Old 7th May 2016, 16:02   #1441
jkrishnakj's Avatar
Thanked: 319 Times
Try avoiding the regular tourist spots at Ooty and you'll feel comfortable. Temperatures in the evening are better at Ooty than Coorg.
jkrishnakj is offline   Reply With Quote
Old 7th May 2016, 19:22   #1442
eethanhunt's Avatar
Thanked: 9 Times
Originally Posted by mpksuhas View Post
I guess you are mentioning about Mysore - Gundlupet road work. It's almost done now, apart from couple of smaller sections no issues.
Yes - thank you. Thought it is still going on.
eethanhunt is offline   Reply With Quote
Old 7th May 2016, 20:14   #1443
sj_koova's Avatar
Thanked: 176 Times
Default Re: Bangalore - Mysore - Ooty : Route Queries
Just back from Coonoor. Avoid Ooty if possible. Too many traffic restrictions in the city due to election time.
sj_koova is offline   Reply With Quote
Old 8th May 2016, 02:17   #1444
eethanhunt's Avatar
Thanked: 9 Times
Wow! Guess the elections and Summer vacations - may be. Will postpone then. Thank you so much for the heads up. How about visiting Conoor???
Thank you KRISHNA. I also came to know about traffic restrictions in Ooty.
Mod Note: Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another on the SAME THREAD!
To know how to multi-quote, click here (How to MULTI-QUOTE (when replying to a thread) on Team-BHP).
Old 9th May 2016, 20:57   #1445
Thanked: 96 Times
Just curious - how much of the ring road of Mysore is completed and functional now? Can anyone share the sketch of the proposed/completed ring road intersecting the major highways out of Mysore?
ajithbr is offline   Reply With Quote
Old 10th May 2016, 07:36   #1446
sandsun7's Avatar
Thanked: 666 Times
It is complete now.
Gmaps route in clockwise and anticlockwise from Columbia asia signal on NH275 towards Ooty/Calicut road.
https://goo.gl/x1t6iG
and
https://goo.gl/l9ppNb
sandsun7 is offline   (1) Thanks Reply With Quote
Old 10th May 2016, 11:12   #1447
nagarjun's Avatar
Thanked: 29 Times
I have taken the clockwise route while approaching Mysore from Bangalore. The road is fully complete. Though its a bit lengthy, you can reach Mysore airport from Columbia asia hospital junction in about 20mins. This is shorter than the anticlockwise route if you are heading towards Nanjangud.
nagarjun is offline   Reply With Quote
Old 15th May 2016, 12:25   #1448
cool_dube's Avatar
Thanked: 397 Times
Hi all,
I am driving to Bandipur next week. Which is the best option, given current road conditions? Is Mysore-Gundlupet road work complete? How is Mysore - Nanjangud? Or should I take Kanakapura road instead?
Thanks in advance
cool_dube is online now   Reply With Quote
Old 15th May 2016, 14:47   #1449
Thanked: 826 Times
Originally Posted by cool_dube View Post
Hi all,
Thanks in advance
If you are comfortable in driving 2L roads, i would suggest to go with Kanakapura road as first option. However, if you are particular about food and not so comfortable in 2L roads, take Mysore route.
-Ravi
ravib is offline   Reply With Quote
Old 15th May 2016, 15:51   #1450
NPV
NPV's Avatar
Thanked: 5,249 Times
Mysore route is easy and straightforward, but start early say 5am or thereabouts. Most eateries open by 6.45am. You can even have breakfast at Kamat Madhuvan near the palace and that's the beginning of the Najangud road as well. There is some widening work between Mysore and Najangud but should be manageable. From Najangud continue straight to Gundlupet and Bandipur (don't turn right after Gundlupet as that's the road to Sulthan Bathery on Kerala side).
Alternate route is Bangalore-Kanakapura-malavalli-kollegal-chamarajanagar-gundlupet-bandipur. You can break at Nijaguna Residency Chamarajanagar.
NPV is offline   Reply With Quote
Old 15th May 2016, 21:59   #1451
Thanked: 826 Times
As part of the construction work going on, I remember seeing a very clear sign boards newly setup in that Junction at Gundlupet which gives directions to Bandipur (Straight) and Sulthan Bathery/Wayanad/Kalpetta (Right turn).
-Ravi
Old 16th May 2016, 14:30   #1452
Thanked: 56 Times
Just back from Ooty in my Ertiga. The road from Mysore to Nanjangud is under road widening and lots of diversion, folks are requested to take the outer ring road to avoid the frequent slow down.
Then till gundulpet the road is very good. From Gundulpet to Bandipur single road but very good. From Bandipur to Ooty via Masinagudi the road in the forest are good with speedbreakers.You will see lots of deers along the road. The 36 hairpin bends roads are also good.
Ooty is very crowded as it is peak season. There are some traffic restrictions at Charring Cross but no roads have been digged. Also you don't find any election fever.
All tourist spots are very crowded. Avoid Weekends.
fuzail is offline   Reply With Quote
Old 16th May 2016, 14:38   #1453
NPV
NPV's Avatar
By taking Mysore outer ring road, will it help avoid entire Mysore-Nanjangud stretch ? I think the ring road on either side of Columbia Asia hospital signal will you to somewhere just after the Palace and Kamat Madhuvan hotel on the Nanjangud Road, but there is still a long way to go for Nanjangud, what am I missing ?
Old 16th May 2016, 14:46   #1454
Thanked: 56 Times
I wanted to go to the Mysore Zoo while returning from Ooty. When I reached the Junction from where it is mentioned Zoo 4 Kms , i took the Outer Ring road for the Zoo. In this way I avoided the diversions and the slowdowns.
Old 17th May 2016, 14:03   #1455
mpksuhas's Avatar
Thanked: 4,093 Times
Had taken Bangalore - Mysore - Kamat Madhuvan - Nanjanguad road till Mysore ORR - Right turn towards Mananthavady road last Saturday.
The reason why there is a mention above to take Mysore ring road may be to avoid part of road widening work ongoing near Mysore I guess.
There is lots of deviations and road work ongoing near Mysore - Mysore Airport stretch, you can avoid part of this by taking ring road and joining near Airport.
Also, NH 212 section near Bandipur forest entry at KA - KL border on Calicut road has a toll booth coming up. So once the road work on Mysore - Ooty section gets over, we can expect similar toll booth on this road too.
mpksuhas is offline   Reply With Quote
Madurai - Mysore - Ooty - Madurai : Route Queries RajeswaranK7 Route / Travel Queries 35 10th May 2017 13:31
Mysore - Yeswantpur - Airport - Mysore : Route Queries madaboutCARS Route / Travel Queries 18 25th December 2015 11:02
Wedding bells in the hills!::Pune-BLR-Mysore-Masinagudy-Ooty-Gudalur-Mysore-BLR-Pune pjbiju Travelogues 15 25th March 2009 14:25
My most Awaited trip Bangalore - ooty - Mukurthi Fishing Hut - ooty - Bangalore. bglsrini Travelogues 25 17th September 2008 18:31
