Old 3rd January 2015, 23:44   #8116
gypsyFreak's Avatar
Thanked: 188 Times
Default Re: All Roads to Kerala
Hi All,
What is the best route from Thiruvananthapuram to Mysore? I would like to avoid NH17 as much as possible and look at other better options.
I will be driving a Scorpio with senior citizens onboard.
What are options for food? Planning to start at 6-7 am so as to reach Mysore before dark.
gypsyFreak is offline   Reply With Quote
Old 4th January 2015, 00:38   #8117
ampere's Avatar
Thanked: 9,108 Times
Originally Posted by gypsyFreak View Post
Hi All,
First on the route:
TVM-Madurai-Dindigul-Kangeyam-Chengapally-Gobi-Sathyamangalam-Chamarajanagar-Nanjangud-Mysore
- TVM-Madurai: You can go either Tenkasi or take the 4-lane via Nagercoil.
- Dindigul-Kangeyam: Either you can do: Dindigul-Odanchatram-Dharapuram-Kangeyam or Dindigul-Aravakurichi-Kangeyam.
- Sathyamanagalam-Chamarajanagar has ghat section (26 hairpins at Dimbam).
- Its good road, but a bad luck can cause a truck to break-down on the hairpin. Traffic is unmonitored.
On Timings:
- Its about 700km of drive. Thats easily 10-12hours of drive.
- Hence I would advise an start much earlier than 7AM. May be 4AM ?
- Madurai bypass has options for food. But once you are out of NH7 (4-lane) you are restricted to small hotels in town.
- Chamarajanagar has Nijaguna residency.
ampere is offline   (1) Thanks Reply With Quote
Old 4th January 2015, 16:20   #8118
Thanked: 593 Times
Originally Posted by joecherian View Post
Is the pollachi palladam route supposed to have foggy conditions?. Today morning, when I did this section, there was moderate to heavy fog in this section.
I must have passed that stretch around half an hour later (I started from Vyttila about 20 minutes after you started from Edappally), but don't recall encountering any fog. Was this somewhere close to Palladam ? (I turned left towards Annur at Kamanaikenpalayam - about 12 kms before Palladam)
kala is offline   Reply With Quote
Old 4th January 2015, 18:14   #8119
joecherian's Avatar
Thanked: 78 Times
I think it was close to palladam. All the vehicles had to drive with headlights on as the visibility was really bad.
joecherian is offline   Reply With Quote
Old 4th January 2015, 18:37   #8120
nidhinsarath's Avatar
Thanked: 96 Times
I am doing a calicut - Mangalore drive this week. Please suggest a route for the same. In google maps there is a deviation after valapattanam which avoids pariyaram and directly enters into cheruthazham. How is the condition of this road? There is a slight reduction of around 5km in this new route but its better avoiding windy stretches near pariyaram. Suggestions please!
nidhinsarath is offline   Reply With Quote
Old 4th January 2015, 18:42   #8121
kutlee's Avatar
Thanked: 202 Times
Trivandrum Nagercoil is in good condition now Some rough patches exist till Marthandam or so. But after that it is smooth. Couple of town entrance and exists are bad patches about 100 meters or so. Rest is good.
kutlee is offline   (1) Thanks Reply With Quote
Old 4th January 2015, 19:23   #8122
Thanked: 1,664 Times
Originally Posted by longhorn View Post
Just one word for the Vadakkenchery - Madukkarai stretch - AVOID. I wasn't very sure of the turn off at Vadakkenchery and more importantly how to latch onto the Palladam road at Pollachi which is why I took the Palakkad route.
I started from Ernakulam at 5:20 AM today and it was bright enough when I reached Mannuthi. But even then the Mannuthi-Vadakkecherry stretch was a torture with lots of oncoming traffic making overtaking near impossible - hence having to crawl behind a convoy of some 30-40 vehicles led by some slow moving truck. Not having oncoming headlights is certainly a help in that scenario.
I started from Perumbavur at 5 AM and reached the end of the dual carriageway by around 6; day hadn't broken by then. So my Kuthiran was in darkness. The danger of oncoming headlights is very real; I just stuck behind a truck moving at a reasonable clip and functional tail lamps. I suppose Bharat Benz trucks haven't reached the level of disrepair that one sees in Ashok Leyland or other brand trucks. :-)
The turn-off at Vadakkenchery for Pollachi is signposted on NH 47. It is a right turn just before a bridge. If you take that, you might get stuck at the bridge itself, which is barely one lane and in pretty bad shape. The right thing to do is to cross that bridge on NH 47 and then take the right turn immediately afterwards.
Note that the road you take after the left turn (before the construction zone), has a right angled turn at one place. This is almost a blind turn, don't go straight here, it leads to a place called Ambalapuram or something like that.
I came that way this morning. The best route is to take a left at Uthukuli (The straight road is blocked with barricades anyway due to the Railway overbridge construction ahead), reach the Palghat-Pollachi road, turn right there and proceed straight - you'll eventuall reach the Palladam road.
This was pretty easy; as the straight road is completely barricaded and I negotiated the turns on the by-pass/detour following a bus towards Pollachi. But I can see that it could be confusing when alone; the thing is to take the detour to its end, take a sharp left turn and then take an equally sharp right turn with 50 metres.
Originally Posted by B103 View Post
The other road via Vadakkencherry - Nemmara - Kollengode -- Pollachi could be better than the one I drive. There was some festival ongoing at Kollengode temple.
The roads in Nenmara and Kollengode (and generally the entire strech in Kerala) is pretty narrow, so any disturbance has the potential to create a jam.
Today for me fog started soon after I left Pollachi behind; this was after 8 AM. Visibility was down to 50m for about 15km or so. Needed careful driving.
binand is online now   (1) Thanks Reply With Quote
Old 4th January 2015, 19:29   #8123
NPV
NPV's Avatar
Thanked: 5,296 Times
Chamarajanagar-Nanjanagud is quite bad per a friend who traveled last week, more painful if driving a low GC hatch or sedan.
NPV is offline   Reply With Quote
Old 4th January 2015, 19:48   #8124
sandsun7's Avatar
Thanked: 675 Times
Don't take that deviation. There is road widening happening under KSTP project on that stretch and is not advisable to take it till it is over. Instead, stick on to the national highway itself. The Taliparamba-Pariyaram stretch even though curvy is wide enough and should not be a problem at all.
See this post, where Bhpian 'Sachinnair' had reported about that route a week ago if you want further confirmation: http://www.team-bhp.com/forum/route-...ml#post3608744 (All Roads to Kerala)
sandsun7 is offline   (1) Thanks Reply With Quote
Old 4th January 2015, 20:03   #8125
venkyhere's Avatar
Thanked: 560 Times
perhaps the reason pollachi-palladam stretch is foggy could be because it is a very windy area (lots of windmills) where winds could be dragging moisture from the mountains to this "valley/pass"
venkyhere is offline   (1) Thanks Reply With Quote
Old 4th January 2015, 20:17   #8126
ampere's Avatar
The other option then is :
Chamarajanagar-Muguru-T Narasipur-Mysore.
Old 5th January 2015, 09:30   #8127
suresh_gs's Avatar
Thanked: 1,249 Times
Hi All,
I would suggest NH47 all the way till CBE by pass and then NH209 via Sathy, Chamarajanagar and Nanjangud.
Dhimbham ghats is a treat to drive with 27 hair pin bends.
suresh_gs is offline   (1) Thanks Reply With Quote
Old 5th January 2015, 12:19   #8128
Jaguar's Avatar
Thanked: 151 Times
Hi All,
I did Trivandrum - Bangalore last week and had mapped decent food stops between Trivandrum and Salem. Hope this helps https://goo.gl/maps/dCWEL
Once you cross Nagercoil, the road is brilliant and the drive is a breeze till almost you touch Salem, where traffic starts.
Driving through kerala, one wouldn't be able to do the journey in a day. The roads are narrow and speed cameras to boost. Plus, once you enter Palakkad district, the road condition is pathetic till you cross CBE. Madurai route is anyday better.
And I doubt, senior citizens would would have the same enthusiasm about the hair pins, that too after a full day's drive.
Jaguar is offline   (1) Thanks Reply With Quote
Old 5th January 2015, 12:36   #8129
procrj's Avatar
Thanked: 2,709 Times
Drove down Mysore > Nanjanagud > Gundlepete and the roads from Mysore - Nanjanagud are not great and the traffic on the road was a lot even at 9 am.
While coming back from kalpetta we did Gundlepete > Chamarajnagar > Muguru > T Narasipura > Talakad > Malavalli > Kanakpura. Gundlepete - Chamrajnagar is patchy but they are laying down new roads in some stretches. Chamarajnagar > Muguru > T Narasipura > Talakad > Malavalli is brilliant roads except for a small 5km stretch just after Talakad. Added advantage is a quick stop near cauvery river bank with beautiful view
procrj is offline   (1) Thanks Reply With Quote
Old 5th January 2015, 13:20   #8130
gypsyFreak's Avatar
Thanked: 188 Times
First on the route:
Thanks all for your replies.
Let me put down my itinerary and then the questions
Day 1 (Jan 22) : Mysore - Chamrajnagar - Sathy - Pallipalayam - Dharapuram - Madurai - Rameshwaram
Day 2 (Jan 23) : Rameshwaram - Tiruchendur
Day 3 (Jan 24) : Tiruchendur - Kanyakumari - Trivandrum
Day 4 (Jan 25) : Trivandrum - Mysore
Is the above routes doable in a Scorpio with senior citizens. There will be 5 adults and luggage. I will be the only driver.
Trivandrum to Mysore via Nagercoil, i feel is lengthier. I was looking at parallel route to NH 17.
How is NH 47 from Trivandrum to CBE?
Is any stretch 4 laned?
I don't mind 2 lane road as long as surface is smooth. I am fine for taking longer route if its comfortable, has food options and safe.
Thanks in advance.
Trivandrum - Kasargode - Mangalore - Kollur :: Kerala Roads - An update convivial Travelogues 26 6th September 2016 15:46
Kerala: Speed limit on highways and 4-lane roads revised darklord Road Safety 39 11th February 2016 08:31
Horrible private bus drivers in Kerala roads Traxter Street Experiences 33 9th December 2014 16:43
Idukki-Kerala's best driving roads? rippergeo Travelogues 103 7th June 2012 06:29
Kerala Roads - Unimaginably Pitiable condition emkay456 Street Experiences 30 1st February 2008 20:12
