Old 19th September 2014, 01:53   #916
Default re: Bangalore - Mysore - Ooty : Route Queries
I will be doing a trip to Ooty on 2nd October in my new I20 Petrol (should have about 500-600 kms on the Odo by then). Going to be my first long drive and ghat experience with the new car. I used to drive a diesel Vista, and am still getting used to the idiosyncrasies of this super-smooth petrol car.
Any advice on prep that needs to be done and route to be taken? Travelling with parents.
What time should I start to reach Ooty by 12? Return next day - start after lunch - will that be fine? Not really looking for sight-seeing, just a change of climate and get away from the city crowd.
smukherjee is offline   Reply With Quote
Old 19th September 2014, 12:23   #917
NPV
NPV's Avatar
Thanked: 5,248 Times
Route options
#1. Bangalore-Mysore-Gundlupet-Bandipur-Mudumalai (Mysore road/SH17 route for Blr-Mysore). More Food/break options on this route.
OR
#2. Bangalore-Kanakapura-Malavalli-Kollegal-Chamrajanagar-Gundlupet-Bandipur-Mudumalai. Lesser options for food/breaks. This is the NH209 route till Chamarajanagar. You can have breakfast at Chamarajanagar - Mayura Rajdhani in bus stand complex or Nijaguna Residency.
*Mudumalai is the forest section in Tamil Nadu, continuation of the Bandipur forest on the Karnataka side.
At Mudumalai, you can go straight towards Gudalur and then to Ooty. This is the NH but is broken at some places.
OR
You can turn left towards Masinagudi (place called Theppakadu) and take the 36 hair-pen bend route to Ooty. This road was in excellent condition few months ago, I don't expect it to be bad now. It's a scenic drive too, but if it's your first hill drive, maybe you can avoid it.
Start time from Bangalore - Needless to say, long weekend traffic will be heavy so try to start around 4am.
*4am start may negate the Mysore road advantage of food stop options as most open around 6:45am-7am, and traffic will be more so I would suggest Kanakapura route.
**Ooty will be crowded at this time, so no escaping crowds
NPV is offline   (1) Thanks Reply With Quote
Old 19th September 2014, 14:40   #918
vnabhi's Avatar
Thanked: 1,300 Times
@smukherjee--Please bear in mind that the 36 hairpin route from Theppakadu via Masinagudi is 40 kms shorter, but the gradient is very steep. If you don't have enough experience of driving on ghat roads, this route is best avoided.
The one via Gudalur is a more gradual gradient, though longer.
Old 19th September 2014, 16:04   #919
Thanks for the advice! I have done ghat roads before in my Vista (Munnar cpl of times and Kodai). This is the first time in the new car and it's a petrol car. I am worried about hurting the engine while it is still in its run-in period. I'm also planning to do a quick Nandi Hills trip to see how comfortable the car is on ghat roads.
The other route seems to be longer and previous posts indicate the roads are quite bad on a particular stretch - so at least while going up I was hoping to take the shorter hairpin route. In terms of time taken, how much difference would there be between the two options?
Old 19th September 2014, 18:29   #920
Rajeevraj's Avatar
Thanked: 8,777 Times
I think the time difference would easily be 1 to 1.5 hours
One other consideration would be the fact that that i20 petrol is known to be a little under powered specially under load. The 36 hair pin drive is very steep and will involve a fair bit of first gear usage. I think the nandi hills plan is a good one. Although that is nothing compared to the ooty ghat, it can give some idea ( especially the final couple of curves which are steep)
Rajeevraj is offline   Reply With Quote
Old 19th September 2014, 19:02   #921
vnabhi's Avatar
It took around 25 minutes longer on the return via Gudalur. By the way, the Gudalur route is 31 kms longer, not 40.
Wish you a pleasant journey.
vnabhi is offline   (1) Thanks Reply With Quote
Old 19th September 2014, 19:08   #922
jkrishnakj's Avatar
Thanked: 319 Times
sMukherjee -
Its very much doable. I did this on my Brio last month. The roads were good. The traffic on the masinagudi section with the 36 bends is actually a bit lesser than the gudalur route. I would say go for it. You save a lot of time thru this route.
jkrishnakj is offline   (1) Thanks Reply With Quote
Old 19th September 2014, 19:19   #923
NPV
NPV's Avatar
@smukherjee - other route options would be via Mettupalayam so you could take either:
Bangalore-Salem-Avinashi-Mettupalayam-Ooty OR
Bangalore-Kanakapura-Chamarajanagar-Dimbam ghat-Sathyamangalam-Mettupalayam-Ooty.
Old 20th September 2014, 15:31   #924
sabret00the's Avatar
Thanked: 45 Times
Just returned to Bangalore. Thanks to those who helped me plan the trip in a jiffy
While going I went via Mysore and returned via Kanakpura Road.
Bangalore to Mysore stretch is 4 lane with dividers but there are lots of speedbreakers. Also it has a lot of towns and the entire stretch is filled with traffic more or less. From Mysore to Ooty road is two lane with no dividers. Road condition is not so good.
The Kanakpura Road stretch via Chamrajanagar is two lane with no dividers but the road condition is comparatively better. You will not find much traffic in-between and I could maintain higher speed on this stretch. Especially that I had to reach HSR BDA KIA Bus Stop within 2PM.
Will post more details in a separate thread soon
sabret00the is offline   (1) Thanks Reply With Quote
Old 25th September 2014, 13:09   #925
Thanked: 57 Times
Hi @sabret00the, how was the road between Chamrajanagar and Gundlupet? One of the earlier posts in this thread mentioned it had some bad stretches, though that was in July.
Another question to anyone who did this route recently: Have any decent food options come up recently on this route (via kanakapura-malavalli-chamrajanagar)
mohan41 is online now   Reply With Quote
Old 25th September 2014, 13:15   #926
Rajeevraj's Avatar
Taking the liberty of answering. Chamrajnagar-Gundlepet is average when compared to the Kanakpura-Kollegala-Chamrajnagar stretch. But considering it by itself, it is pretty decent. It is a mix of fairly good stretches inter-spread with patchy ones. But no really bad stretches or pot hole filled stretches. This update is as of September first week.
No new food options that have come up on this route. Nijaguna is still the only family friendly place on the stretch.
Rajeevraj is offline   (1) Thanks Reply With Quote
Old 25th September 2014, 13:41   #927
Thanked: 57 Times
Thanks Rajeev.
I am wondering how this route will be : Ramanagara-Maddur-Malavalli-Kollegal-Chamrajnagar-Gundlupet. With this we get some good morning breakfast options till Maddur hopefully with decent toilet facilities. Post Maddur this route will avoid the heavy traffic of Mysore route. The only unknown is Maddur-Malavalli. Overall distance via this route vs others (via Kanakapura or via Mysore) looks almost same on the map.
Old 25th September 2014, 14:56   #928
Rajeevraj's Avatar
Thanks Rajeev.
Don't think this is a good choice. Typically the reason to use the Kanakpura-Kollegal route is to avoid the traffic and choke-points on Mysore road. With the above option (assuming you are heading out on a long weekend), you will still need to negotiate the heavy traffic til Maddur which will include Kengeri, Bidadi, Ramanagara and Channapatna. If you are taking this route then may as well go via Mysore-Nanjangud itself. You can always by-pass Mysore using the Ring Road.
Old 25th September 2014, 17:21   #929
Thanked: 22 Times
Thanks Rajeev.
Greetings of the day!
+1 to what Rajeevraj says! The NH 209 (Kanakapura road) route shall be more scenic and with lesser traffic enabling you to maintain higher speeds almost throughout.There is also an option of exploring offbeat destinations like Talakadu, Kollegal, Belakavadi and the like, directly through this route and/or slight diversions.
Regards!
onkar1710 is offline   (1) Thanks Reply With Quote
Old 25th September 2014, 20:22   #930
NPV
NPV's Avatar
While the strategy is good considering you get lots of options for breaks/food between Bangalore-Maddur on the Mysore Road, the Maddur-Malavalli stretch will make you feel sorry, remember reading recent posts that it's not in good condition
For food breaks, some options, 6.30am onwards mostly
-Vasu Hotel in Kanakapura town on the highway itself on left side
-Mayura Rajdhani in the Chamarajanagar bus stand campus
-Nijaguna resort in Chamarajanagar just off the highway (the road going towards Dimbam ghats at the end of the town).
Madurai - Mysore - Ooty - Madurai : Route Queries RajeswaranK7 Route / Travel Queries 35 10th May 2017 13:31
Mysore - Yeswantpur - Airport - Mysore : Route Queries madaboutCARS Route / Travel Queries 18 25th December 2015 11:02
Wedding bells in the hills!::Pune-BLR-Mysore-Masinagudy-Ooty-Gudalur-Mysore-BLR-Pune pjbiju Travelogues 15 25th March 2009 14:25
My most Awaited trip Bangalore - ooty - Mukurthi Fishing Hut - ooty - Bangalore. bglsrini Travelogues 25 17th September 2008 18:31
