Old 1st March 2016, 07:13   #9331
Thanked: 1,625 Times
Default Re: All Roads to Kerala
Originally Posted by TheHkrish View Post
I could not find any Problem with the above Kalpetta --> Mananthavady route.
You went through Mananthavady town, is it? Not the shorter Panamaram-Koyileri-Mananthavady bypass route that doesn't go into the town?
Even then, there are some bad sections between Kambalakkadu-Panamaram. Altogether my weekend Calicut trip assessment was that I'd rather avoid the Kalpetta-Mananthavady-Mysore route till they fix the road section in Kerala.
binand is online now   Reply With Quote
Old 1st March 2016, 08:34   #9332
arjithin's Avatar
Thanked: 1,412 Times
How does one spot the exit from Sankari to the Edappadi road ? And then the (right?) turn from Tharamangalam towards Omalur ?
There are two routes
1. While coming from Coimbatore side, once in Sankari bypass, look for the signs for a Maruti Tata service center. You will find 2-3. Turn left at the junction. Turn (first) right to a single lane road around 1 km ahead. At the end of road turn left to Tharamangalam road. Turn right at Tharamangalam towards omalaur.
2. Get into Sankari town. Turn left to Tharamangalam road after town.
I always take option 1
Here is a dashcam video (All Roads to Kerala) of option1
arjithin is offline   (1) Thanks Reply With Quote
Old 1st March 2016, 09:52   #9333
pramodpk's Avatar
Thanked: 473 Times
Originally Posted by arjithin View Post
That's second good news in a row; first was the Gudalur - Gundlupet section.
How about sankari - Edappadi section? That was equally bad last time.
Take option 1 but instead of taking a right to the single lane road, proceed to Edappadi, Tharamangalam & Omalur. This is the first time that I took the Edappadi route and it is in excellent condition. This is faster than taking the single lane road.
pramodpk is offline   (3) Thanks Reply With Quote
Old 1st March 2016, 10:22   #9334
reignofchaos's Avatar
Thanked: 1,266 Times
Folks - planning to do a weekend trip on the 25th long weekend to Varkala beach from Bangalore. Could you suggest the best route? Google maps suggests
Bangalore-Krishnagiri-Salem-Madurai-Tirumangalam-Sriviliputhur-Rajapalyam-Shenkottai-Thenmala-Pariapally-Varkala
Is this the best route? I wanted to be on NH7 for as long as possible as someone mentioned in the bangalore trivandram thread that roads are bad in the Tirumangalam - Shenkottai stretch and I found the following route:
Bangalore-Krishnagiri-Salem-Madurai-Tirumangalam-Nallathinputhur-Kalugumalai-Sankarankovil-Chintamani-Shenkottai-Thenmala-Pariapally-Varkala
Does anyone have a clue about SH76 between Nallathinputhur and Chintamani? I am worried about how bad these roads are as I have a car with 145mm ground clearance.
Finally does it make sense to go via the Dindigul-Theni-Kumily-Kottayam-Varkala route instead of this one?
It would be longer but a friend of mine suggests that I take this route as it is in decent condition.
Old 1st March 2016, 10:57   #9335
NPV
NPV's Avatar
Thanked: 5,164 Times
Looked at gmaps and it's a little confusing since thee is a sankari-idappadi road from NH 47 and also another one going almost parallel. Which is the road you took ?
NPV is offline   Reply With Quote
Old 1st March 2016, 11:14   #9336
pramodpk's Avatar
Thanked: 473 Times
I took the Sankari - Idappadi road. The parallel road was not in good condition when I travelled last.
pramodpk is offline   (1) Thanks Reply With Quote
Old 1st March 2016, 11:23   #9337
suresh_gs's Avatar
Thanked: 1,222 Times
For people going to North Coimbatore, instead of going Via Mettur-Bhavani, they can take the Mecheri, Nangavalli, Jalakandapuram,Idappadi road to Sankagiri.
suresh_gs is online now   Reply With Quote
Old 1st March 2016, 14:24   #9338
NPV
NPV's Avatar
Thanks!
So, is this the same turn off as @arjithin mentioned and the dashcam footage in ivento's post shows ? Or is it an earlier turn off ?
Old 1st March 2016, 14:40   #9339
pramodpk's Avatar
Thanked: 473 Times
Thanks!
The NH47 exit is the same as the one arjithin mentioned and showen in the dashcam footage but do not take the right turn ( at 3:49 in the footage) in to the single lane road. Continue straight to Idappadi. This has better roads.
pramodpk is offline   (2) Thanks Reply With Quote
Old 1st March 2016, 16:27   #9340
arjithin's Avatar
Thanks. Driving to TCR this Friday night and coming back on Monday. Will try this route.
arjithin is offline   Reply With Quote
Old 2nd March 2016, 21:21   #9341
Thanked: 67 Times
Hi suresh_gs, would you have an update on the road conditions on this route? How much time would it take?
MinivanDriver is offline   Reply With Quote
Old 4th March 2016, 13:56   #9342
naveen.raju's Avatar
Thanked: 3,551 Times
Guys,
Need route suggestions to Wayanad, Kuruvadweep to be exact. I am planning to take NH 47 and then Shornur road from Mannuthy. It will be an early morning start (4.30 or 5am) from Cochin.
Kindly suggest. Thanks in advance.
naveen.raju is offline   Reply With Quote
Old 4th March 2016, 17:52   #9343
The safest would be to not go to Shornur at all, but to Calicut via Kunnamkulam > Kuttipuram > Valanchery (NH47 > NH17). From Calicut to Kalpetta (NH 212) and then onwards smaller roads to Kuruva.
If you do go to Shornur then a possibility is Shornur > Pattambi > Perinthalmanna > Manjeri > Arekode > Thamarassery. I am not sure of the final few kms of this route (Mukkam-Thamarassery), rest all is good. From Thamarassery you take NH 212 as above. I reckon this route is a bit longer than the one through Calicut.
binand is online now   (1) Thanks Reply With Quote
Old 4th March 2016, 19:33   #9344
Rajeevraj's Avatar
Thanked: 8,712 Times
Guys,
Agree with Binand, no need to take the Shornur route ( unless you specifically have a need to).
Apart from the route Binand mentioned, the NH 17 via n paravoor- kodungaloor- chavakkad- ponnani- chamravattom - kuttippuram ( via the new road) and then the standard valanchery - calicut route is also an option since it is an early start. No major advantage I suppose, just a different route.
Rajeevraj is offline   (1) Thanks Reply With Quote
Old 5th March 2016, 14:25   #9345
Thanked: 592 Times
I think the second suggestion (NH17 all the way) would be the better one with an early morning start. The only issue with this route is the Edappally to Kodungallur sector where the roads are narrow which doesn't allow you to average more than 25-35 kmph when driving during the day. But since traffic would be much lower early in the morning, it should be much easier to traverse at speeds of at least 50-60 kmph. On the other hand I've seen traffic bottlenecks even at 5AM on the NH47 section at places where metro construction is in progress.
The only correction to the route as described by @Rajeevraj is that you shouldn't go via Chamravattom when going from Ponnani to Kuttippuram. Take the Ponnani bypass and at the 5 way junction at the end of the bypass you need to continue on the road that goes straight ahead to go towards Kuttippuram. The road to Chamravattom is also almost in the same direction, but it is a narrower road at an angle of about 10 degrees to the left. (The acute left turn at that junction takes you to Ponnani town, and the right turn takes you to Edappal). Not sure about how good are direction markings at this junction.
Also just in case you're not familiar with how to the bypass Calicut city, make sure you take the road that goes straight ahead at Ramanattukara. (Left goes to Feroke/Calicut city, and right goes to Calicut airport/Malappuram). Continue on the bypass till Malapparambu where you need to take a right turn onto Wayanad road (NH212).
kala is offline   (2) Thanks Reply With Quote
Trivandrum - Kasargode - Mangalore - Kollur :: Kerala Roads - An update convivial Travelogues 26 6th September 2016 15:46
Kerala: Speed limit on highways and 4-lane roads revised darklord Road Safety 39 11th February 2016 08:31
Horrible private bus drivers in Kerala roads Traxter Street Experiences 33 9th December 2014 16:43
Idukki-Kerala's best driving roads? rippergeo Travelogues 103 7th June 2012 06:29
Kerala Roads - Unimaginably Pitiable condition emkay456 Street Experiences 30 1st February 2008 20:12
