Old 17th December 2015, 13:58   #9136
silversteed's Avatar
Thanked: 1,669 Times
Default Re: All Roads to Kerala
Originally Posted by MSAneesh View Post
Did you contemplate Chelari - Parappanangadi - Tirur - Chamravattom - Ponnani? Any idea how the road condition of this route? This used to be shorter and more importantly, less traffic.
Not sure about the latest state of the roads, but a month or so ago, the stretch took more or less the same time to cover, compared to the alternate routes. The roads are narrow and twisty as you approach Chamravattom bridge, then there were rough patches after Chamravattom, and Tirur-Parappanangadi-Chelari was not so easy on traffic. Especially the towns. I covered this stretch at around 11 o'clock on a weekend.
silversteed is offline   (1) Thanks Reply With Quote
Old 17th December 2015, 15:13   #9137
Sportsmind's Avatar
Thanked: 28 Times
Hai Kerala Bhpians,
My second and third legs of my South India Road trip covers Kerala and Tamilnadu.
Kindly update on drive conditions on Guruvayoor- TVM route. Please do indicate if the average speed /time is accurate.
Leg 3 is where I need more inputs, as it's the first time on this stretch. In particular the night drive conditions,as Kanyakumari to Rameshwaram sector would be post sunset. I have factored speed of 40 km/hr on this leg. Would that be fair?
Last edited by ampere : 17th December 2015 at 16:21. Reason: Back to back posts merged
Sportsmind is offline   Reply With Quote
Old 17th December 2015, 15:40   #9138
pramodpk's Avatar
Thanked: 474 Times
Originally Posted by Sportsmind View Post
Hai Kerala Bhpians,
What time of the day are you planning to drive from Guruvayur to Trivandrum?
Better to start early. A 5:00 AM start can take you to Trivandrum in 6 hours but an 8:00 AM start can take as long as 8 hours.
pramodpk is offline   (1) Thanks Reply With Quote
Old 17th December 2015, 16:17   #9139
Sportsmind's Avatar
Thanked: 28 Times
Thanks for the input. It would be most likely post 8, as we reach Guruvayoor around midnight. Temple visit with a few hours rest would easily be post 8.
Old 17th December 2015, 16:19   #9140
pramodpk's Avatar
Thanked: 474 Times
Not a good time to start. Expect an average speed between 30 - 40 KM/H.
pramodpk is offline   Reply With Quote
Old 17th December 2015, 16:26   #9141
Thanked: 1,668 Times
Guruvayur is a very crowded temple; people queue up for hours to have a darshan. I think average queue time is about 3-4 hours nowadays.
binand is offline   (1) Thanks Reply With Quote
Old 17th December 2015, 17:29   #9142
treadmark's Avatar
Thanked: 268 Times
As Binand mentioned nowadays you need to spend 3 hours for dharshan even on weekdays. Suggest to reach Guruvayoor before 8PM and make it for Athazha seeveli at 9 PM when the queue will be relatively less.
Cheers!
treadmark is offline   (1) Thanks Reply With Quote
Old 17th December 2015, 18:41   #9143
Thanked: 593 Times
That used to be the route I had been taking at most times in the past couple of years. But as @silversteed mentioned, passing the towns like Tirur, Tanur, Parappanangadi etc is quite a pain during the day time since the roads are narrow - and the traffic also has increased considerably these days. Also the roads were quite rough around Chamravattom the last time I passed through - that's why I thought of trying the Kottakkal route this time.
But then traffic on the Calicut-Kuttippuram stretch is also quite high during the day, and quite unruly as well - so not much to choose between the two really.
kala is offline   (2) Thanks Reply With Quote
Old 17th December 2015, 19:31   #9144
Traversing the towns in this route - Parappanangadi, Tanur, Tirur - is extremely taxing. Plus there is at least one railway level crossing at Chettipadi (the other two probably have overbridges now).
binand is offline   (2) Thanks Reply With Quote
Old 18th December 2015, 12:13   #9145
theexperthand's Avatar
Thanked: 1,242 Times
Originally Posted by B103 View Post
Since you are starting by morning, taking NH all the way is the best option as Pramod suggested.
For return trip, you can come via MC road till Chengannur -> Tiruvalla -> Changanacherry bypass -> Putupally -> Ettumanoor (outer) -> Talayolaparambu -> Tripunithura -> Seaport airport road ->Irinjalakuda.
This can be done more or less in predictable time and also will help to avoid:
1) Construction work in Changanacherry - Kotttayam section of MC road
2) traffic jams inside Kottayam town
3) traffic jams in Ettumanoor
4) traffic jams inside Cochin
Originally Posted by JohnnyBoss View Post
Instead of coming to Tripunithura from Thalayaloparambu, proceed straight via Mulanthuruthy, Chottanikkara (bypass) and Karingachira to enter A-S Road. this way you can avoid Tripunithura traffic also. Traffic at Karingachira Jn. may be a bit high during evening hours, though.
Thank you B103 and Johnny for the inputs - I will stick to the route mentioned by you both and will update after the travel.
--Anoop
theexperthand is offline   Reply With Quote
Old 18th December 2015, 18:37   #9146
Thanked: 593 Times
For the onward journey I would suggest Irinjalakuda-Kodungallur-Paravur-Edappally and then NH47 from thereon instead of NH47 all thw way (via Potta). The Alwaye-Edappally section of NH47 is very very messy with the metro construction - I got stuck for about half an hour at a diversion near Kalamassery at 5:30 AM yesterday morning. NH17 should be relatively better to get to Edappally early in the morning.
kala is offline   (1) Thanks Reply With Quote
Old 18th December 2015, 18:45   #9147
Thank you! This is the same advice I got from everyone, so I am sticking with the Kodungallur - Paravoor route.
--Anoop
Old 18th December 2015, 22:19   #9148
sunnyman_46's Avatar
Thanked: 7 Times
Dear Friends,
I am traveling from Vythiri(Wayanad) to Kochi. Which is the best possible route to take?
sunnyman_46 is offline   Reply With Quote
Old 19th December 2015, 08:16   #9149
Originally Posted by sunnyman_46 View Post
Dear Friends,
Please scroll a few pages back to see recent conversations. Kochi to Wayanad and back were discussed at least twice in the last 15-20 days.
This query, and the discussion that followed:
http://www.team-bhp.com/forum/route-...ml#post3859042 (All Roads to Kerala)
This trip report:
http://www.team-bhp.com/forum/route-...ml#post3871706 (All Roads to Kerala)
binand is offline   Reply With Quote
Old 19th December 2015, 12:10   #9150
Surprise's Avatar
Thanked: 272 Times
Route query, but not road
Planning for a boat ride. Looks like there are options like Alappuzha-Kollam-Alappuza, Alappuzha-Kumarakom-Alappuzha, Alapppuzha-Thathampally lake etc. Which would be the most scenic and ideal for clicking pictures
From Kumily to Alappuzha, the best and shortest route is via Mundakkayam, Pulikkal Kavala, Karukachal and Chenganassery.
On your return, I would suggest go either via Kayamkulam, Adoor, Pathanapuram as MC Road has some work is being carried out
https://goo.gl/maps/BXf21PxCDjx
https://goo.gl/maps/KJiRLXrdx1p
Thanks. As suggested I will be taking those routes....just to reconfirm on correctness, I have attached the maps above
Originally Posted by JohnyRider View Post
You can easily cover Kumily Alleppy by 4.5 hours. Please note - there are many dangerous curves between Kumily and Peruvanthanam.
Alleppy Tenkasi via Kayamkulam can easily cover by 3.5 hours. You may visit Thenmala Eco tourism and Palaruvi on your way to Tenkasi.
http://thenmalaecotourism.com/home.php
https://www.keralatourism.org/shooti...ns/palaruvi/16
Thanks for those links...will cover minimum the Palaruvi.
Surprise is offline   Reply With Quote
Trivandrum - Kasargode - Mangalore - Kollur :: Kerala Roads - An update convivial Travelogues 26 6th September 2016 15:46
Kerala: Speed limit on highways and 4-lane roads revised darklord Road Safety 39 11th February 2016 08:31
Horrible private bus drivers in Kerala roads Traxter Street Experiences 33 9th December 2014 16:43
Idukki-Kerala's best driving roads? rippergeo Travelogues 103 7th June 2012 06:29
Kerala Roads - Unimaginably Pitiable condition emkay456 Street Experiences 30 1st February 2008 20:12
