Old 30th September 2013, 14:16   #451
Thanked: 17 Times
Default re: Hyderabad - Chennai : Route Queries
Am planning to drive down to Chennai this Friday / Saturday. Would appreciate feedback on the road conditions / anti-telengana agitations in Coastal Andhra. Should I take the Hyd -Nalgonda - Ongole - Nellore route? Or should I take a different route?
crisscross is offline   Reply With Quote
Old 30th September 2013, 16:20   #452
rnidumolu's Avatar
Thanked: 88 Times
There are 2-3 routes by which you can reachout to Ongole from Hyderabad. But from there it is GQ only and it passes through Ongole, Nellore, Gudur, Tada etc. Now coming to your question, I would suggest you to do a night drive if possible to avoid issues like road blocks, agitations etc. I did not travel recently so could not talk about the road condition.
rnidumolu is offline   Reply With Quote
Old 30th September 2013, 16:41   #453
Thanked: 17 Times
Thanks Ravi.
My dad is suggesting I take the Kurnool - Cuddapah - Chennai route. Any inputs on the road conditions?
Old 30th September 2013, 17:39   #454
ranjitp1's Avatar
Thanked: 1,794 Times
Thanks Ravi.
Kadapa route,you are highly likely to get into a rasta roko at Chittoor.Stick to the Vijayawada route imo.fast and good conditions as well.
ranjitp1 is offline   (1) Thanks Reply With Quote
Old 30th September 2013, 18:10   #455
rnidumolu's Avatar
Thanked: 88 Times
Thanks Ravi.
I would suggest to avoid this as suggested by Ranjit. My dad had faced issue two weeks back while travelling in this route
Ideally you should look for a route where you travel more in the Telengana region and less in the Andhra region.
If you start in the evening/night and choose the Nalgonda -> Miryalaguda route, by mid night you will be able to cross the problamatic regions (read as boarder villages) where you may held up. This route is under construction but doable in the nights. The only challenge you will face is the diversions. Last time (read almost one year back) when I travelled in this route the diversions were not glaring and I had a challenge with them.
Coming to Hyd -> Vij -> Guntur -> Ongole -> Nellore -> Tada, this road condition is good, but the issue is people may stop the traffic at some places. But you can take a chance.
rnidumolu is offline   (1) Thanks Reply With Quote
Old 30th September 2013, 19:50   #456
virgovencat's Avatar
Thanked: 70 Times
If you do not have problem with night Driving, then best is to stick to HYD-VJA-CHN highway and start around 3pm.
Or esle start early morning - 4am - Take Nalgonda route, you will hit VJY-CHN highway near addanki - this route is also being made into 4 way. 40% is done.
What I have heard is that, they are not stopping Cars & Bikes on highway..only buses and trucks. Not sure.
Best ROUTE is HYD-NALGONDA-ADDANKI- ONGOLE-CHN - to escape disturbances.
But agian..it's all LUCK my dear friend !!
All the best !!
virgovencat is offline   (1) Thanks Reply With Quote
Old 3rd October 2013, 10:29   #457
Thanked: 17 Times
Any recommendations for decent vegetarian food on this route? I will most likely take the Hyd-Nalgonda-Addanki-Ongole-Chennai route.
Old 3rd October 2013, 11:22   #458
Thanked: 302 Times
Nalgonda and Miryalguda have bypass. So you can bypass both the towns. Decent eating places only in Piduguralla town which does not have a bypass.No specific restaurants that I can suggest. After Piduguralla the next option is only Ongole. Once you cross Addanki and reach Medarmetla you have a lot of dhabas on the highways which can be tried
gajadonga is offline   Reply With Quote
Old 6th October 2013, 11:26   #459
Thanked: 70 Times
Rightly said..decent places to eat are only after you hit Ongole, none before that. you will pass all small villages and towns. Better to pack food.
On Ongole bypass, once you come down the flyover, on left ( while going to chennai), you will see a good tiffen center ( at cross roads)..or else Murali Krishna hotel in Nellore town ( you have to enter town for that)
Last edited by moralfibre : 20th October 2013 at 21:49. Reason: Back to back posts.
virgovencat is offline   Reply With Quote
Old 20th October 2013, 10:36   #460
praveengupta's Avatar
Thanked: 11 Times
Default Hyderabad-Chennai route alternatives
Thanks tbhpians, with the info on this thread i just concluded a hyd-chennai round trip:
Route:
http://goo.gl/maps/YrZSz
1. Hyd-Chennai via NH7 Anantapur, Madanapalle, Chittoor bypass
2. Chennai-Hyd via NH5 Vijayawada Prakasham Barrage, ORR
Time:
I traveled from west Hyd to south chennai so both routes were similar in distance (~800km) and took around 15 hours each at steady speeds of 80-100kmph, including rest breaks, toll booths and unintended deviations costing around 2 hours on each leg. If you are traveling from east Hyd you would get a saving of 50km on ORR if you take route 2.
Money:
Spent 19l of fuel until the first refuel point at 320km (17kmpl), and 50l on the return journey from Chennai to Hyd (16kmpl). Didn't get a chance to measure the other legs.
Made an overnight stopover at a serene place called Horsley hills.
Got good food enroute. Restaurants marked on the map are simple veg food joints, so may not appeal to non-vegetarians.
Road from Hyd to Blr is the best I have come across yet.
Roads are well marked with milestones across all of TN.
Highway from Walajah to Chennai is no longer the expressway it used to be as it shows aging signs, undulations and cattle.
Vijayawada-Hyd road at 4 lanes is too narrow for its traffic.
The road from Guntur to Vijayawada is completely under construction with tens of deviations and hundreds of cows even though the toll booths are fully constructed and dipping into your pockets as well as precious time.
Car: Fiat Petra 1.6 2004
Preparations:
Wheel alignment, oil change and throttle-body cleaning was done some 3000km ago so didn't get it redone. Got the following done right before the trip:
AC recharged
Air filter cleaned
Tires at 28psi
Topped up from Shell both in Hyd and in Chennai.
praveengupta is offline   Reply With Quote
Old 20th October 2013, 16:22   #461
Thanked: 378 Times
Default Re: Hyderabad-Chennai route alternatives
Route:
Time:
Can you compare and give an update on the condition of the roads on both the routes?
hyd_traveller is offline   (1) Thanks Reply With Quote
Old 20th October 2013, 20:31   #462
Thanked: 11 Times
1. via Anantapur
60% expressways - NH7
30% undivided but good scenic roads - Anantapur-Madanapalle, Palamaner-Walajah
10% roads with some potholes, speedbreakers and city traffic - Madanapalle-Palamaner
2. via Vijayawada
60% expressways
30% expressways but runs city traffic with cattle, wrong side truck traffic.
10% called expressways but mainly running on service roads with speed-breakers, cattle, everything else (Guntur +- 50km)
Old 20th October 2013, 20:38   #463
vnabhi's Avatar
Thanked: 1,310 Times
Yes, we need this information, especially the 2-hour unintended diversions please.
Old 22nd October 2013, 11:01   #464
Thanked: 11 Times
The 2 hour is for all the non-travel times, lunch, snack etc. Unintended diversions were probably less than 30m of wastage mainly when I missed the direction signs and ended up entering some towns instead of taking the highway bypass. I don't remember which towns they were, but they weren't too crowded.
praveengupta is offline   (1) Thanks Reply With Quote
Old 4th November 2013, 02:33   #465
ecosport rules's Avatar
Thanked: 1,351 Times
Hey guys,
A quick question.
On the 5th or 6th I will be travelling from nellore to hyd
Can you please update me about the road condition, expressways, percentage of divided or undivided roads if I travel via nellore-ongole-addanki-nagarjuna sagar hyderabad.
Is this road better or the nellore-ongole-vijayawada-hyderabad better.
Thank you
ecosport rules is offline   Reply With Quote
Pune to Hyderabad : Route Queries shoky Route / Travel Queries 665 29th May 2018 02:19
Chennai-Mumbai-Chennai route queries jeevmenon Route / Travel Queries 89 7th November 2017 14:40
Bílore-Hyderabad-Nagpur-Jabalpur-Maihar Route/Hotel/Food Queries. Su-47 Route / Travel Queries 14 19th April 2017 16:42
Hyderabad to Nasik : Route Queries lejhoom Route / Travel Queries 24 18th January 2016 14:06
Hyderabad - Coonoor - Ashtamudi: Route & Accommodation Queries MileCruncher Route / Travel Queries 2 5th January 2011 23:01
