Old 21st July 2013, 15:51   #121
Thanked: 134 Times
Default re: Hyderabad to Srisailam : Route Queries
Originally Posted by YanTra Makto View Post
Thanks for the other advises, any idea regarding the round trip time for Akka Mahadevi?
Round trip time for Akkamahadevi Caves would be around 3 hours, but you may have to go in early to get the tickets and possibly wait while the boat starts, so keep at least 4 hours.
deepv is offline   (1) Thanks Reply With Quote
Old 22nd July 2013, 07:43   #122
YanTra Makto's Avatar
Thanked: 378 Times
Thanks deepv, when you say early, how early does it mean. I mean the rides start at what time, are there 2/3 trips in a day? or just one ?
YanTra Makto is offline   Reply With Quote
Old 22nd July 2013, 20:49   #123
Thanked: 134 Times
I think the first boat ride was around 10 - 10:30am for the morning slot, and mostly there were 2 for the day last time I went. But there may not be any if minimum count is not met according to their capacity, so most practical option remains the first boat.
Besides, they start giving tickets for them only when they are sure that nos. are getting met based upon ppl coming and enquirying. In fact I remember the APTDC booking guy giving me a call back for taking tickets as he initially told us to wait and we just went around for a stroll.
But this is when nos. are less, if its otherwise then the earlier you are there the better it would be.
Old 26th July 2013, 16:03   #124
ranjitp1's Avatar
Thanked: 1,742 Times
http://timesofindia.indiatimes.com/c...w/21348176.cms
Srisailam dam seems to be full and would be quite a sight.
ranjitp1 is offline   (1) Thanks Reply With Quote
Old 26th July 2013, 16:17   #125
Thanked: 351 Times
Not full as yet. It is at 849 feet only whereas the full capacity is 885 feet which is a huge quantity of water. They plan to start power generation when it touches 854 feet.
hyd_traveller is online now   (1) Thanks Reply With Quote
Old 31st July 2013, 10:51   #126
Thanked: 134 Times
Originally Posted by hyd_traveller View Post
Not full as yet.
Srisailam crest-gates have indeed been opened yesterday, and should continue to remain so for next few days as per the following.
http://www.thehindu.com/todays-paper...cle4972294.ece
Time to plan for a weekend drive!!!
Old 31st July 2013, 11:14   #127
ranjitp1's Avatar
Yes the gates have been open as of yesterday.Somebody who was there yesterday send me pictures and it looks as beautiful as ever.However not all the gates are open,only 4 iirc are open as of now,but if the rains stay this way its just a matter of time for the others to open.
ranjitp1 is offline   Reply With Quote
Old 7th August 2013, 16:34   #128
Thanked: 134 Times
More gates opened later last week (http://www.thehansindia.com/2013/08/...am-dam-lifted/), any updates on the situation this week??
I could not find any info upon closing of gates, was wondering how would things be coming long weekend.
deepv is offline   Reply With Quote
Old 11th August 2013, 19:24   #129
vnabhi's Avatar
Thanked: 1,240 Times
More gates opened later last week (www.thehansindia.com/2013/08/01/gates-of-srisailam-dam-lifted/), any updates on the situation this week??
All gates were closed yesterday when we made a sudden trip to Srisailam. However, the following updates on road conditions and distances might be of interest to travelers:
  • Distance from Moshin Brothers IBP petrol bunk opp NIMS to temple parking lot: 234 kms. Route taken was via PVNR flyover > ORR entry just after Shamshabad Jn > ORR exit for Srisailam Road > Amangal > Kalwakurthy > Dindi >Mannanur forest check post > Srisailam Dam > Srisailam temple
  • Time taken : 4 hours 15 minutes. Dindi, which is 135 kms away, was covered in 2 hours, and the balance 99 kms took 2 hours 15 minutes. Numerous speed-breakers and ghat roads have an effect on your average speed.
  • Roads were good throughout, barring very few pot holes. But the sudden speed-breakers between Kalvakurthy and Dindi can ruin your car, as the roads are decent enough at some stretches for triple digit speeds. God saved me when I was doing 95 and saw an opposite direction Safari bouncing 100 meters ahead. I slammed the brakes and went over it at a very safe speed. On my return direction, I saw an Innova with a dented bonnet at the road side at that same spot. I guess he might have rear-ended someone.
  • There are several speed-breakers on the first 20 kms of the nearly 50-km forest stretch that starts from Mananur check post. These were not there in June 2007, when I had last traveled.
  • The ghat starts around 8 kms before Mananur check post, in a non-forested area. The forest stretch starts closer to Mananur.
  • Farhabad is around 17 to 18 kms from Mananur (for those keen on visiting the forest view point). Beware of monkeys darting across the road.
  • Descending to the bridge level in the Dam area and ascending on the other side takes a lot of time, if there are many vehicles. It took me 40 minutes to cover the 20 km distance to the temple from the dam's viewpoint from where one descends to the bridge level.
  • One needs to be very wary at hair-pin bends of RTC buses, as they have a very poor turning circle. I had to reverse 30 feet at one spot to allow one to complete its turn. I could not spot the bus in time due to foliage.
  • It is easy to miss the right turning at spots such as the right turn towards Dindi after Kalwakurty. This spot has a tiny board which can easily be missed. It is around 5 to 7 kms after the left turn at the T Junction at Kalvakurthy.
  • Another confusing spot comes at odometer 147 (12 kms after Dindi reservoir). One needs to turn left at the small junction here. Going straight will take you to Achampet.
  • Finally, around 7 kms before the temple, one needs to take a right turn at a T Junction. Left will take you to Dornala. This is well-marked. Remember to take a left turn here on your return. The sign board can be seen only after taking the left turn.
  • After Mananur, in the stretch when one is descending the final leg of the ghat, there is a confusing spot. One needs to take the right turn and not the gradual left which takes you towards Atchampet.
  • Lastly and most importantly, please note that the temple closes between 330 pm to 6 pm. We were lucky to reach at 245, and come out by 330, when the crowd was the thinnest.
  • The return journey should not be attempted after 730 pm, as the first check post from Srisailam side at the beginning of the forest stretch closes at 830 pm. It takes around an hour to reach that spot.
Edit: I forgot to mention that I'd taken the Fiesta for the journey. The FE came to 14.5, despite ghat sections, which is very decent. My wife was asking why I did not take the diesel Figo, as it would have saved us some cash. But the tremendous low-end torque of the 1.6 liter duratec can be best exploited only on such journeys. No vehicle that was on the road yesterday could keep up with the car. A Vento and an old-gen Verna diesel were trying hard to keep pace, but whenever a speed-breaker came, they were falling way behind. This apart, over-taking on narrow stretches was simply awesome. The sound of the engine as she revvs over 4K rpm is simply ecstatic, and brought a grin from ear to ear many a time. Good OEM headlights were also a boon on the return journey--way better than the Figo's.
vnabhi is offline   (3) Thanks Reply With Quote
Old 11th August 2013, 20:31   #130
Thanked: 378 Times
Talking re: Hyderabad to Srisailam : Route Queries
Thanks for the route update. Hopefully the google map on my android will prove to be true and save the confusions and wrong roads!
Old 12th August 2013, 11:29   #131
vnabhi's Avatar
You can try your luck. I had an updated version of Satguide maps on my Garmin device, which proved to be a darn waste on this trip. Most of the time it kept saying 'traveling on unknown road' and 'recalculating, take a U turn', even though i was on the correct path. At places it showed me going through fields too.
Being a June 2013 version, it was simply not worthwhile on this trip. It was indeed very good last year at Bangalore and Ooty. I'll change the map to the link posted on the GPS thread today itself.
vnabhi is offline   (1) Thanks Reply With Quote
Old 12th August 2013, 11:37   #132
mobike008's Avatar
Thanked: 8,037 Times
Thanks for the detailed update on the route and other important info. As you know, i too had been to Srisailam earlier this year and experienced two similarties as mentioned in your report
1. Experienced the sudden appearance of speed breakers and it took me by surprise many times. Infact, I saw a nasty incident when an Indica slowed down unexpectedly and a different hatchback ( dont remember which car) hit it with full force from behind. Hyd_Traveller also saw this accident as he was on his way back to Hyderabad
2. The sign where you need to take a left turn was missed and i took a detour of 40kms through some really bad roads to rejoin back on the main Srisailam highway
Old 12th August 2013, 11:41   #133
vnabhi's Avatar
That makes two of us. I missed both turnings, but retraced my path within half a km at each spot by stopping and asking. I was lucky that there was someone around to answer. This apart, both places provided an opportunity for a bio-break.
Old 12th August 2013, 12:06   #134
Thanked: 134 Times
[*]Roads were good throughout, barring very few pot holes. But the sudden speed-breakers between Kalvakurthy and Dindi can ruin your car,
[*]There are several speed-breakers on the first 20 kms of the nearly 50-km forest stretch that starts from Mananur check post. These were not there in June 2007, when I had last traveled.
[*]It is easy to miss the right turning at spots such as the right turn towards Dindi after Kalwakurty. This spot has a tiny board which can easily be missed. It is around 5 to 7 kms after the left turn at the T Junction at Kalvakurthy.
Thanks for the details/updates .. Venu Sir!!
I kept on deliberating for going this weekend, finally pushed it to next, looks like we would have missed the gates in any case.
I had last done Hyd-Srisailam in 2011 (twice, in Jan & Aug), those speed breakers were there then.
The first time, while going, they troubled me a lot for the same reason. However it was better while returning (in evening) because it would get easier to locate them in your headlight's beam, though locating those crucial turns becomes a little difficult.
Same with me, these apart Hyd-Srisailam is quite peaceful drive to make with not much traffic - trucks, etc.
Old 12th August 2013, 20:36   #135
Thanked: 134 Times
  • Distance from Moshin Brothers IBP petrol bunk opp NIMS to temple parking lot: 234 kms. Route taken was via PVNR flyover > ORR entry just after Shamshabad Jn > ORR exit for Srisailam Road > Amangal > Kalwakurthy > Dindi >Mannanur forest check post > Srisailam Dam > Srisailam temple.
Ppl,
I am planning to go to Nagarjunasagar as well from Srisailam, this weekend.
Which one would be better route for Srisailam -> N'sagar:
1. through Dornala - Macherla (175 km), or
2. through Mannanur - Back to Kawalakurti T junction - Devarkonda (220 km).
On #2, its possible to make some shortcuts instead of going to Kawalakurti Road, however just to be on safe side (& good road) the above looks better.
Otherwise, on #1 side if the road conditions are OK, I won't mind taking that route as I haven't gone there.
It appears ghat sections are good as well, though I got feedback from some friends last year that roads were quite narrow and/or in bad condition.
While returning from N'sagar, I believe it should be better to take (Halia - Nalgonda - NH9, 172 km) route rather than Nagarjuna Sagar Road (161 km).
Any insights?
Bangalore - Srisailam - Hyderabad : Route Queries Ram Pratap Route / Travel Queries 36 18th August 2017 20:32
Chennai to Srisailam : Route Queries shenbag63 Route / Travel Queries 16 6th June 2016 22:37
Hyderabad - Srisailam - Dornala - Kurnool. Road pictures only IndianNomad Travelogues 39 18th September 2013 11:19
Hyderabad Srisailam Nagarjunsagar pravdr Route / Travel Queries 34 26th December 2012 17:30
hyderabad srisailam nagarjunsagar hyderabad warangal hyderabad pravdr Travelogues 61 2nd May 2010 21:52
