Old 21st July 2010, 11:13   #1396
jeevmenon's Avatar
Kozhikode does not share its boundaries with any state. Its only via Wynad which is covered.
jeevmenon is offline   Reply With Quote
Old 21st July 2010, 11:20   #1397
Thanked: 140 Times
While in the case of the other roads you can move to other parts of Kerala, in the case of Top Slip - Parambikulam you cannot do so, effectively it ends there.
pypkmsrikanth is offline   Reply With Quote
Old 21st July 2010, 14:03   #1398
Bigzero's Avatar
Thanked: 161 Times
Yeah you are right - my bad! I guess I got a bit carried away there..
Bigzero is offline   Reply With Quote
Old 22nd July 2010, 01:21   #1399
Default Options for avoiding Walayar (to and from Kerala)?
Hi
I go to Kerala quite often from Bangalore. The Walayar check post is a nightmare (I was stuck at a standstill for almost 2 hours this morning from 5:30 to 7:30 going from Palakkad towards CBE).
Is there an alternate route that is not too time consuming? How about SH26 - CBE-PKD through Velamthavalam? How much more time is it compared to taking NH47 assuming there was no blockage at Walayar? The maps shows it is only 6 km more but how are the roads?
Thanks...
uy663z is offline   Reply With Quote
Old 22nd July 2010, 10:09   #1400
jacs's Avatar
Thanked: 715 Times
Originally Posted by uy663z View Post
Hi
Thanks...
Velamthavalam route is very narrow, if you are stuck it will be even worst nightmare. Lot of trucks take this way, have tried it once but would not recommend it especially at night.
jacs is offline   Reply With Quote
Old 22nd July 2010, 10:45   #1401
Thanked: 238 Times
In the Bangalore - Mangalore route, after Uppinangadi, take laft to Puthoor - Vittala - Perla - Charkala - Kasargod.
For the route details and conditions, you can refer the earlier threads
Kasargod
Adhur - Jalsoor
Mularia - Jalsoor
Panathoor-Talakaveri
Badiyadka - Perdala
Uppala - Manjeshwar
You can refer these threads-> http://www.team-bhp.com/forum/route-...-kasargod.html
-> http://www.team-bhp.com/forum/travel...ekal-trip.html (Bangalore - Kasargod (Nileswaram, Bekal) Trip)
Kannur
Virajpet - Iritty
Wayanad
Pandalur - Meppadi
Pandalur - Batheri
Gundlupet - Batheri
Thrishilery - Kakanakote
Thrishilery - Kutta
Refer the thread -> http://www.team-bhp.com/forum/route-...fo-needed.html
Please note that Virajpet - Irrity road is recently opened after 18months of closure. Still there are some work pending, but it is easily driveable
Rajesh
RajeshK is offline   Reply With Quote
Old 22nd July 2010, 10:58   #1402
coolclouds's Avatar
Thanked: 513 Times
Two months back, I traveled in a "Special bus" from Cochin to Bangalore. They took a right just before Walayar and joined back NH47 after L&T highway (?to avoid check posts)
The route was narrow but absolutely no traffic at about 12 in the midnight other than two-three Kerala bound private travels buses in opposite direction.
Similarly, this bus again skipped Hosur check post to reach Bangalore
coolclouds is offline   Reply With Quote
Old 22nd July 2010, 11:29   #1403
clevermax's Avatar
Thanked: 403 Times
Marked all the roads seen in the map which lead to Kerala.
clevermax is offline   Reply With Quote
Old 22nd July 2010, 12:06   #1404
jeevmenon's Avatar
RajeshK: Yes, indeed helps for current road conditions and thanks for the info on the Kannur route, but also to know if people have taken such routes before. Are there restrictions/timings/check-posts/terrains/petrol stations/eating/rest-places/view-points/time-compared-to-traditional route/etc. Something more.
Clevermax: Thanks. However the markings on the map are not exhaustive e.g the Mannarkad-Anakkati route is not mentioned.
Lets leave all the NH normal routes. They are heavily used by people and its usually unaffected. e.g Has anyone used SH45 via Chittar Dam 1/2? Has anyone taken the Sulya road in Kasargod? What are the specialities of these routes?
Old 22nd July 2010, 12:57   #1405
hvkumar's Avatar
Thanked: 3,354 Times
Great thread. Reminds me of my mobiking days when I decided to drive up and down every single ghat down to the coast in the Western Ghats between KL and GJ.
Yes, Munnar-Kodai is indeed closed, but there is one more OTR road which can be driven the OTR way parallel o the old road.
hvkumar is offline   Reply With Quote
Old 22nd July 2010, 14:20   #1406
sbraj's Avatar
From TVM, one can reach Tamilnadu via Kattakkada, Kulaseskharam to Aralvaimozhi on NH7. Is that SH45?
sbraj is offline   Reply With Quote
Old 22nd July 2010, 14:23   #1407
jeevmenon's Avatar
RajeshK: I re-read the two links. Quite some info on the Sulya route and you mentioned separately about the Perdala route. So is there a link on Google maps missing about the Vittala-Perdala road? Is it via Ukkuda? I can see some minor roads there. How is the road condition?
All: What I could do is: at the top of this thread, each route that's listed will be hyper-linked to the corresponding thread. e.g - Sulya links, Perdala links as mentioned by RajeshK (Kasargod expert), Parambikulam links as pointed by pypkmsrikanth (Parambi/Valparai expert,), Nilambur/Calicut (say Bigzero/Ampere.) Kind of indexing for quick de-referencing.
Old 22nd July 2010, 14:29   #1408
jeevmenon's Avatar
sbraj: Just checked google maps. Its the SH45 and the SH45 splits into two around the two Chitra Dams. It appears great. So maybe a first hand report on the same would help.
Old 22nd July 2010, 14:29   #1409
jeevmenon's Avatar
Oh! And yes we did get the Trivandrum expert!
Old 22nd July 2010, 14:33   #1410
sbraj's Avatar
I have been through this route in June. I wanted to get an alternate route to bypass Nagercoil.
Road condition was not great, under repair. Sedans/hatches would find it difficult whereas it should be fine for SUVs. Scenic road with lots of vegetation around.
On the way one finds the Pechiparai waterfalls, dam as well.
Trivandrum - Kasargode - Mangalore - Kollur :: Kerala Roads - An update convivial Travelogues 26 6th September 2016 15:46
Kerala: Speed limit on highways and 4-lane roads revised darklord Street Experiences 39 11th February 2016 08:31
Horrible private bus drivers in Kerala roads Traxter Street Experiences 33 9th December 2014 16:43
Idukki-Kerala's best driving roads? rippergeo Travelogues 103 7th June 2012 06:29
Kerala Roads - Unimaginably Pitiable condition emkay456 Street Experiences 30 1st February 2008 20:12
