Old 8th June 2010, 19:37   #1336
Surprise's Avatar
Thanked: 142 Times
Originally Posted by hvkumar View Post
Athirapalli-Vazhachal 5 kms-Peringalkuth Dam/Checkpost 5-Sholayar Dam 25-Malakkiparai (KL/TN Border)/Check Post 24-Valparai 22-Rottikadai/Iyerpadi 5-Aliyar Dam 36-Pollachi 24
Beautiful route. Roads are reasonably good & this has to be done during Dec-Jan season as mist would add beauty to those ALL GREEN roads
Surprise is offline   Reply With Quote
Old 8th June 2010, 21:10   #1337
ampere's Avatar
Thanked: 8,826 Times
AArgee,
Nelliyampathy is close to Nemmara (Clocse to Palakkad).
Recall Laluk's TL.
Old 8th June 2010, 21:35   #1338
Intoxicator's Avatar
No problem with landslides anywhere, unless there are some very heavy rains - even then, there will not be much dislocation.
For Wayanad, the classic Mysore route is OK. Make sure you cross Bandipur area before the night closure timings.
From Wayanadu, the route choices to Alapuzha are:
Route 1: Wayanad-Kozhikode/Calicut-Kuttipuram-Kunnamkulam-Ernakulam/Koci-Alapuzha
Route 2: Wayanad-Nilambur-Shoranur-Trissur-Ernakulam-Alapuzha
The route via Calicut is straightforward, but you will encounter high traffic by day. But that would be preferred.
Thanks a lot. Will take the safer Calicut route then. Should i take the same route back from Kochi to reach Bangalore?
Originally Posted by trrk View Post
And right upto Ernakulam / Cochin, it is without bad patches. The Aroor - Cherthala 4 laned portion has some bad patches and sticking to the right lane is better as far as possible.
On 03/06/2010, I reached Calicut byepass beginning (243km) at 1022hrs from Alleppey, journey started at 0508hrs. The break was between 0902 and 0930hrs for breakfast.
I did not go into Calicut as I was on my way to Kannur (Parassinikadavu Temple).
If you see any private bus approaching you from front or back, please keep as much distance as possible from it.
Thanks for the word of caution. I remember travelling by a private bus from Ernakulam to some other place (cant remember the name). I hope i dont encounter any races when on the road.
Intoxicator is offline   Reply With Quote
Old 8th June 2010, 22:05   #1339
I'm planning to drive to Munnar from Coimbatore during this weekend.
Though i have driven hills, this is my first trip to Munnar.
Would like to know,
1. The current road conditions between Udumalaipettai and Munnar
2. How would you rate the difficulty of the hill road to Munnar, compared to CBE-OOTY, CBE-MYSORE(via DHIMBAM), CBE-VALPARAI?
3. Estimated travel time between Udumalai and Munnar
4. One of the days during the trip, considering driving to Thekady from Munnar. Are the roads good in that stretch? Is it a trip that i can make and get back to Munnar? Or is there a better route to return to Coimbatore from Thekkadi?
I might get to take a Scorpio for the trip, but if does not work out, will settle for my own Santro. Should Santro be good enough for this trip?
Please help with anything else i need to be aware of during this trip.
Regs
Harris
harrysan is offline   Reply With Quote
Old 8th June 2010, 23:15   #1340
hvkumar's Avatar
Thanked: 3,357 Times
If you want a different route, come back on NH47-NH7 via TRissur, Palakkad, Coimbatore, Salem & Krishnagiri.
hvkumar is offline   Reply With Quote
Old 8th June 2010, 23:23   #1341
hvkumar's Avatar
Originally Posted by harrysan View Post
Would like to know,
Good road, through forests, expect wildlife, check post time restrictions at night may be there.
Ooty road is very gradual climb, smooth and has parapet walls throughout.
Dhimbam road is also very smooth and not very steep
Valparai has lots of sharp curves.
Climb to Munnar is not steep, but roads are narrower than all others, no steep valleys, not difficult for even a not-so-experienced driver.
90 kms, 3 hours max
Good road, no steep sections, expect fog at Lockhart Gap within 10 kms of leaving Munnar.
110 kms can be covered in 3 hours.
You can go and return the same day.
Except that boat timings may be unsuitable since best wildlife sightings are possible only during early morning and evening
You can return to Coimbatore faster from Thekkady via Kumbam, Theni, Periakulam, SEmbatti, Ottanchatram, Palani, Udumalaipet & Pollachi. You should take 5-6 hours to cover the 280 kms.
Old 9th June 2010, 03:54   #1342
Thanked: 592 Times
Unless you have a specific reason for going via Calicut / Wayanad, the route suggested by HVK would be the best one to take - If you leave early from Cochin and get past Coimbatore byepass (and preferably Avinashi) before heavy traffic begins, you should be able to do the trip in about 8 or max 9 hours. Via Calicut it'll take you at least 2-3 hours more.
kala is offline   Reply With Quote
Old 9th June 2010, 05:22   #1343
aargee's Avatar
Thanked: 2,126 Times
No, No, No. You are again relying on these inaccurate Google Maps.
Yes, my bad, I should've googled on TBHP rather than google maps.
Thanks so much
Recall Laluk's TL.
Yes, you're right (Swifted Nelliyampathy via Valparai), I should've searched in it. But that was not my priority. Thanks Ampere.
aargee is online now   Reply With Quote
Old 9th June 2010, 10:29   #1344
NH47-NH7 is better i guess. Aren't Athirampally and Vazhachal near Trissur? If so, I could detour to visit them i guess. (If time permits)
This would be my first roadtrip after joining T-Bhp, will post a nice Travelogue with loads of pictures.
Any tips on what all to take note of while on the trip so that I dont miss out on posting anything that might help fellow newbie T-Bhpians on their next trip?
Old 9th June 2010, 10:52   #1345
hvkumar's Avatar
Turn off NH47 at Chalakudy (40 kms from Kochi/Ernakulam), and go 35 kms to Atirapalli (and 5 more for Vazhachal), and return the same way to Chalakudy and resume your journey on NH47.
Old 9th June 2010, 12:11   #1346
Thanked: 592 Times
When coming from Kochi, Isn't there a shorter way that deviates from NH47 somewhere around Angamaly ? If that road condition is good, that would probably save some time (And the NH47 isn't that great anyway between Angamaly and Chalakudy - plenty of traffic and 4 laning work).
On the way back he could take the Chalakudy road and join back NH47 there.
Old 9th June 2010, 12:15   #1347
hvkumar's Avatar
You can also turn off NH47 1 km after Angamali town, but remember that you have to turn left to cross the River Chalakudy at Mokkanur which is 28 kms from Angamali town.
Old 9th June 2010, 12:47   #1348
trrk's Avatar
Thanked: 13 Times
You will! But give way, if they are coming towards you or behind you. The sooner, the better! That's all. The drive is very scenic.
Your Santro should be fine.
trrk is offline   Reply With Quote
Old 9th June 2010, 13:49   #1349
trrk's Avatar
Thanked: 13 Times
South of Alleppey, from about 15kms, there is a bad stretch of almost 6 to 7 kms which has nice huge potholes. Most of them are in the centre of the road, right now.
Another stretch to be careful is the 2 or 3 kms south of Thottappally spillway bridge.
Old 9th June 2010, 18:24   #1350
Thanks a million hvk and kala!! So, getting off NH47 at Angamali and then cross over at Mokkanur and rejoining NH47 at Chalakudy - going into my trip book. Thanks a lot guys.
Thanks a lot for the heads up mate. Two more caution points into my book. Noticed that you are from Alleppey. Any suggestions on which(type?) House Boat to book?
Trivandrum - Kasargode - Mangalore - Kollur :: Kerala Roads - An update convivial Travelogues 26 6th September 2016 15:46
Kerala: Speed limit on highways and 4-lane roads revised darklord Street Experiences 39 11th February 2016 08:31
Horrible private bus drivers in Kerala roads Traxter Street Experiences 33 9th December 2014 16:43
Idukki-Kerala's best driving roads? rippergeo Travelogues 103 7th June 2012 06:29
Kerala Roads - Unimaginably Pitiable condition emkay456 Street Experiences 30 1st February 2008 20:12
