Old 28th April 2015, 18:52   #1096
sdp1975's Avatar
Thanked: 927 Times
Default re: Bangalore - Mysore - Ooty : Route Queries
Originally Posted by philjo View Post
I am planning to drive to Ooty, this Friday. Which is the best route to an easy climb-up between Masinagudi-Kalhatty-Ooty and Gudalur-Naduvattom-Pykara-Ooty? Looks like no one has choosing the latter option even though it is bit higher in distance. Any thoughts?
Keep in mind the extra traffic due to the long weekend. I was returning to Bangalore on the long weekend of Jan 26 and Mysore road was a complete mess. Took a right turn at Mandya , reached Kanakpura road somehow. Heard somebody took 7 hours to reach Bangalore on that day.
If you're leaving early mornings there won't be a problem, but peak hours - particularly returning on the evening of Sunday May 3 may take longer if you choose Mysore road.
sdp1975 is offline   (1) Thanks Reply With Quote
Old 28th April 2015, 21:49   #1097
Thanked: 1,317 Times
Am driving down to Coonoor in a fortnight from Bangalore, but am halting overnight at Mysore to split the drive duration (traveling with a 2 year kid, hence).
I understand the Mysore - Ooty (via Nanjangud - Gundlupet) road is in bad condition and avoidable. What other option do I have?
sachinayak is offline   Reply With Quote
Old 28th April 2015, 22:40   #1098
Rajeevraj's Avatar
Thanked: 8,350 Times
If you are halting in Mysore, you don't have any other option other than the Nanjangud-Gundlepet route. This route is not terribly bad, its being widened and hence several average stretches and diversions.
The other option is Bangalore-Salem-Avinashi-Mettupalayam-Coonoor. It is much longer by distance but should take almost the same time since you get 4 lane all the way to Avinashi and also avoid the time to cross Ooty.
I don't think you need a stop over. It will be a ~7hour drive, so maybe you can look at taking a longish break and complete the drive in one day.
Rajeevraj is offline   Reply With Quote
Old 30th April 2015, 04:22   #1099
Thanked: 76 Times
Hey guys
I am planning for a Bangalore -Ooty trip during the coming weekend (leaving on 2nd and returning on 4th). I understand from the previous posts on this thread that the mysore -nanjangud-gundlupet route is avoidable due to some road work. Is it still the case?
If so the other option appears to be the route that kala suggested in one of the previous posts i.e via malavalli-talkad -chamrajnagar. Are there good breakfast options on this route? If not, can I take the mysore road till srirangapatna and then deviate towards chamrajnagar? Is this road good and are there any deviations / road work on this stretch that I should be aware of?
Thanks in advance
Car-go-man is offline   Reply With Quote
Old 30th April 2015, 06:58   #1100
mpksuhas's Avatar
Thanked: 3,517 Times
Unfortunately there is no trouble free route currently.
NH 209- Kanakpura -Kollegal route has bridge closure, which requires a long deviation which is listed in detail by TBHPian Kala few pages back.
Nanjangaud - Gundulpet route has road work in progress.
The deviation via Srirangapatana - Bannur- Mallavalli has bad sections in Bannur.
Guess you will have to opt for a lesser troublesome route based on your drive requirements.
mpksuhas is online now   (1) Thanks Reply With Quote
Old 30th April 2015, 07:06   #1101
ampere's Avatar
Thanked: 8,824 Times
If you come down till Srirangapatna, then its: Srirangapatana - Bannur - T Narasipura - Muguru - Chamarajanagar.
I think Srirangaptna-Bannur is good. I am not sure about Bannur - T Narasipura.
Today I think an early start on the Mysore road followed by Bannur- T-Narasipura-Chamarajanagar-Gundlupet should give the best option. Simply because Mysore road will give options for food and then the follow-up route, bypasses the bad sections. There is only one unknown though as mentioned earlier. It would be good if someone can check it out. But yes, the whole option will cost about 30km more.
ampere is offline   (2) Thanks Reply With Quote
Old 4th May 2015, 12:42   #1102
InControl's Avatar
Thanked: 157 Times
Was a terrible experience to say the least Bangalore - Mysore took 7 hours and then Mysore to Ooty another 4 hours. Left at 7.30 AM un the morning from New BEL road and reached at 6.30 Ooty on 1st May.
While coming back also Mysore-Bangalore took 5+ hours yesterday evening.
Last edited by InControl : 4th May 2015 at 13:03. Reason: adding dates, spell check
InControl is offline   Reply With Quote
Old 4th May 2015, 14:04   #1103
Rajeevraj's Avatar
I returned from Kerala via Gudalur-Gundlepet. Seeing the traffic inside the forest itself (at ~5 PM), I felt that Gundlepet-Mysore-Bangalore is going to be a nightmare. Hence I turned off at Gundlepet and returned via Chamrajnagar-T Narsipur-Talakkad-Malavalli-Kanakpura-Bangalore.
Left Gundlepet at 5.40 PM and reached the Kanakpura-NICE Road Jn at 9.50 PM with a 20 min break.
On a long weekend, you should be out of Bangalore and hit Mysore Road by 5 am if taking Mysore Road, and return either before lunch on the last day of the holiday or take a different route.
Edit: Mudumalai Forest Entry to Theppakadu continues to be in shambles. I had read in some thread here that it had been repaired. Not true at all
Rajeevraj is offline   (1) Thanks Reply With Quote
Old 4th May 2015, 14:07   #1104
InControl's Avatar
Thanked: 157 Times
Thanks. I learnt it the hard way though.
Old 4th May 2015, 16:11   #1105
motomaverick's Avatar
Thanked: 864 Times
Even I was there on 1st May on Mysore road going towards Wayanad. It was worse than Bangalore city traffic. Started at 12.30pm from Kamalanagar and could reach Maddur only by 3PM. After lunch took the diversion at Maddur towards Chamrajnagar via Mavalli. Much better in terms of traffic. Roads are not good though from Maddur upto Malavalli due to expansion work.
While returning completely misread the route and went via Kollegal towards Malvalli only to find out that the bridge is closed hence, had to backtrack to go via Talakkad.
motomaverick is offline   (1) Thanks Reply With Quote
Old 4th May 2015, 16:17   #1106
ampere's Avatar
Looks like day by day driving to Ooty is no more a pleasure at all. Crowd, bad roads, closed bridges just to name a few. The only solution now is to time it right.
Old 4th May 2015, 17:54   #1107
Thanked: 709 Times
Ooty itself is becoming a "hill station" over-crowded, ill maintained and in desperate need of fresh air. I had made visit their four years back, but luckily decided to stay put at Masinagudi. The small resort at Masinagudi gave my family a better experience, which we could not have got in the crowded Ooty. Two years later we visited Kodaikanal, seems to be in much better shape than Ooty.
sachinpk is online now   Reply With Quote
Old 4th May 2015, 22:25   #1108
Rajeevraj's Avatar
Yes, looks like it needs to be timed well. Maybe plan the trip during weekdays. Unfortunately there is no end in sight and it is only going to get worse. The 6 laning of Mysore road will really not help. What was needed was a controlled expressway like the NICE Road. Making it 6 Lane and building by passes are only temporary solutions. Also fail to understand why the road inside the Bandipur/Mudumalai forest has not got a fresh coat of tar for years now. The Theppakad-Gudalur section has been in shambles for a very long time now.
Ooty, fortunately (or unfortunately) is very accessible. I spent several years in Ooty as a kid in the 80's, even then there was a large tourist influx from Kerala. It is ~5 hours drive from pretty much any place from Central to North Kerala. Similarly it is very accessible from large parts of Karnataka and Tamilnadu. Last but not the least, with the concept of quick trips gaining popularity and more and more people willing to drive, crowds from Bangalore pretty much take over any tourist spot and Ooty is always the prime contender.
Kodai is a little lucky in that aspect, it is a little more isolated compared to Ooty.
Old 5th May 2015, 18:24   #1109
luvurride's Avatar
Thanked: 300 Times
Not really, Kodai is also packed with local crowd over the weekends. Madurai/Dindigul/Trichy/Coimbatore/Erode are all pretty close a drive.
luvurride is offline   Reply With Quote
Old 8th May 2015, 11:32   #1110
maheshramaling's Avatar
Thanked: 151 Times
Hi, Isn't road work happening on this section or is it over or you took some deviations?
Planning to go tomorrow to masinagudi from Bangalore - hence, enquiring.
maheshramaling is offline   Reply With Quote
Madurai - Mysore - Ooty - Madurai : Route Queries RajeswaranK7 Route / Travel Queries 35 10th May 2017 13:31
Mysore - Yeswantpur - Airport - Mysore : Route Queries madaboutCARS Route / Travel Queries 18 25th December 2015 11:02
Wedding bells in the hills!::Pune-BLR-Mysore-Masinagudy-Ooty-Gudalur-Mysore-BLR-Pune pjbiju Travelogues 15 25th March 2009 14:25
My most Awaited trip Bangalore - ooty - Mukurthi Fishing Hut - ooty - Bangalore. bglsrini Travelogues 25 17th September 2008 18:31
