Go Back   Team-BHP > Buckle Up > Street and Travel Experiences > Route / Travel Queries
Route / Travel Queries About the best routes or other travel related questions.
Thread Tools
Old 15th October 2007, 17:59   #1 (permalink)
Default Chennai to Baroda
Hello there,
On 16th of November, I am planning to travel to Baroda with my Maruti 800 along with 2 additional passengers.
Route as; Chennai, Bangalore, Belgaum, Kolhapur, Satara, Pune, Nashik, Dhule, Surat, Bharuch & Vadodara.
I presume that the route falls in Golden Quadrilateral and hope the route should be fine.
Planning to halt in Bangalore, Pune and straight to baroda.
All I know is the distance from Maps of India is 1723 Kms and I have 2.5 days available to reach this distance.
Would appreciate team suggestions and comments about route, alternate route and rad conditions, pit stops and driving assistance,...
Mod's Note: Please take your time to familiarize yourself with the sections and the subsections on this board. Do take care to post in the correct section. Thread migrated.
Dhanasekaran is offline   Reply With Quote
Old 15th October 2007, 20:14   #2 (permalink)
hvkumar's Avatar
Alternative route would be to go from Pune to Bombay and Surat on NH8 - this is the true GQ route. My rough calculation is that this route is shorter than the Pune-Nasik-Dhulia-Surat route and faster. Except for a small stretch between Ghodbunder and Manor which has rutted roads, the rest of the route till Surat is very good although Surat-Baroda is in a bad shape (road widening, flyover construction, etc).
Bombay can be bypassed without too much of fuss from New Bombay to Thane and Ghodbunder.
Unless you have any specific reason to halt in Bangalore, you could stretch Day 1 to Hubli/Belgaum, assuming you start early enough from Madras. Day 2 will be tight, but you could reach Baroda by the day-end.
BRoadly, the distances are: Madras-Bangalore 350, Bangalore-Bombay 1050 and Bombay-Baroda 400, or 1800 kms.
The route via Nasik/Dhulia goes through ghats in 3 sections and is much slower because it is on conventional 2 lane highway. You intercept NH6 at Dhulia to reach Surat.
__________________
Kumar
2005 Mahindra Scorpio 2.6
1999 Daewoo Matiz SE
1994 Mahindra Commander
1986 TVS Suzuki AX100
hvkumar is offline   Reply With Quote
Old 15th October 2007, 20:42   #3 (permalink)
akbaree's Avatar
Originally Posted by Dhanasekaran View Post
Hello there,
AFAIK Pune - Nashik - Dhule - Surat doesn't fall on Golden Quadrilateral. Moreover the road is bad in patches. I had travelled on this route some 6 months back while I was coming to Bangalore from Ahmedabad. I will suggest that you don't take this route. From Pune you can take express way to Mumbai and then NH8 to Surat. Pune - Mumbai - Valsad - Navsari - Surat. This is the GQ route. Roads are pretty good (all along 4 lane) and shorter as well. You may get a lot of traffic on NH8 but it should be fine unless you are entering this stretch at peak hours say early morning or late evening.
akbaree is offline   Reply With Quote
Old 15th October 2007, 20:57   #4 (permalink)
nitrous's Avatar
Instead of Bangalore, halt at Belgaum.
Its more appropriate.
__________________
hindu.com/mp/2008/08/25/stories/2008082522220200.htm
Old 15th October 2007, 21:05   #5 (permalink)
Thanks for the response. I am planning to leave Chennai around 1:30 PM in the afternoon on 16th November. Could anybody suggest the stretch I can make on that day and a possible halt in the night with moderate comfort.
Old 15th October 2007, 21:40   #6 (permalink)
hvkumar's Avatar
You should reach Bangalore by 630 pm, but wading through the ring road/Nelamangala road is quite an ordeal. If you can do a very fast and a late drive, you could even do Chitradurga by 11 pm. There are several hotels on teh bypass itself. Otherwise, stop by at Tumkur which you should reach latest by 9 pm. There are 2-3 hotels near the bus stand (can't remember the name) - go into town instead of taking the bypass, wasy to locate once you get to the bus stand.
This means, assuming you stop at Tumkur, Day 2 should take you to Bombay - maybe you should stay at the New Bombay hotels (on NH4), or at Hotel Fountain at Ghodbunder on the NH8. If you do very well that taht day, you could even go all the way to Vapi where there are some good hotels like Woodlands.
__________________
Kumar
Old 16th October 2007, 09:58   #7 (permalink)
Thanks for the response again.
Please give me feedback about the following routes;
1. Chittoor to Bangalore
2. Nelamangala to Chitrdurga
Road condition, pit stops and any other suggestions.
Other question I have is the number of tolls I must pass through from Chennai till Baroda.
Can you tell me the tolls and likely amount tobe spent for singleway.
Old 17th October 2007, 11:20   #8 (permalink)
Hello Mr.Kumar,
I am eagerly waiting for your advice.
Old 17th October 2007, 12:53   #9 (permalink)
akroy's Avatar
1) Chittoor bangalore is an excellent 2 laned stretch...Food stop here is A1 Plaza-10km before Palamner (also there is a Mayura near Palamner as well)
Woodys - immediately before taking Kolar BP (if coming from Chennai, to your left)
Kamat Upachar - 15km after Kolar towards Bangalore side on your right
If you are starting in the afternoon better to take the chittor route because entering from Hosur can become taxing and you will loose time...take the ring road which starts immediately after the Cable stayed bridge (it is marked), next main stop is Hebbal flyover, keep going straight you will reach Tumkur road...it will be quick...
2) Neelamangala - Chitradurga is an excellent and fast stretch...except of Tumkur BP, entire Part of the GQ is done...so u can easily do it quite fast, Chitradurga A1 Plaza to Home (in bangalore), i did in less than 3 hours in my Alto while returning from Goa...Neelamangala to Chitradurga should be easily doable in 3 hours or less...
At the start of Chitradurga BP, there is a A1 Plaza in the right (it is open till 11:30PM)
Before Tumkur, there is a A1 Plaza and a Kamat Upachar, both are good but you have to take a U turn because it is on the other side of the 4 laned highway....
For hotels near chitradurga, Davangere, Ranibennur pls contact Kumar....
Abhi
__________________
2003 Bajaj Caliber115 | 2006 Alto LXi
akroy is offline   Reply With Quote
Old 17th October 2007, 19:15   #10 (permalink)
Thanks for your response.
Any idea of tolls between Chennai-Blr-Belgaum-Pune-Baroda One way.
While returning I need to attend customer in hyderabad.
Advise me on the route to Pune-Hyderabad-Chennai as well and likey tolls in this route.
Old 17th October 2007, 20:20   #11 (permalink)
hvkumar's Avatar
As Abhi mentioned, road conditions between Chitradurga and Hubli are not in the best shape but OK. Speeds slow down a bit and night driving is to be avoided. On the Chitradurga bypass, there are about 4 hotels offering rooms at different budgets - try them.
Tolls - lots of them. Since you asked, let me list them down!
Bangalore-Bombay:
Nelamangala, Rs 21, 25 kms from Zero Point Bangalore/Yeshwantpur
Hubli-Dharwad ByPass, Rs 23, 418 kms
Kognoli, Rs 25, 590 kms
Kini, Rs 41, 647 kms
Tasawade, Rs 41, 709 kms
Anewadi, Rs 25, 765 kms
Khambatki Ghat Tunnel, Rs 13, 796 kms
Shivapur, Rs 45, 846 kms
Pune-Bombay Expresway, Rs 118, 892 kms
Bombay Airoli, Rs 25, 1007 kms
Bombay Mulund, Rs 25, 1012 kms
Rs 402, total
Bombay-Baroda:
Bombay Mulund, Zero Point
Ghodbunder, Rs 15, 25 kms
Vasai, Rs 30, 56 kms
Charoti, Rs 25, 108 kms
Bagwada, Rs 30, 175 kms
Boriach, Rs 25, 237 kms
Bharuch, Rs 13, 348 kms
Total Rs 139
which means Bangalore-Baroda toll will be Rs 541.
I have no idea about Madras-Bangalore, not having driven through GQ after toll roads were completed.
I have posted a mail somewhere in the forum on the Reliance petrol stations between Bangalore-Bombay-Baroda.
__________________
Kumar
Old 17th October 2007, 20:26   #12 (permalink)
hvkumar's Avatar
I found the hotels on the Bangalore-Kolhapur stretch a littlempoor but once you cross into Maharashtra, you have lots of choices of eateries on the highway itself. Same situation in South Gujarat (Bombay-Vapi), but after that, quality of hotels is not great. Tyre puncture shops are aplenty. Petrol stations (especially Pure & Sure, Club HP) are also all over the place. All towns are bypassed. Road signages are good, there is no scope for confusion, it is one road all the way, after you leave Bangalore - first NH4 (except on Pune-Bombay expressway) and NH8 from Ghodbunder.
Bypassing Bombay through New Bombay (Turbhe) through Airoli, Mulund and Thane, is not a complicate dthing - you should take 1 hour for that, although you do have a couple of slow patches that can delay you by 15-30 minutes. I can guide you there in detail through PM.
__________________
Kumar
Old 17th October 2007, 21:13   #13 (permalink)
hvkumar and akroy, you seem to know a lot about routes. Impressive indeed.
__________________
Proxima
2004 Safari LX
2008 Pulsar 180
Proxima is offline   Reply With Quote
Old 18th October 2007, 10:20   #14 (permalink)
Thanks for your reponses. Very informative. Just collcted the toll info from Chennai to Bangalore.
Sriperumbudur - 25.00
Ranipettai - 35.00
This is NH4 route and not through GQ.
Old 18th October 2007, 11:40   #15 (permalink)
madan80's Avatar
Ranipettai - 35.00
After ranipettai,
vellore toll- 25
vanyambadi - 35
krishnagiri - 25
(I might be off a bit here and there, but its within 200 bucks)
If you are taking the chitoor route- you just have two toll booths.
If time is a constraint, I would suggest the GQ through via hosur to bangalore. Its faster, and a better road. The route via chitoor goes through several towns and villages and this can slow you down.
__________________
Taken the plunge!
www. virtu. in
__________________
2002 Lancer | 2006 Palio | 2008 Trek 4300D
madan80 is offline   Reply With Quote
Thread Tools
Chennai-Thalaivasal-Chennai:500km:One day trip.. Ford_madhan Travelogues 2 3rd December 2007 19:37
Chennai-Rameswaram-Kodaikanal-Chennai ram2004 Travelogues 8 4th May 2007 21:37
Where What How in Chennai?? Revvhead Shifting gears 2 24th April 2006 10:54
Hello, I am from Chennai krikah Introduce yourself 4 27th February 2006 09:13
Bombay to Baroda by road. Info needed? GTO Shifting gears 5 9th February 2005 23:35
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
