Old 18th August 2014, 14:29   #556
ampere's Avatar
Thanked: 9,122 Times
Default re: Bangalore to Trichy : Route Queries
Originally Posted by Waxeloquent View Post
National High Way is just 2 lane, filled with only sand trucks. The 3 1/2 hour drive was not enjoyable. If there is an option to move to Salem Coimbatore highway somewhere after Karur, even if it adds say 20, 30 kms, it would be highly preferred.
For an additional 40km you can try :
Tanjore-Trichy bypass - Dindigul - Dharapuram - Palladam - CBE
But you endure the last section. Else its brilliant. 4-lane till Dindigul. Good roads to Dharampuram and Palladam. This once you end on GST from NH67 from Tanjore, you just latch on to GST and you dont need to get into Trichy again!
Old 18th August 2014, 17:05   #557
Thanked: 120 Times
Ampere thanks! What about Karur-Kodumudi-Erode-Cbe? I find that's 34km more than
Karur-Vellaikoil-Kangayam-Palladam-Cbe. But then one endures the 2 lane torture
only for 62km between Karur and Erode and enjoy the 4 lanes from Erode to Cbe
That seems a reasonable trade-off, no?
On a different topic, the merciless sand mining from Cauvery river bed is really
a matter of concern. Had seen similar thing on Chennai-Villupuram route in Tamilnadu.
Waxeloquent is offline   Reply With Quote
Old 18th August 2014, 17:22   #558
ampere's Avatar
Looks good to me. But I thought you said even Trichy Karur has lots of trucks. Hence I suggested the Dindigul option.
This is very true. Esp beyond Trichy towards Grand Anicut/Thiruvaiyaru its even works.
Old 18th August 2014, 17:54   #559
Thanked: 899 Times
You could either do that or Trichy-Nochiyam-Thuraiyur-Namakkal-Tiruchengode-Erode-Coimbatore (or) Trichy-Nochiyam-Thuraiyur-Namakkal-Salem-Coimbatore.
narayans80 is online now   Reply With Quote
Old 18th August 2014, 18:13   #560
Thanked: 120 Times
Oh no! Had terrible experience on Thuraiyur-Namakkal-tiruchengode-Erode; traffic is chaotic
and the road was not good for half the way. Well that was 2 years back. Things could have improved, have they?
Old 18th August 2014, 20:02   #561
ampere's Avatar
Just realised, that may not help much. Thats because both these towns have no bypasses. So what you save from trucks, you give it to these towns!
Old 19th August 2014, 05:18   #562
suresh_gs's Avatar
Thanked: 1,249 Times
It is NH 67 all the way from Karur to CBE via kangeyam,palladam and sulur. Very good extended 2 lane roads. But you can expect traffic at Sulur
suresh_gs is offline   Reply With Quote
Old 16th October 2014, 14:52   #563
Thanked: 13 Times
Folks,
Will be driving down to Trichy this Sunday (6am start). Any recommendations on the best route, based on current situation?
a) via Namakkal, Thuraiyur
b) via Thottiayam, Musiri
c) or Namakkal, Karur bye pass
nssrini is offline   Reply With Quote
Old 16th October 2014, 14:56   #564
suresh_gs's Avatar
Originally Posted by nssrini View Post
Folks,
Choose option c. Even though it is 30 odd kms more compared to Thuraiyur route, karur by pass is a very good extended 2 lane road.
suresh_gs is offline   (1) Thanks Reply With Quote
Old 16th October 2014, 15:06   #565
ampere's Avatar
Take the Karur road as Suresh mentioned. The road via Thuraiyur is quite convoluted. Its easy to get lost. And also Thuraiyur option works well if you have to go past Trichy towards Tannjore. Thats because this route directly lands you at Toll Gate and there on you can easily come down to the GST and take the NH67 exit.
But other wise the Karur road is the best. Clean bypass for Karur as well. You drive past Karur on the Nh7 bypass and then take the Trichy exit.
ampere is offline   (2) Thanks Reply With Quote
Old 16th October 2014, 16:04   #566
Thanked: 13 Times
Thanks, have to reach K.K.Nagar in Trichy & hence the other route had easy access therein, whereas the Karur route will lead into Thillainagar & inside the town. But I guess, it should not be a big deal, when the main highways are already covered.
Thanks.
Old 16th October 2014, 16:54   #567
ampere's Avatar
Thanks.
Just checked in Google maps that KK Nagar south of the city; off the Madurai road. In that case actually Thuraiyur option helps.
But the amount of trucks you may have bear when crossing or bypassing Namakkal is just too much. For that I think wading Trichy might be less of a pain.
Old 16th October 2014, 17:38   #568
Thanked: 899 Times
Better to stick to Thuraiyur route. That way you can catch the bypass at Number 1 Tollgate. Karur route will land you near Chathiram Bus Stand.
Unless you know your way well in Trichy it might not be so easy. Signages are poor inside and you could be going in circles. The location looks accessible from the bypass, stick to it.
Had a personal experience of getting lost in Trichy for almost 2 hrs and pretty much went around the same place almost 2-3 times
Old 16th October 2014, 17:46   #569
ampere's Avatar
Wow! Did not realise it was that bad. I found it to be OK.
But otherwise I do agree that the Thuraiyur option is much cleaner. But wading past Namakkal is big pain. To avoid that many have suggested the option via Budhan Santhai - Senthamangalam - Vadugapatty - Alanganatham. This option works like a charm. (Even I have used it). But one has to deal with lots of truck traffic till one reaches the Namakkal-Kannanur SH. After that its smooth sailing till Trichy.
Old 16th October 2014, 21:27   #570
Thanked: 13 Times
Unless you know your way well in Trichy it might not be so easy:
From Karur Road, there is a right turn that will take you to Thillainagar, bye passing Chatram area. From there one can reach central bus stand and further - there'll be traffic, but not too bad compared to Chatram area...
nssrini is offline   (1) Thanks Reply With Quote
Trichy - Rameshwaram - Kanyakumari - Trichy saugdas Route / Travel Queries 30 22nd May 2017 16:52
Chennai - Trichy : Route Queries sathya_j2084 Route / Travel Queries 122 17th March 2016 23:54
Did this last weekend - Chennai-Trichy-Dindigul-Kodaikanal-Madurai-Trichy-Chennai srikanthpotluri Route / Travel Queries 2 2nd November 2011 02:20
Bangalore Kanyakumari Rameshwaram Trichy Bangalore - One Hella Trip !!!!! lancersfx Travelogues 21 5th July 2010 14:01
