Old 9th October 2012, 13:25   #4201
mpksuhas's Avatar
Thanked: 3,372 Times
Default re: All Roads to Kerala
Originally Posted by sridharp77 View Post
I am reluctant to take the route via Mysore because of the protest near Mandya effecting Bangalore - Mysore highway. Is there any alternate route to Mysore without touching Mandya.
My friend did Bangalore -Mysore on 7th Sunday. No issues, also if you starting from Bangalore you can plan in a way as to cross Mandya before ~ 5 AM.
mpksuhas is online now   Reply With Quote
Old 9th October 2012, 20:59   #4202
ak916's Avatar
Thanked: 145 Times
hello everyone,
Wanted some info on the route between Mangalore and Kochi. I am planning to drive from Bangalore to Kochi via kasargod sometime this month. I know that the ghat section before mangalore is pretty bad. Are there any other bad stretches to look out for between Mangalore and Kochi. I have done Tirur - Kochi a couple of months ago but clueless about the rest of the stretch.
part of the reason to do this stretch is to avoid any untoward incidents in relation to cauvery issue on the TN side. Thought, I might as well take a round about and stop at Bekal and do some sightseeing along the way to Kochi.
Any inputs welcome.
ak916 is offline   Reply With Quote
Old 10th October 2012, 21:59   #4203
DieselLover's Avatar
Thanked: 86 Times
I am plannig a short vacation along with family during Oct 26th-28th (starting 26th morning and returing 28th eve). We have shortlisted Coorg, Wayanad or Rameswaram as possible destinations. Wayanad is comparatively closer (from Thrissur) as against other two places. But I would like to know which will be a better destination considering the current climate and road conditions? Appreciate if someone can suggest the best route to these locations from Thrissur with approx driving time.
We originally wanted to go to Mysore but dropped it in view of the ongoing Kavery issue. We are 4 adults - self, wife, parents + 2 yr old kid and I am going to be the only driver, driving a swift.
DieselLover is offline   Reply With Quote
Old 10th October 2012, 22:26   #4204
ampere's Avatar
Thanked: 8,760 Times
You can try Valparai also. Its just about 150km from Trichur. Makes a nice getaway from the usual din of a regular tourist place. On the way you can also check Athirapally.
Old 10th October 2012, 22:58   #4205
Thanked: 86 Times
Actually,.we did visit valparai, munnar last month
Old 11th October 2012, 05:54   #4206
ranjitp1's Avatar
Thanked: 1,742 Times
The weather at Coorg is definitely going to be far better than what one can expect at Wayanad or Rameshwaram.You should be able to make it to Madikeri in approximately 7hrs from Thrissur.Plenty of accomodation options available depending on your budget.Wayanad is closest of the three at about 5hrs drive time.but both the places need atleast a good full two days to do justice to the places-Imho.even Rameswaram is a long drive for a 3day,one more day would have been perfect.my vote goes for Wayanad
ranjitp1 is offline   Reply With Quote
Old 11th October 2012, 09:52   #4207
Thanked: 86 Times
Thanks Ranjith. I may probably drop Rameswaram as the drive look very hectic for a 3 day plan. We cannot extend the vacation either.
It's a close call between Wayand and Coorg. Where should we stay if opting for Wayanad? The places of interest in Wayand seems to be spread over a large area.
Old 11th October 2012, 10:44   #4208
ranjitp1's Avatar
Depending on your budget,Wayanad has all kinds of places now a days.Vythiri is good to keep as your base,Green Gates resort is another nice place to stay if budget permits.Vythiri resort is good.If you want the normal hotel kind of stay then Mint at batheri is good,then there is Isaac Regency at Batheri.Windflower at Vythiri is also good.I would suggest stay at Vythiri and go around as its much more scenic.
Coorg would be a long drive imo,and roads are just about ok.
ranjitp1 is offline   (1) Thanks Reply With Quote
Old 11th October 2012, 12:25   #4209
Thanked: 12 Times
Hello Everyone,
Need your expert advice on the route query from bangalore to Kochi, I am planning to drive from Bangalore to Kochi airport on 12-Oct-12.
I am planning to do following route
Bangalore - Salem- CBE By pass- Palakad- Thrisur- Kochi Airport
which is appr 550 kms and planning to cover in 9 hrs with less break ( start time from bangalore ( Marthahalli around 2:00 PM )
how are roads in the above routes and do I need to take care of anything especially related to traffic. Also some where in the forum I read there is alternate route via Pollachi, does it save time and does it require lot of deviation from normal route.
many thanks in advance
soarer is offline   Reply With Quote
Old 11th October 2012, 12:52   #4210
ranjitp1's Avatar
Originally Posted by soarer View Post
Hello Everyone,
Since its an afternoon start,dont bother going via Pollachi,stick to NH47 till Palakkad.From Palakkad take the Palakkad-Ottapalam-Shoranur-Wadakancheri-Thrissur-NH47-Angamaly-Nedumbassery Airport.
Do not continue on NH47 beyond Palakkad as the road is all broken up,hence the detour via Shoranur.
BLR-Salem: 3hrs
Salem-Avinashi:3hrs
Avinashi-Walayar:1.5-2hrs
Walayar-Palakkad:45mins
Palakkad-Shoranur-Thrissur:2hrs
Thrissur-Airport: 1hr
Heres the map of the detour from Walayar to Thrissur NH47.
https://maps.google.co.in/maps?saddr...via=3&t=m&z=16
Old 11th October 2012, 17:41   #4211
Thanked: 89 Times
See if this helps for your stay at Wayanad http://www.team-bhp.com/forum/travel...li-blooms.html (Wayand - JRW Thirunelli and Blooms)
I would anyday prefer a homestay. There are some good homestays at Meppadi. All the good waterfalls and some of the scenic routes are here. Try valley avenue homestay, we have stayed there couple of times.
http://www.valleyviewavenue.com/contact.html
Fauji had a good time at glenora homestay.
VindyWheels is offline   (1) Thanks Reply With Quote
Old 12th October 2012, 15:54   #4212
Soccerfan's Avatar
Thanked: 54 Times
Any repair work started in the Alappuzha-Kayamkulam stretch of NH ?
Soccerfan is offline   Reply With Quote
Old 12th October 2012, 16:20   #4213
govigov's Avatar
Thanked: 454 Times
Yes. Travelled last Monday. Just regular patch work. No re tarring. Work is slow in progress. Expect bumpy rides.
govigov is offline   Reply With Quote
Old 12th October 2012, 16:35   #4214
Thanked: 55 Times
Posting my Query from Kannur thread
I am completly new to north Kerala, I need to go to Bekal and I could not find an active thread for Bekal hence posting here. Can you suggest the best route options, please? I came across the following options going through the thread.
1. Bangalore - Mysore - Madikeri - Baghamandala - Panathur - Kanhangad - Bekal
2. Bangalore > Srirangapatna > Round about sharp turn to right > Elivala > Bilikere > Hunsur > Kampala pura > Periya patna > (Mysore - madikeri road) Kushalnagara(follow orange county board, Take the left from circle where you see board toards DUBARE Camp (do not miss) ) > iddapura > Ammathi town > Virajpet > Koottupuzha Bridge, Thalassery Coorg Road > Iritty > Bekal.
3. Bangalore > Srirangapatna > Round about sharp turn to right > Elivala > Bilikere > Hunsur > Kampala pura > Periya patna > (Mysore - madikeri road) Kushalnagara(follow orange county board, Take the left from circle where you see board toards DUBARE Camp (do not miss) ) > iddapura > Ammathi town > Virajpet > Sulya > Bekal.
4. Bangalore - Kunigal - Hassan - Sakleshpur - Nelyady - Bekal
5. Bangalore - Srirangapatna - Round about sharp turn to right - Elivala - Bilikere - Hunsur - Kampala pura - Periya patna - (Mysore - madikeri road) Kushalnagara - Madikeri - Sulya - Bekal
Can you also suggest the safest and scenic route?
RSimonS is offline   Reply With Quote
Old 12th October 2012, 20:05   #4215
Thanked: 239 Times
@RSimonS, The option 1 is the shortest but due to the ongoing cauveri issue it is not good idear to drive through mysore road. My suggestion would be
Bangalore - Kunigal - Hassan - Sakleshpur -Uppinangadi - Puttur - Vittal - Kasargod (town) - Bekal.
Rajesh
RajeshK is offline   (1) Thanks Reply With Quote
Trivandrum - Kasargode - Mangalore - Kollur :: Kerala Roads - An update convivial Travelogues 26 6th September 2016 15:46
Kerala: Speed limit on highways and 4-lane roads revised darklord Street Experiences 39 11th February 2016 08:31
Horrible private bus drivers in Kerala roads Traxter Street Experiences 33 9th December 2014 16:43
Idukki-Kerala's best driving roads? rippergeo Travelogues 103 7th June 2012 06:29
Kerala Roads - Unimaginably Pitiable condition emkay456 Street Experiences 30 1st February 2008 20:12
