
& thereafter ???
Opel Corsa is fine enough, only that you will have to drive slow in bad patches. Pune onwards its Mum-Pune expressway, I guess that was obvious.
TaureanBull is offline   Reply With Quote
Old 7th May 2014, 09:50   #291
Any suggestions on my route plan?
Since I'm getting my car serviced today, what more checks needs to be done before hitting the roads tomorrow?
I'm driving solo. Anyone interested to join me?
Old 7th May 2014, 09:52   #292
Hi -
Zaheerabad - Bidar
Humnabad - Solapur
Solapur - Pune
& thereafter ???
Old 27th May 2014, 22:09   #293
Cyrus_the_virus's Avatar
Thanked: 156 Times
Any update on the conditions on your trip?
Cyrus_the_virus is offline   Reply With Quote
Old 3rd June 2014, 01:32   #294
nawabnabeel's Avatar
Thanked: 19 Times
Yesterday I travelled from khopoli to hyderabad. My route was
Khopoli-pune-solapur-umerga-aland-gulbarga by pass via orr-farooqnagar-nh7 to mehdipatnam.
Total distance was 700kms against 630kms which is if I travel via nh9 all the way. This way I was able to avoid the stretch between umerga and hyderabad via nh9
nawabnabeel is offline   (2) Thanks Reply With Quote
Old 4th June 2014, 14:55   #295
ranjitp1's Avatar
Thanks for the update.How is the stretch between Aland and Umerga and Umerga and Solapur.
Could you pls advise what was the time taken to cover the distance between Solapur and Aland and ORR
Old 4th June 2014, 23:18   #296
Thanked: 19 Times
The stretch between umerga and aland is ok not bad. It took me 7 hours from solapur to hyderabad.
nawabnabeel is offline   Reply With Quote
Old 5th June 2014, 13:27   #297
vnabhi's Avatar
Thanked: 1,142 Times
To summarize, taking the 70 km detour via Aland from Umerga adds around 1.5 to 2 hours to the normal time from Hyderaad to Solapur, when the road was good.
But I've read on this forum that the road between Zaheerabad to Umerga is not that bad nowadays. If this is correct, then is it still adivisable to take the detour?
Old 5th June 2014, 13:55   #298
Hi -
Zaheerabad - Bidar
Humnabad - Solapur
Solapur - Pune
& thereafter ???
Can you share updates on the road condition based on your trip?
RoadSafety_RR is offline   Reply With Quote
Old 5th June 2014, 15:28   #299
Thanked: 19 Times
Can you please confirm about the road condition because as far as I know absolutely no repair work has been carried out on this stretch an it has atleast 100kms of pot holed and crater filled road on which I have to drive my vento in 2nd or 3rd gear.
Old 5th June 2014, 23:15   #300
vnabhi's Avatar
I've not traveled on that stretch for years. I was referring to ranjitp1's post of May that says it should take around 6 hours to reach Solapur from Hyderabad.
Hyderabad - Goa : Route Queries kiranpashtakar Route / Travel Queries 893 26th April 2017 14:30
Bílore-Hyderabad-Nagpur-Jabalpur-Maihar Route/Hotel/Food Queries. Su-47 Route / Travel Queries 14 19th April 2017 16:42
Pune to Hyderabad : Route Queries shoky Route / Travel Queries 549 10th April 2017 15:06
Hyderabad to Nasik : Route Queries lejhoom Route / Travel Queries 24 18th January 2016 14:06
Hyderabad - Coonoor - Ashtamudi: Route & Accommodation Queries MileCruncher Route / Travel Queries 2 5th January 2011 23:01
